Inner layer of a microwave door is part of the metal cage that keeps the microwave energy inside and prevents potentially dangerous energy leaks.
To clean the inside of the glass the door will need to be dismantled - some doors dismantle easily and some don't and sometimes the door must be removed in order to dismantle...
Some doors remove easily and some don't...
It is very important the door is reassembled correctly and then tested for energy leakage.
SOURCE: Panasonic Microwave Warm
Replace the h.v. capacitor (the silver can mounted in back under the magnatron) and the h.v. diode and it will be fine.
Hope Ya Fix It!
SOURCE: Cleaning inside of microwave door
THE DOOR ON MY MAYTAG MICROWAVE OVEN HAS A SCREEN OVER IT. I HAVE SOME FOOD SPATTERS THAT PENETRATED THE SCREEN AND I CAN'T CLEAN THE GLASS THAT THE SCREEN PROTECTS. HOW CAN I REMOVE THIS SCREEN TO CLEAN THE GLASS?
SOURCE: PANASONIC NN-SN789S MICROWAVE INVERTER. IN LOCKED
The owner's manual cover should cover this. if for some reason you don;t have yours, you should be able to download it here.
If you're outside the US, see Panasonic.net.
We're
happy to help you with free advice and we'd appreciate your thoughtful
rating of our answer.
SOURCE: My Panasonic Inverter Genius Sensor 1250W Lights
microwave is in lock mode. How do you unlock to use?
SOURCE: microwave runs for 3 seconds and stops
See if this describes
what's happening:
If so, see http://207.234.249.73/mwd/safety.txt , http://207.234.249.73/mwd/disassembly.txt and http://207.234.249.73/mwd/doorsw.txt
Otherwise, if
the digital programmer circuit / controller does not get a feedback
signal from the inverter for a period of 3 seconds, the controller will
stop the cook cycle.
That may be a loose connection in the wiring between the
inverter, magnetron, and/or control board, or maybe one of
those
components has failed.
Due to the lethal
voltages used and produced in inverters, I do not recommend that an
inexperienced person work on these.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
We're
