Powers up (can hear fans turn on), power light blinking green, then switched to steady orange power light and steady red lamp light. Replaced the lamp with new one two times and still does the same...
There is a sensor in those that can tell if you are using an original bulb or another one, IF you just changed the bulb and not the module then it may not see the new bulb.
Testimonial: "Thank you Brad, but could you specify where that sensor is...? The lamp module doesn't seem to have a one. I replaced the hole lamp module not just the lamp... Is there a way to fool this sensor...? Thanks again..."
SOURCE: Lamp will not come on
try pressing and holding the enter button on the projector for about 30 seconds - this resets it. It worked for me!!
SOURCE: Power LED blinks red
it is a bad fan. it also could be a power supply. Quite often the real problem is dirt clogging up the fan(s) to the point that they need to be replaced. Operation of the set in a dirty environment is not a good idea
SOURCE: Power indicator light blinks orange times
sounds like the lamp faceplate is not screwed back in properly
SOURCE: power light flashed red 4 times then repeats no pic,new bulb/fan!
Check the fan that cools the bulb. It is directly behing the bulb. It should turn on when the power comes on. It apparently has a safety to protect your tv(and home). mine is in the process of going out. looking for online solutions as we speak.
SOURCE: No picture or sound - Power Save light blinks red 5 times - nothing on the screen
i also have the same problem with the flashing green light for a while then a different red light starts blinking on and off around 5 times....and i replaced my burnt bulb with a new one...still no picture.
