Exercise & Fitness Logo
T
Terri Murphy Posted on Mar 27, 2020
My Tunturi 620P treadmill is stuck in S! mode. Prior to this if I hold the ENTER button for a dew seconds the screen clears. This is not working. I tried the reset button and both buttons together.
Ruffa bonos
Level 1:
New Friend:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 18 Answers
  • Posted on Mar 28, 2020
Ruffa bonos
Contributor
Level 1:
New Friend:
Welcome Back:
Answers
18
Questions
0
Helped
5498
Points
37
Unplug your treadmill from its power outlet
2answers
Motor Drive Belt Tunturi J620P Treadmill
Please check with Mcmaster carr, ebay and amazon to find your treadmill part. You can also check out alibaba if the 3 prior sources don't work out for you.
Thank you.
My tunturi 620p has a e2 code how can i fix it
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. check for tunturi treadmill articles
http://electro-medical.blogspot.com/
When I turn on says stuck button
reset the treadmill, follow this step and fix it. Merry Christmas
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • 3
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
    • 4
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.move on to the next step.
    • 2
Locate the reset switch on the underside of the treadmill console. Usually the button
2answers
My tunturi T 20 gets error code E 7. it starts up, and after 5 or 10 seconds, it stops and flashed the error code. I have tried the recommended solution, which is to unplug the treadmill, wait a minute to...
From time to time, error codes will pop up on your treadmill. It just takes a quick second to clear the error log and get the treadmill up and running again.
1.When the treadmill is not in use, press the "Stop," "ENTER" and "QUICK START" buttons in rapid succession. The "RESET" button can also be used, in place of the "Stop" button.
2.Press the "ENTER" button three times to access the treadmill's error log.
3.Press the up or down arrows to scroll through the error codes, if necessary for club or personal logging purposes.
4.To view the treadmill's odometer reading when a particular error code was elicited, press "SELECT" while a particular error code is displayed.
5.To clear the error log, press "QUICKSTART" for a minimum of four seconds while viewing the list. Prompts will appear on the display and let you know when the log has been deleted.
I hope you find it very helpful.
6helpful
The machine just goes into auto calibrating on the screen and beeps constantly. does not stop auto calibrating Just seems unable to cope with any programs to do with hill climbs
power off, put in the key, press and hold down the 'stop' button and 'incline up' buttons, power on holding down the buttons for a few seconds - message clears
4helpful
2answers
T60 treadmill came up with lift motor error so switched off. Now when I switch on it displays autocalibrating but never gets any further. Can you help?
power off, put in the key, press and hold down the stop button and incline up buttons, power on holding down the buttons for a few seconds - message clears
1helpful
My Tunturi Treadmill ramp is stuck in the top elevation position and will not run. I get a "Auto Syncing" message, but the machine will not run. Have tried unplugging etc, but it will not exit the mode...
Enter the testing mode after switching the treadmill POWER ON by pushing first ‘SELECT’ and then ‘SPEED DOWN’ and hold buttons pressed simultaneously.
LED scanning mode for verifying display functionality Press ‘ENTER’ to scan DATA LINES to verify display functionality Press ‘ENTER’ to scan SACN LINES to verify display functionality Press ‘ENTER’ to scan LED’s to verify display functionality After pressing ‘ENTER’ the TIME window shows “test” and the keypad functionality can be tested (the value displayed changes when a button is being pressed) Press ‘ENTER’ to enter IO mode (TIME display shows lift motor potentiometer value, SPEED reads speed from speed sensor and DISTANCE shows heart rate pulse) Press ‘START’ to test lower board relay (a “click” sound) and then press ‘ELEVATION UP’ for 2 seconds to increase the elevation to 8%. Press ‘ELEVATION DOWN’ to decrease the elevation to minimum percentage 0% Press ‘SPEED UP’ to increase speed value and ‘SPEED DOWN’ toto decrease speed value. Press ‘ENTER’ to repeat above test or ‘SELECT’ and ‘ SPEED DOWN’ buttons simultaneously to return to the normal mode
The lift motor calibration is done manually by following the following steps: 1. Drive the lift motor to 0% from user interface (inclination display must be 0%) 2. Switch off the treadmill and unplug the power cable 3. Remove motor cover 4. Fold up the running deck 5. Loosen two screws (A) attaching the lift motor nut (B) to the incline frame 6. Adjust the lift motor nut (B) so that there is 9 mm (.358 in ) gap between the upper end of the nut and the lift motor frame Tighten the screws (A) and verify correct elevation by measuring Adjusting lift motor to 0% position 2.76in 12% position 9.646 in measurement taken from floor to bottom of motor compartment frame.
1helpful
Treadmill Tunturi T 20 keeps inclining upward by itself
Testing Mode 1. Enter the testing mode after switching the treadmill POWER ON by pushing first ‘SELECT’ and then‘SPEED DOWN’ and hold buttons pressed simultaneously 2. LED scanning mode for verifying display functionality 3. Press ‘ENTER’ to scan DATA LINES to verify display functionality 4. Press ‘ENTER’ to scan SACN LINES to verify display functionality 5. Press ‘ENTER’ to scan LED’s to verify display functionality 6. After pressing ‘ENTER’ the TIME window shows “test” and the keypad functionality can be tested (the value displayed changes when a button is being pressed) 7. Press ‘ENTER’ to enter IO mode (TIME display shows lift motor potentiometer value, SPEED reads speed from speed sensor and DISTANCE shows heart rate pulse) Press ‘START’ to test lower board relay (a “click” sound) and then press ‘ELEVATION UP’ for 2 seconds to increase the elevation to 8%. Press ‘ELEVATION DOWN’ to decrease the elevation to minimum percentage 0% Press ‘SPEED UP’ to increase speed value and ‘SPEED DOWN’ to decrease speed value. Press ‘ENTER’ to repeat above test or ‘SELECT’ and ‘ SPEED DOWN’ buttons simultaneously to return to the normal mode
2answers
My Tunturi T20 treadmill stops and cuts the power. This happens when it is stopped with the emergency switch. Then when I try to turn it on again it shows KM 579 and then nothing..no power no screen...
We have the EXACT same problem! Would love to hear a solution to this. It will eventually work again but we have no idea what brings it back to life. I've tried the reset button, unplugging and replugging numerous times and still get the KM and 579 showing up and then no power.
13helpful
TUNTURI 620p TREADMILL displays 51, or S1 WHEN TURNED ON , AND WILL NOT OPERATE. PLEASE SEND ANY INFORMATION TO HELP SOLVE THIS PROBLEM.
Solution:
press and HOLD the button that says display above it and Reset below it untill you see the normal start up Screen and yoru good to go!
Top Tunturi Exercise & Fitness Experts
ZJ Limited
ZJ Limited
john h
ADMIN Andrew
ADMIN Andrew
Are you a Tunturi Exercise and Fitnes Expert? Answer questions, earn points and help others
