Question about HP Office Equipment & Supplies
HP LaserJet 2015 fatal error led light comes on when power on
Posted by Nolly on
Attique-ur-Rehman
    Top Expert:
  • HP Master
  • 2,677 Answers
Https://www.youtube.com/watch?v=zNjyQLBuhno
Posted on Mar 26, 2020
5 Related Answers
Anonymous
  • 87 Answers
SOURCE: HP Laserjet 2015 dn
It means that the printer is in READY State.
Control panel
The printer control panel is comprised of six lights and two buttons. The lights produce patterns that
identify the printer status.
1 Jam light: Indicates that there is a jam in the printer.
2 Toner light: When the print cartridge is low, the Toner light illuminates. When the print cartridge is out of the printer,
the Toner light blinks.
3 Paper out light: Indicates that the printer is out of paper.
4 Attention light: Indicates that the print-cartridge door is open or other errors exist.
5 Ready light: Indicates that the printer is ready to print.
6 Go button and light: Initiates action or indicates status.
7 Cancel button: To cancel the print job that is currently printing, press the Cancel button.
Posted on Nov 03, 2008
Anonymous
SOURCE: when trying to print to
try loading a pcl5 driver instead of the pcl6. pcl xl is hp's pcl6 and some times has problems.
Posted on Mar 27, 2009
Anonymous
SOURCE: Fatal Error
Did you try cleaning the led heads
Posted on Apr 25, 2009
Anonymous
  • 102 Answers
SOURCE: Printer Hp Laserjet 3055 giving error message 5
If you scanner error 5 or printer hangs at scanner bulb warming up than the issue is with Scanning Assembly inside the printer and it is hardware issue.
Posted on Jul 02, 2009
1helpful
After powering on printer firstly initialize then all led are turn on & not getting ready...
c00381709.gif Fatal error
All lights are on. Unplug the printer for 30 minutes, and then plug the printer back in power outlet.
Replace the formatter assm..
All led study
This is a fatal error. I can tell you exactly what is wrong but you need to press and hold the go button and post what light you see when you do that. I can then give you the exact item that has failed.
Printer all led on when i give the printing
Hello!
From HP website:
All lights are on
Issue
The product experienced a fatal error.
Solution
  1. Unplug the power cable from the electrical outlet.
  2. Wait for 30 minutes, and then plug the power cable into the electrical outlet.
  3. If you have completed all the steps listed above and are still experiencing a problem, service the product.
Visit the website above for more possible problems/solutions...
Good luck and best regards,
Pelu.
2helpful
2answers
The Attention, Ready, and GO LEDs are on solid
Here is service manual for HP 1160/1320 series ->http://filecom.net/CXW_R.
Solution is on page 34. I hope it will help you.
Problem for HP LaserJet 1160 Printer Fatal error light pattern pls help with the hp laserjet 1160
Check if paper is in the printer because that may cause the print to show that light or maybe the hardware part are not properly fit to the printer
3helpful
2answers
My hp laserjet 3030 keeps reading 79 error power on power off
79 errors are often fatal. Your only hope is to get it back to READY, then update the firmware before it reverts back to 79 ERROR. The other option is to replace the formatter, but it would be about the same cost to replace the whole machine.
Help
Hi Raja,
This means there is an error during POST (power on self test). Please refer your manual for the error codes or light codes. If you can manage to access the machine diagnostic menu please do. Like from off position and pressing combination of buttons holding for 3 to 5 seconds and powering it on.
Best regards,
Rosener
2answers
All lights on
Fatal error, I think it has gotten rid of itself, probally fuser at cheapest would be the fix and even that would be more than it is worth to fix. Fatal error will be fuser/laser/board all cost in parts min $100 to 350.
that great but now how do i get rid of it? Place in bin after releasing frustration apon it, if not under warranty
Open Questions:
k24674
Mike
