Https://www.youtube.com/watch?v=DRGvUAa_qvU
https://www.youtube.com/watch?v=zNjyQLBuhno
SOURCE: 2015 network printer
Please perform the following:
Unplug the network Cable:
Cold reset
A cold reset changes most system parameters in NVRAM to the factory defaults. However, unlike NVRAM initialization, a cold reset does not reset the page count, the paper tray sizes, language, or formatter number.
A cold reset also resets all the HP Jetdirect settings as well as the printer settings.
Use the following procedure to perform a cold reset.
The printer's LEDs begin cycling. The cold-reset process runs until completion, and the printer returns to the ready state.
If both the Attention and the Ready LEDs turn on before you release the Go button, you must start the procedure again with step 1.
Network reset
A network reset changes all network system parameters in NVRAM to the factory defaults. During the network-reset process, all button presses are ignored.
Use the following procedure to perform a network reset.
Now plug in the network cable and then wait for 5 mins.
If the Attention and Ready lights illuminate before you release the Job Cancel button, start again at step 1.
Then print a configuration page and check the IP Address.
SOURCE: when trying to print to
try loading a pcl5 driver instead of the pcl6. pcl xl is hp's pcl6 and some times has problems.
SOURCE: Printer Hp Laserjet 3055 giving error message 5
If you scanner error 5 or printer hangs at scanner bulb warming up than the issue is with Scanning Assembly inside the printer and it is hardware issue.
SOURCE: hp 2300 laserjet printer error code 13.20.00
this problem persist NVRAM resetting
To perform an NVRAM initialization, complete the following steps:
1 Turn off the printer.
2 Press and hold (DOWN arrow), and turn on the printer.
3 When all three status lights are lit, release (DOWN arrow) and press (UP arrow).
4 Press PAUSE/RESUME. The first item of a menu appears.
5 Use (UP arrow) or (DOWN arrow) to scroll to NVRAM INIT, and press (SELECT).
cihat ALTIN FROM TURKEY ANKARA
SOURCE: fatal error 980 OKI C5500 printer
I had a paper jam and removed the jammed papers. The paper jam cleared and then the Fatal Error 980 appeared. OKI C5500 printer
