Question about The Kitchen Appliances - Others
I have the 28 Cup Dual Basket Digital Deep Fryer. It said to make sure the white filter is resting on the metal surface below the black filter.
Posted by D Kareem Sumner on
Attique-ur-Rehman
    Top Expert:
  • The Master
  • 2,677 Answers
Https://www.ramtons.com/media/catalog/product/files/R/M/RM370_MANUAL.pdf
Posted on Mar 26, 2020
Testimonial: "Thank you so much, I had them on wrong. Now all I have to do is use the fryer. Appreciate you!!"
I need an instruction manual for a cooks essentials air fryer
How to Use Your Fryer:
  • Remove all packaging materials, sticker, and labels.
  • Clean the basket and pan with hot water, soap and a non-abrasive sponge. These parts are dishwasher safe.
  • Wipe the inside and outside of the appliance with a clean cloth.
  • Place the air fryer on a flat and even surface.
  • Put the basket in the pan.
  • Plug unit in to an approved wall socket.
  • Place the ingredients in the basket and then put the basket and pan back into the appliance. The fryer LED will light up.
  • Set your cooking time and temperature by either choosing one of the 8 presets or manually set it with the "+" or "-" buttons. See "Cooking Guide" to determine the right time and temperature.
  • Once you have set your cooking time and temperature, press the "Start" Button.
  • The heating icon and fan icon will be blinking and this means that the fryer is starting and is circulating the hot air in the fryer. NOTE: During hot air frying, you will notice that the heating up icon will blink and stays from time to time. When the heating icon is on, it means that the temperature inside the fryer has reached the set temperature. When the heating icon is blinking, it means that the temperature inside the fryer dropped and is below the set temperature and is currently heating up to the reach the set temperature.
  • Some ingredients may need to be shaken halfway through the cooking cycle (see "Cooking Guide"), To do this, pull the pan out of the air fryer by the handle, the air fryer will automatically shut down. Then shake the contents in the basket, then slide the pan back into the air fryer and it will resume the cooking cycle. CAUTION: Do not press the button on the handle during shaking; this will detach the basket from the pan.
  • When the cooking time has been reacher, the air blower will stop in 20 seconds.
  • Pull the pan out of the fryer and place it on a pot holder. The cooking pan is VERY HOT do not put on surface that can burn. NOTE: Oil from the ingredients will gather in the bottom of the pan, so be careful when pulling the pan out of the fryer.
  • To remove the ingredients, press the button on the handle of the pan to detach the basket. DO NOT TURN THE PAN OVER. PLACE ON A POT HOLDER.
  • Upon placing the cooking basket back into the air fryer, the air fryer will automatically go to the previous cooking cycle and will repeat the previous cooking cycle, press the cancel button to stop and reset the air fryer if desired.
Mar 25, 2016 | Kitchen Appliances - Others
Why doesnt my deep fryer heat up ?
First it is good to check the fuse by unscrewing the plug.
If the fuse wire is not broken, it means that the deep fryer could be broken.
Nov 21, 2015 | Farberware Home Electric Faberware Deep...
I have a Wells WVAE-55FS 240 55-lb Ventless Fryer, Basket Lift, Oil Filter, Solid State Controls, 240/3... and the check filter light went on.... how do i check my filter and where is my filter located?...
Hi there!
Your filter may need replacement, that is what the light prompts.
For complete owners manual of your unit, you may visit www.wellsbloomfield.com
Regards.
Sep 04, 2011 | Wells WVAE30F Deep Fryer
Our battered chicken and fish is sticking to the basket what do we do?
Hi there:- You mean the products you put into the deep fryer stick to the basket or sunk down to the bottom and stick to the bottom basket. It can be a number of reasons but the most important is the temperature of the oil, it should be 350 degree F or more to do the frying , any temperature below that will be call boiling not frying. Secondly the batter mix ( you should try out and make your own batter mix ) Hope this can help.
Sep 23, 2010 | Rival CZF725 Deep Fryer
I need a filter for My deep fryer
I have the Euro Pro F1066 and love it. But, I called the Euro Pro people and found that there is NO replacement filter. If you go to their site and put in the model number, it shows only the following accessories can be ordered. This is from the Eoro Pro site:
Accessories
Oil Container & Lid
Replacement Fryer Basket
Replacement Control Panel with Element (1700 Watts - U.S. unit)
Power Cord
Replacement Basket Handle
Call 1-800-798-7395 to order
So, the only way to get a new filter is to purchase the Oil Container & Lid which would come with a new filter in the lid. I am trying to figuire a way to rework the original filter but have had no luck so far. I hope this helps answer your question ;-)
Jul 31, 2010 | Euro-Pro F1066 Deep Fryer
Where can I get a new pwer cord for my GE cool touch deep fryer model 106789
call GE customer sva for replacement parts (877) 207-0923
Mar 29, 2010 | GE 106789 Deep Fryer
I purchased this deep fryer. REALLY like it,
use a different oil that worked the best for me
Jan 14, 2010 | Euro-Pro F1061 Deep Fryer
I want to buy a replacement heating element
send me an email at [email protected] , we are factory in China that produce heating elements. :-)
Jun 28, 2009 | Maximatic EDF-4080 Deep Fryer
I lost my users manual for my Rival® 1L Cool Touch Deep Fryer
There is really not much to the deep fryer. it s very strait forward. Fill with oil or lard and drope the basket in and start cooking check now an then to see if done. when cooked remove basket let drain. , Bonaparte DFD
Apr 20, 2009 | Kitchen Appliances - Others
Kitchen Appliances - Others Logo
69 people viewed this question
Top Kitchen Appliances - Others Experts
Marvin
Marvin
Paul Carew
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
