Question about Sceptre Televison & Video
My Sceptre 32. Inch worked fine for year. Then one day no sound!do you have a wiring diagram?
Posted by Thomas Keene on
David Spradling
    Top Expert:
  • Sceptre Master
  • 12,058 Answers
Check input or source see if changed also check audio see if speakers on
Posted on Aug 25, 2020
Attique-ur-Rehman
    Top Expert:
  • Sceptre Master
  • 2,677 Answers
Https://www.sceptre.com/pub/Manuals/HDTV/X32GV-KOMODO.pdf
Posted on Mar 26, 2020
5 Related Answers
Anonymous
SOURCE: i have a 32 inch sceptre naga. when i turn on a
mine does the same thing, before... it would come on when i turned it on & off. But now it blue screens then blank black. Blue means if it stays blue & i turn on my computer it will show all the computer stuff, i have not used TV yet.. But if you can get it to stay blue you can change things with the cc control, or swap..
If you find how to keep it blue let me know please..
Posted on Apr 18, 2009
Anonymous
  • 10 Answers
SOURCE: Sceptre LCD TV power come on, but there is no picture or sound.
There are two easy fixes you can try. Both require you to take the back panel off. If you are not comfortable doing this, take it to a repair shop.
UNPLUG IT.
Place the TV face down on a soft/solid surface.
After you get the back panel off, there are three silver boxes. There are white and black wires leading from the off switch to the top silver box. Take the cover off that box.
Inside is a ceramic fuse. Test that fuse. If it is blown, your local electronics shop can find a replacement.
If not, disconnect the white and black wires from the PC board. Remove the 6 screws holding it in place.
Look for scorch marks under the board.
Cut a thick piece of plastic and tape id down over the scorch marks.
Re-attach the board with the six screws and re-connect the black and white wires.
Turn the power switch to the OFF position and plug in the TV.
Turn on the power switch while WATCHING the board you just removed.
If you hear a sizzle, turn off the switch and get a thicker piece of plasic.
If not, the TV should come back on.
Re-assemble the silver box and put the back on.
Hope this helps.
Posted on Aug 09, 2009
Anonymous
SOURCE: Sceptre 32 tv won't turn off or change channels,
I have the same problem, did you ever get this fixed?
Posted on Feb 17, 2010
Anonymous
  • 19 Answers
SOURCE: my Emerson HDTV 32 inch sound stopped working all
everything with sound picture av component has to do with the main board of the tv not the power supply the only thing you can do its replace the main board not the power supply board or anything else cause it may be only a resistor or a capacitor but to replace it the guy that comes to do it will charge more than replacing it go to www.shopjimmy.com and check your tv model and it will give you what you need and the price and cheaper than the manufacturer
Posted on Apr 13, 2010
Anonymous
SOURCE: westinghouse 32 inch screen goes blank
Westinghouse LTV-32w1
replace capacitor c162 on power supply
power supply was a delta electric dps210ep-2c rev01
reheat any solder joints that don't look 100% as well .
such as c310 .
this is a known working fix . try before you buy a supply .
Posted on Apr 15, 2010
How do I get hd channels to show on sceptre 32 inch classic hdtv?
Silly question, but are you subscribed to the HD channels? Most cable companies include HD channels o higher tier subscriptions, and then require a different decoder box to get them.
1helpful
2answers
Tv is on with no picture or sound, only 4 months old!!
Hello
The power supply regulator board to your set has the fault. If you try to open the set, or try to repair it by yourself, the warranty will void. The set must have warranty as it is new. Why do you spend for it? Just contact the nearest authorised service center for Sceptre. the components in this set will be very hard to get from open electronic spare part market, and will costly too.
1helpful
I have a sceptre 32 inch tv and there is only sound no picture
usually problems with the screen such as sound but no screen means the backlight or power inverter is gone. you can check this out by turning the TV on or off. If you faintly see the screen pop up then go away, and if you shine a flash light on the screen you can still barely see it then it's that problem. You have to buy parts from your manufacturer or open up the TV and see if any transformer or capacitors are toast.
I have a 32in flat screen TV. It's by Sceptre and It's only six years old. The problem im having is that I have to unplug it and then plug back in. I do this approxi four times before it's on all the...
Sounds like a worn out power relay, or a bad capacitor that is keeping the power supply from powering on first try. The thing with Sceptre products is that they don't tend to last too long... six years isn't that bad! Might want to look into replacing it. At this point a 32" TV can be had for less than 300$. It would likely not be worth trying to fix the thing, that is, unless you know how to do it yourself! :3
~KenjiFox
I have a 37" inch lcd sceptre. I got in March, It was working absolutely fine just two days ago. Then I moved it to another room (very carefully) and when i plugged it in, the green light came on but no...
Look for bad solder joints of the NTC Thermister in the main power supply board, it will be closed to where the power cord connection is on the circuit board, you will have to look at the bottom side of th PCB. oNLY
I have a 20 sceptre widescreen lcd monitor
Have you tried any other monitor connected to your computer since your current problem? Check your connections, make sure your VGA cable/DVI cable are in good condition. If none of that works try to RMA it to sceptre if your still within the 1 year period.
Televison & Video Logo
Top Sceptre Televison & Video Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Sceptre Televison and Video Expert? Answer questions, earn points and help others
