Washing Machines Logo
My Aftron front loaded washing machine indicates an error code as FE , could you please any one explain the code and solution also.
Posted by samy nathan on
Attique-ur-Rehman
    Top Expert:
  • Washing Mach... Master
  • 2,677 Answers
Https://removeandreplace.com/2015/05/05/washing-machine-error-codes-front-and-top-load/
The FE error code indicates that the washer is overfilling. This is usually the result of faulty water valve. To fix this: Close both water taps.
https://www.lg.com/us/support/help-library/error-codes-washing-machine-CT10000010-20150140270078
Posted on Mar 26, 2020
rawldc
I just started 6 weeks ago and I've gotten 2 check for a total of $2,200...this is the best decision I made in a long time! "Thank you for giving me this extraordinary opportunity to make extra money from home. This extra cash has changed my life in so many ways, thank you!"
Visit site: http://Neway9.com
5 Related Answers
Anonymous
  • 209 Answers
SOURCE: Indesit front loading washing machine error code
i am a recently retired engineer of 20 years, but this sounds like (based on the info given) a heater element fault, after the machine fills up and agitates a few times the heater should start, check the heater for open circuit, replace if needed, of course it just could be a wire off? if i have helped rate me please
Posted on Sep 09, 2007
Anonymous
  • 3 Answers
SOURCE: Maytag front loading washing machine
This worked for me for the E3 error code: Turn the machine off and then on. Enter the Service Mode by pressing the Chime and Exrta Rinse keys for 3 sec. Display the Diagnostic Codes by pressing the Rinse and Spin key. Clear the codes by pressing the Delay and Chime keys for 3 sec. Turn the machine off, unplug and plug in the power cord. This dumps the memory. Evidently, if it gets full, it causes problems with the programming and messes up the cycles.
Posted on Jun 20, 2008
Anonymous
  • 1776 Answers
SOURCE: F35 error code on a kenmore Elite front loading washing machine
This typically indicates slow drain condition. Check for any clogs or kinks in the drain line. Also check that the pump is not clogged and that no pump impeller blades are missing/broken and that the impeller moves freely. Any broken/missing blades or if the impeller won't turn freely will indicate a faulty pump. Hard objects can sometimes make it to the pump and cause damage. Hope this helped and best wishes.
Posted on Sep 09, 2009
Anonymous
  • 1304 Answers
SOURCE: what does the code 5d mean on my washing machin???
5d is actually SD
it means SUDS
you have suds detected in the pump
Your using too much soap and the machine cannot rinse it
try one load with out any soap
from that load on you should not be using any more that a table spoon per load
Posted on Oct 20, 2009
David
  • 177 Answers
SOURCE: miele front loader washing machine W3275- error co...
hi,
this is a tachogenerator fault or the drive motor brushes are faulty. you will need a Miele service tech or a Miele service agent to look at this.
Posted on May 24, 2010
E2 error aftron washing machine
Aftron Top Load Fully Automatic Washer 5kg AFWA6070P
  • Type: Top Load Fully Automatic WasherLess priced, have a shorter wash cycle and have single tub for washing.
  • Capacity: 5 kgIdeal for smaller families (3 to 4 people).
https://uae.sharafdg.com/product/aftron-afwa6070p-top-load-fully-automatic-washer/
2answers
Code fe on lg what does this mean
This fe error or fault code indicates that the washer is overfilling due to a defective water inlet valve. The valve is not repairable and will need to be replaced.
2answers
LG washing machine loud and error code LE
Here is a tip that explains what the LE error code means.....
LG Washing Machine LE Error Code or Fault Code
heatman101
I have a LG washer model WM2487 H*M suddendly water started coming out from underneath and also the front panel shows a light saying FE....I read that means something about is due the faulty water...
FE = Fill Error. Not a faulty water valve in your case. (FE codes if it takes too long to fill the machine, but if the water is leaking out, the valve is not the problem, the leak is) If you take the back cover off, you might be able to see where the water is comming from. Possibly the black rubber hose from the tub to the pump has a leak.
What is error code FE on LGWM2455HG
The FE code is a overflow code. This can indicate a bad pressure switch but more likely just a clogged pressure switch hose. Remove the top of the machine and locate the pressure switch. It will be the part with the surgical looking hose connected to it. disconnect the hose and be sure it is not clogged. If it is clear replace the pressure switch. Good Luck.
2helpful
Error code FE
From the manual ,FE means Water level is too high due to a faulty water valve. hence the possible leak
4helpful
2answers
"FE" error code; won't stop filling
Hello Sheri Tucker,
The "FE" code is referring to a bad or malfunctioning water valve. The machine continues to fill because the solenoid on the valve inside the machine isn't closing to stop the water. The valve should be inspected and/or replaced if bad. This will require some dis-assembly, if washing machine repair isn't something your comfortable with then a service call is the best bet. If you are going to try and inspect yourself please make sure you unplug the machine before starting any dis-assembly. Hope this helps.
Thanks,
edgin96
I’m happy to assist further over the phone at https://www.6ya.com/expert/ryan_7b238a1b08d97b98
Open Questions:
Top Washing Machines Experts
Marvin
Marvin
