My machine is counting 1-10 and then error aln
Posted by Patrick shoo on
Attique-ur-Rehman
    Top Expert:
  • Office Equip... Master
  • 2,677 Answers
Https://www.youtube.com/watch?v=UmapUgg12UU
https://www.youtube.com/watch?v=JMOOayRplI4
Posted on Mar 26, 2020
My girbau washer flashing ALn error,how to fix it? thanks.
its should be that is the Inverter Drive error.
Check to see if the cooling fan is working on the inverter. If not, then when the drive gets hot, it will cut off in the high speed extract.
If the fan is working then it's probably an inverter.
tip
Features found on most bill counting machines
Bill and coin counters come with a host of different functions and features that when you learn and master the them you will be a bill counting ninja! There are many terms that you will hear when getting started with your coin counter but the the most important ones are hopper capacity, error detection, adding mode and batch counting.
The hopper is the part of the bill counter that holds the bills that are going to be counted. Bill counting machines have a limit to how many bills the hopper can hold this is known as the hopper capacity. Usually instructions come with a number for how many new bills the hopper can hold, but if you are going to be counting older and crumpled bills that number will be cut in half. So if the capacity is 100 new bills then the number of old bills with around 50.
when you are counting bills its important to watch for error detection on the machine. These errors can be for a feeding error, detection of fake bills or a problem with the sensors in the machine. Machines with error decors are on the higher end but they make troubleshooting easier as well as give you confidence in their counting.
These last two features can be combined into one key feature that makes counting bills with a machine a breeze. Adding and batch counting modes. In a regular mode on a bill counting machine the counter will reset when you finish counting a stack, but if you enable adding mode the counter will continue to count from where the last stack left off.
Batching on the other hand is good for when you have a huge stack of bills like lets say $5's and you want them to be split into stacks of 10's. You can set the machine to batch count so it will stop counting after 10 bills have passed through. This is really good for if you are stacking bills into increments that are easy to count.
on Nov 14, 2013 • Retail Supplies
Aln key or screwdriver to release broken. needle brother overlocker
I think that it is a size #2 metric, about .75 cents at hardware store.
I've another fisher and paykel washing machine GM512. It has fault error of 1 and 7. How do I fix it?
What side are you counting from? Each light has a different value for the error code. Counting left to right will give a different error code than counting from right to left.
1helpful
How do I find out how many pages are on the current drum in my Brother 2820 machine
You must enter in maintenance mode:
Press the Menu/Set and Start keys. Next press the key four times to make the machine enter
the maintenance mode, or turn on the machine while pressing the menu/set key.
The machine beeps for approx. one second and displays "MAINTENANCE " on the LCD,
indicating that it is placed in the initial stage of the maintenance mode, a mode in which the
machine is ready to accept entry from the keys.
Display of the Equipment's Log Information (Function code 80)
Function
The equipment may display its log information on the LCD.
Operating Procedure
(1) Press the 8 and 0 keys in this order in the initial stage of the maintenance mode.
The USB serial number appears on the LCD.
(2) Press the Start key. Each time the Start key is pressed, one of the following log
information items appears on the LCD in the order given below.
1) Jam count, indicating how many times a paper jam has been occurred
2) Page count, indicating how many pages the photosensitive drum has been printed
3) Total page count, indicating how many pages the equipment has been printed since
produced
4) Drum count, indicating how many times the photosensitive drum has been rotated
5) Drum change count, indicating how many times drum replacement has been made
6) Toner change count, indicating how many times toner replacement has been made
7) Copy page count, indicating how many copies have been made
8) PC print page count, indicating how many pages the equipment has been printed as
an output device of the connected PC
9) FAX page count, indicating how many received FAX pages have been printed
10) Error code of the most recent machine error *1
11) Error code of the most recent communications error *2
12) ADF jam count, indicating how many times a document jam has been occurred
13) ADF page count, indicating how many documents have been fed
(3) To stop this operation and return to the equipment to the initial stage of the maintenance
mode, press the Stop/Exit key
To exit maintenance mode press 99
Not reading the games disc and when i put in a
This could be alnes problem or a system problem. Try to restore the PS3 first.
Turn off the ps3 then press and hold the powr button until it turns off again. Then do the same thing but this time it will make a beep, then it will make a double beep, and as soon as the ps3 makes a double beep release it. Its going to bring up a menu and make sure you press number 3 which is restoring file system. I would recommend going to this webpage which explains everything in better details http://www.ps3blog.co.za/2008/04/10/ps3-error-80010514-explained/
2helpful
Machine stopping mid cycle
Count the number of green flashes(1st number of error code). count number of red flashes(2nd number of error code).
Common codes are:
E10 or 11 water pressure faults.
E20 filter/pump faults.
E30 pressure switch/heater faults.
E40 door switch faults.
E50 motor faults.
E60 Heater faults.
These are some of the error codes but there are many variations on some codes depending on the model.Hpoe this has been some help.
2helpful
Lens error 10e,1,10- Kodak EasyShare M753
this is an hardware error. I'm sorry but you can't fix it by yourself. You've to contact kodak for a repair.
Tom Chichester
