Saws Logo
Corneshia Ward Posted on Mar 26, 2020
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why is a digital caliper held at a 45 degree angle
steve
Level 3:
  • Master 3,718 Answers
  • Posted on Mar 26, 2020
 steve
Master
Level 3:
Answers
3718
Questions
Helped
962542
Points
12533
Do you mean when using
5 Related Answers
Anonymous
  • 631 Answers
  • Posted on Jul 29, 2009
SOURCE: I cannot get a perfect 45 degree angle with my
When using the gauge on your saw it is off on the 45 degree cut? If so you might have to use a tri Square every time you want to cut a 45. Sometimes the lock gauge for the 45 angle may be off some. When you put a tri square on the board you cut it is not a true 45 even though the saw says it is?
Michial Gueffroy
  • 1140 Answers
  • Posted on Aug 06, 2009
SOURCE: I can not pedal back and the angle of the lower
Make sure your rear derailleur is lined up with one of the rings of teeth on your rear gears( cassette ). Also make sure Your chain is riding correctly on one of the front gears on your crank. If you are still unable to back pedal make sure that one of the cogs (gears) in the rear derailleur arm isn't seized. They must both be able to rotate and the chain should pass through them in a backward S pattern. If you still can't back pedal remove the back wheel or move the chain off the cassette to see if the cassette will freewheel. It has to move freely in a counterclockwise direction in order for you to backpedal. Moving in a clockwise direction engages pawls inside the cassette which lock it into a drive situation which propels the bike. If the cassette will not freewheel in a counterclockwise direction you will need to take the rear wheel to a good bicycle shop to have the cassette replaced. It requires a special tool to remove it. Hope this helps.
Anonymous
  • 287 Answers
  • Posted on Jan 04, 2010
SOURCE: Laptop screen only displays images if screen is
It seems like a LCD screen problem, contact ur dealer / service center for replace / repair! :(
Anonymous
  • 5 Answers
  • Posted on Mar 17, 2010
SOURCE: how to cut a 45 degree angle on wood using a jig
use a combination sliding square to mark ecxactly where you want to cut. Measure the distance from the jig-saw blade to the edge of the jig-saw bottom plate. Use this distance to mark another line parralel to the first line. Nail or screew a straight piece of wood on the second line. Put the jig-saw plate against the wood fence and cut your perfect line.
Anonymous
  • 710 Answers
  • Posted on Mar 27, 2011
SOURCE: looking for compound miter chart,
Check out amazon.com at this webaddress: http://www.amazon.com/Compound-Miter-Chart-Tables-Laminated/dp/B0002TY06O to buy charts and tables. Also, you can see a free chart at this site: http://www.woodcraftplans.com/compound_miter.htm
Hope this helps.
Handie Andie, woodworker by night
Why do a digital caliper held at 45 degree angle
https://prdros.en.made-in-china.com/product/kSCQLrTJVDUz/China-45-Degree-Vernier-Calipers-for-Angle-Measurement.html
Mar 26, 2020 • Saws
2answers
What angle do I cut a picture frame?
4 corners? Each corner is 90 degrees. Divide by 2 for the cut on each piece for 45 degrees.
Jan 17, 2020 • Saws
Dremel model 1695 scroll saw 45 degree cutting
Distinti gi? check in internet forum the online manuale?
Oct 04, 2018 • Dremel Saws
How do I miter with my radial arm saw (RA-2500). I can't tell from the manual.
the slide can be angled by the degree plate where the timber sits
the blade can be angled by the degree plate on the arm that mounts the saw
so you can get a 45 degree to the timber length and a 45 degree angle cut to that angle to give you a corner mitre cut
Jul 03, 2017 • Saws
3helpful
2answers
I want to know the torque opel corsa lite 1.4 cylinder head bolts.
Corsa 1.4i
Engine code Z14XE 2000-2004 Bolts must be replaced after removal.
stage 1. 25Nm
stage 2, +90 degrees
stage 3. +90 degrees
stage 4. +90 degrees
stage 5. +45 degrees
Engine code C14NZ 1993-1998
Stage 1. 25Nm
stage 2. +60 degrees
stage 3. +60 degrees
stage 4. +60 degrees
Compressor not starting, after it was moved/held at 45 degree on cart while reattaching water line. is there a reset
Good Afternoon Friend,
I understand that the compressor on your Frigidaire refrigerator, model# FRT18IL6DWL, will not start after having the appliance held at a 45 degree angle to reattach the water line. You can reset your appliance, by either unplugging it or shutting the power off at your homes circuit breaker, for 3-5 minutes. After restoring power, if the compressor is still not starting, I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your refrigerator and determine why the compressor is not coming on. Hope this is helpful.
-Best Regards-
WP
1helpful
Wen miter saw will not keep 45 degree angle
I found a wood working forum and I think that there is a discussion that may assist you with this issue: http://www.woodworking.com/forum/archive/index.php?t-4424.html
2answers
If an angle of a parallelogram is one- third of its adjacent angle, find the angle of the parallelogram
Since the two adjacent angles of a parallelogram must add to 180 degrees, the two angles have to be 45 and 135 degrees respectively.
1helpful
What is the reference angle of 225 degrees and 15'
The answer to this is 45 degrees and 15' i.e. forty five degrees and 15 minutes. Each degree is split into 60 minutes. So that 15' would be 15/60 degrees. that means 225 degrees and 15' is equal to 225.25 degrees. The reference angle is given by = 225.25 - 180 degrees which is equal to 45.25 degrees. This is in fact 45 degrees and 15'.
Please vote for the answer!
2answers
Finding the length of a triangle
might try
(54tan)/45
I don't have a calc that will do it or I would try it and see.
Top Saws Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Saw Expert? Answer questions, earn points and help others
