Question about In Office Equipment & Supplies
How I can fix Printer is in an Error State? - In Office Equipment & Supplies
Posted by Harry Bolt on
STEVE
    Top Expert:
  • In Master
  • 34,843 Answers
Find and read the manual for it
Posted on Mar 26, 2020
1 Related Answer
nirmal63637
Nim Petro
SOURCE: How to fix brother printer in error state error?
Check that Your printer is properly connected and there is ink in cartridge. Also Check for the paper jam. If every think fine and still its showing same error message read blog Printer in error state.
Posted on Oct 05, 2018
Oct 05, 2018 | Brother Office Equipment & Supplies
Updated to Windows 10, upgraded all drivers, printer is still in error state when printing
To help you troubleshoot the printer problem after upgrading to Windows 10 Operating System, please find the link given below and follow the instructions step-by-step:
http://windows.microsoft.com/en-us/windows-10/fix-printer-problems
If issue persists, it is recommended to contact your printer manufacturer for further for further help.
GuruAid.com
Apr 27, 2016 | Zebra Technologies 105SL 300dpi 4"...
Error 99.09.67 on a laser jet printer 600
Disk is not bootable please download firmware
Description
The product has a non-secure disk (solid state disk) installed as the boot disk, and it has been replaced
with a new service part.
Jul 14, 2014 | HEWLETT PACKARD - LASER JETS HP LaserJet...
When I turn on my canon ImagePress C1+ printer it stays in warmimng up state and never gets ready. what is wrong? how can I fix it?
when i turn my conon imagepress c1 printer it state and this error code come it e00001 - 001 what the problem and how can i fix it
Nov 17, 2013 | Canon Imagepress C1 Color Copier,...
Error 22
Go to hp website and look for firmware update. The model M1217 had the same issue which was fix in a firmware update.
Jun 07, 2012 | HP LaserJet Pro M1212nf MFP -...
My dell 5210 is showing a 920.16 Service Fuser Error. How I fix this/trouble shoot?
920 Fuser Error indicates the Fuser is below temperature while printing. The fuser, melts or fuses the toner to the media and has a heat roller and a pressure roller. The heated roller is heated by a halogen lamp or in some cases a solid state ceramic heating element and is subject to failure.
If this is the first time you have seen the error
    1. Power the printer off.
    2. Leave the printer powered off for 20 to 30 seconds.
    3. Power the printer back on. If it comes up to the Ready state, try printing again.
      • If the fuser error does not return, continue using the printer as normal but observe it closely over the next few days to see if the error returns.
      • If the fuser error returns on power-up or if the error returns as soon as you try to print or at a later date, the printer will probably require service to correct the issue.
  1. One thing that you can check as well (since it is a "under temperature" error), is to make sure the printer is not plugged in to a UPS/surge protector. The printer may not be getting enough electricity to heat up the fuser. Try plugin it in to directly to the wall/different outlet and see if the error persists.
If this does not correct it, you need to replace the fuser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Feb 01, 2011 | Office Equipment & Supplies
The traingle is flashing orange the rest not flashing. the printer does not print
In the Attention state, the Attention light is blinking and the Go and Ready lights are off. This state can be reached in the following circumstances:
● Paper tray is empty
● Door open
● Toner Cartridge Missing
● Paper jam/ Tray Misfeed
Pressing Go attempts to reset after a jam is cleared or is ignored in the other error cases. It may be necessary to clear the error manually and press Go or close the top cover. If the error still persists, the device will return to the Attention state.
Note
The LJ1010 product series does not have paper out sensors. When the printer is in an Attention state because the paper tray is empty, the user must reload paper and press Go.
Nov 13, 2009 | HP LaserJet 1010 Printer
Error 6
When I install the smart Label disk, I get this message.
An internal error has occurred. close all programs and restart the system. Error 6
Aug 05, 2009 | Seiko Smart Label Printer Pro Thermal
HP Laserjet 1320 Printer doesn't respond
Manual Feed or Continuable
Error
● Manual feed
● Out of paper for the
specified tray
● General continuable error
● Memory configuration error
● Personality/Job related
error
Solution
To recover from the error and
print whatever data is possible,
press the GO button.
If the recovery is successful,
the printer goes to the
Processing Data state and
completes the job.
If the recovery is unsuccessful,
the printer returns to the
Continuable Error state.
Feb 05, 2008 | HP LaserJet 1320 Printer
18 people viewed this question
Top In Office Equipment & Supplies Experts
Marvin
Marvin
Paul Carew
NatesGaga
Level 1 Expert
Are you an In Office Equipment and Supply Expert? Answer questions, earn points and help others
