Question about Kenwood Cell Phones
I have a Kenwood DNX6990HD and I can not get the bluetooth icon on the home screen, nor can I connect my phone
Posted by [email protected] on
johnson2333
    Problem Solver:
  • 14 Answers
Maybe you should check your screen whether it doesn't work.Once my Perodua had this kind of problem too.
Posted on Mar 26, 2020
1 Related Answer
otacon
Damen Wong
  • 1950 Answers
SOURCE: Tomtom GO 720 mobile phone connection
Have you used yout Tomtom with other phones before?
Posted on Apr 12, 2008
Cant connect to wifi because bluetooh is stuck running a prograhm
You can turn off BlueTooth by either going to Settings-->Bluetooth, or touching the BlueTooth icon in the Control Center (swipe bottom to center to bring up the Control Center).
Test your WiFi. If it doesn't work, double-click the Home button, locate the program BlueTooth is running, and swipe it to the top of the screen.
Test WiFi again. If it doesn't work, power down; wait 5 minutes; and power up your phone (if you don't see the white Apple icon when powering up, you did not power down properly).
If you need further help, reach me via phone at https://www.6ya.com/expert/john_77bb351c0c06b354
tip
How to turn Bluetooth on and off on a BlackBerry Tour
The BlackBerry Tour comes with Bluetooth capability, but in order to connect to a Bluetooth device, you have to enable the Bluetooth functionality. When you're not using a Bluetooth connection, disable Bluetooth to avoid other devices from connecting to your BlackBerry.
- To turn Bluetooth on:
From the main home screen, press the BlackBerry button (to the left of the trackball) to go to your Home folder. Scroll down until you see the antenna icon for Manage Connections and click on it. A pop up list will appear; find Bluetooth on the list and click it to put a check in the box next to it. "On" will appear next to Bluetooth, and the Bluetooth icon will be displayed in the upper right corner of the screen. Your BlackBerry is now in Bluetooth mode, where it can connect and pair with other Bluetooth-capable devices.
Bluetooth can also be turned on from the Options folder, under the Home folder. Select Bluetooth from the list and when the screen comes up saying "Bluetooth: Disabled," press the BlackBerry button and then select Enable Bluetooth. If you've previously paired your Tour with other Bluetooth devices, the list of those devices will appear.
- To turn Bluetooth off:
From the home screen, press the BlackBerry button. Scroll down to Manage Connections and select it. In the list that appears, click Bluetooth to uncheck it and disable Bluetooth functionality.
You can also turn Bluetooth off by clicking Options in the Home folder, selecting Bluetooth from the list of options, then pressing the BlackBerry button and choosing Disable Bluetooth.
Head unit wll not stay on
You either have a loose connection on your head unit or a fault with the unit take it to. Car audio store get them to connect it up on the bench if it stays on faults in your wiring.
Where is sync?
Pairing a Nokia Lumia 520 to a 2013 Ford Escape
1. To Find "Bluetooth" on the Nokia Lumia 520
  • Slide your finger left on the display.
  • Press Settings.
  • Press Bluetooth.
2. Turn on Bluetooth
  • Press the indicator next to "Status" to turn on Bluetooth.
3. Pair a Bluetooth device with your phone
  • Make sure the vehicle (parked in a driveway) is turned on and engine running. Go tot he Phone Menu, System Settings, Add Bluetooth Device, Push OK, The Sync System will display a 6-digit PIN number. Use the Seek Arrows to change to Special PIN (the system will display 0000), Push OK.
  • Your phone now searches for devices and after a moment, a list of Bluetooth devices within range is displayed.
  • Press the required Bluetooth device (the tab should say Sync).
  • Follow the instructions on the display to pair the Bluetooth device with your phone. Enter the 4-digit PIN
  • The new device is displayed on the list of paired devices.
  • Press OK on the console screen to set as Primary Phone, set 911 Assist and Download Phonebook. Be sure to check your phone screen and check "Always Connect" and Yes to approve the phonebook download. Be sure to check to see is there is also a request to Always Connect for SMS (texting) alerts.
4. Return to the home screen
  • Press the Home key to return to the home screen.
Your phone should now be paired the Sync system. Use the Voice button on the steering wheel to start the process (say "Phone"). Use the Phone icon to answer (a quick push) or hang up (push and hold down for about five seconds).
For more info www.fordtechlane.com Ford Tech Lane Driving you on the fastlane of vehicle technology
How do I pair Jawbone headset to Samsung Galaxy S phone
Follow these steps to pair your iOS device:
  1. Turn Bluetooth on (from the Bluetooth menu on your iOS device)
  2. Put your Jawbone device into pairing mode (click the link below to access instructions for your device)
  3. Wait for your iOS device to detect your Jawbone
  4. Tap the Jawbone device name in the Bluetooth menu to connect
1. To begin, access your iOS device's Bluetooth menu:
  • From the Home screen, tap Settings
    • Tap General (for iOS 5 or older)
    • Or tap Bluetooth (for iOS 6)
Oct 25, 2017 • Cell Phones
How to pair your phone to the bluetooth on th kenwood kvt-514
Go into your Setup menu and scroll down to bluetooth settings.
From here you should see a screen that says "HFP connect device", "A2DP connect device" and "Receiver pin code".
Press the "Set" button to the right side of "A2DP" and it should bring you to another screen that says Pair device.
Go onto your phone settings and make sure you have your bluetooth setting on your phone set to "make discoverable"
Press the search button on the Kenwood unit on the right side and it will start scanning for available devices in the vicinity
Also press the Search button on your phone so it also starts scanning.
Next you should get a message on both your phone that shows the Kvt-514 and also a message on the Kenwood that shows either the model of your phone or your "nickname" (if you named your phone)
Select the Kvt-514 on your phone and it will prompt you for the pin code that was on the first bluetooth setup screen...most likely 1111 (you can also set a different pin code using the "set" button to the right side of the "Receiver Pin Code" on the first bluetooth setup screen)
Enter the Pin code and select "Pair" on your phone.
You should get a confirmation on both the Kvt-514 and your phone that they are connected and you're good to go.
I have lost the bluetooth
The Bluetooth symbol on the bottom left of the screen will not show up unless the unit is linked with a compatible phone and Bluetooth is turned on. When the phone is not connected or the Bluetooth is turned off, you will not see this icon. The same thing goes for the Traffic icon. If you do not have an active traffic receiver connected, the Traffic icon will not show up either.
2helpful
I need to connect a new phone to my lexus 460ls bluetooth system
Go into the information /Nav Screen and you will find an icon for phone, then settings. Click on the icon and it it will give you a connect new phone option, click on that icon and it will release a 4 digit entry code and be findable by your phone.
Next go to your phones tools or connections settings and look for Bluetooth, enbale Bluetooth, Search Bluetooth Devices/handsfree Your phone will search out the car, once found it will request the 4 digit pin code to be input and ask you to confirm "handfsree" Once confirmed the car will read out connecting...then bluetooth connection successful and the dial pad will appear on the NAV screen
If you have more than one phone connected to the car the driver will need to select the connect phone button in order to chose the phone he wishes to enable
How do i set up my bluetooth for my kenwood kvt-512. im trying to find the bluetooth app in the settings
The Kenwood 512 works with the Kenwood KCE-BT200 module. You need to have this box plugged into the main unit to work. If not, then Bluetooth will not be available. When you do have it connected, use your cellular phone to initiate the connection. when prompted on your phone for a passcode, it will be 0000. After successfully pairing your phone to the unit, you can access the telephone menu by holding the "FNC" key on the front of the Kenwood or pressing "TEL" from the source screen.
Cell Phones Logo
Top Kenwood Cell Phones Experts
ADMIN Canada
ADMIN Canada
Are you a Kenwood Cell Phone Expert? Answer questions, earn points and help others
