Question about Sharp Televison & Video
Sharp aquos LC-32CFE6242E not turning up. - Sharp Televison & Video
Posted by Regis Castellonese on
Attique-ur-Rehman
    Top Expert:
  • Sharp Master
  • 2,677 Answers
Https://www.youtube.com/watch?v=yYZP8XTUNgw
manual
https://www.libble.eu/sharp-lc-32cfe6242e/online-manual-768917/?page=0009
Posted on Mar 26, 2020
Testimonial: "Hi, thanks for the links. It doesn't work for me, TV doesn't turn up. Regards,"
5 Related Answers
Anonymous
SOURCE: LC-37D62U Sharp Aquos HDTV Settings
lost sound on Sharp Aquos 37LCD62U
Posted on Jan 25, 2008
Anonymous
SOURCE: Sharp Aquos LC 37HV4U - problems with AVC
I have a fully functioning lc37hv4u box & cable that I will sell for 200$ my lcd got cracked. let me know [email protected]
Posted on Aug 01, 2008
ginko
Ginko
  • 19396 Answers
SOURCE: LC-37AF3X Sharp Aquos KCD TV
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Posted on May 05, 2009
Anonymous
  • 405 Answers
SOURCE: Sharp Aquos LC-3237U keeps turning off what could
Check if the power menegment is enabled. Go menu> power control ind see if NO OPERATION OFF is enabled.
Posted on Nov 06, 2009
Anonymous
SOURCE: I need the 4 digit remote code for a Sharp Aquos
Try 0093 mate.....
Rgds,
Nik..
Posted on Jul 24, 2010
No sound on my sharp aquos lc-45gd4u 45 in
Assuming you are using the internal speakers, check and make sure you have the audio enabled. Some TV sets have a option to turn off the internal speakers. Also make sure mute isn't turned on. If you are using external audio setup, double check your connections.
8helpful
2answers
My sharp aquos has low volume
my sharp aquos flat screen has a low volume, even when turned up to max. how can i increase the volume
1helpful
Sharp aquos lc-52se94u green screen
If it it new, take it back. The product is not working properly.
23helpful
2answers
Sharp Aquos LC-32GD8E-picture goes off at random, sometimes switching it off and on again solves the probelm, sometimes not
I had the same problem with the Sharp Acquos LC-32GD8E. A repair man was able to fix this by opening up the back cover and tightening the metal (ground) shield. the screws seem to have come lose. If I had known this I would have done it myself!
3answers
Sharp Aquos LC-37GD6U 37 in. HDTV LCD.
I've had this problem with my Aquos. I had Sharp send out a tech. and they upgraded the firmware on the motherbd. to version 1.04 (main and monitor) and this took care of the problem
8helpful
Red Blinking Power Light Sharp Aquos
What do three blinks of the power light mean on my Sharp Aquos LC-C5262U? I cannot power up my display.
2answers
Televison & Video Logo
Top Sharp Televison & Video Experts
 Grubhead
Grubhead
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
