Serger Help
https://www.singer.com/sewing-resources/winding-a-bobbin-alt
Machine will not pick up bobbin thread. ... - Your thread could be caught on something between the needle and your spool of thread if so, your thread will be too tight for the needle to pick up the bobbin thread. - Make sure that the upper thread is threaded properly. - Re-thread your machine, if necessary.
https://help.brother-usa.com/app/answers/detail/a_id/76369/~/machine-will-not-pick-up-bobbin-thread
SOURCE: Hi I'm trying to get some new bobbins for my
The bobbins are generally interchangeable between singer models.
You have to watch out for the bobbin case though as this is the one specific to model families.
Hope this helps.
SOURCE: Singer/merritt 2430 bobbin fill
If you lift up the thread holder, the bobbin holder is inside. Loosen the hand guide to stop the needle from going up and down. Pull the thread around the top thread guide and back into the bobbin holder. Thread the bobbin and move the bobbin over so the guage is "inside" the bobbin. As for the manual, the Singer Merritt 2404 is applicable to the 2430 if that helps.
SOURCE: bobbin case futura singer sewing machine came out
The opening fits on the right side, toward back. There is the silver ring with the slot in it for the bobbin. That slot is facing the sewer.
SOURCE: The bobbin tension too tight on my Singer Quantum 9240.
I am having this problem also; the thread catches in the **** in the bobbin. I am thinking maybe I am not threading the machine correctly--the bobbin area, not the top thread. I will try this & see if it fixes the problem. You may be doing the same as I am.
