Question about Hisense Televison & Video
Im trying to scan channels on my 2016 hisense tv without remote control it wont go to scan channels only change input
Posted by Letha Randle on
Sampson
    Habit-Forming:
  • 91 Answers
If you have a smart phone you can download a remote app to use instead of the original remote. Then you could go ahead and scan the channels after setting up the app.
Posted on Mar 27, 2020
5 Related Answers
Paul
  • 224 Answers
SOURCE: INPUT GOING CRAZY
It could well be the accumulation of dirt/dust behind the buttons causing them to stick. If you are able to carefully remove the board that the buttons are located on and use a cleaner that will de-grease at the same time. Be sure that everything is dry as can be before re-assembling and then check if the problem persists. If you are not capable of doing this trust a competant technician. Hope this helps.
Posted on Oct 01, 2008
ShadeTek
ShadeTek
  • 81 Answers
SOURCE: Can't change our Panasonic TV channel to watch DVD input
Buy a 21 way scart.This will have an 'AV' enable connection built in. After fitting, turn on the TV, then turn on the DVD player. It will automatically enable the DVD through the scart socket.
Posted on Nov 10, 2008
John Morganti
  • 864 Answers
SOURCE: input channel with no remote
You should be able to select the AV input with an Input or Menu button on the front of the TV.  If there are no arrow keys the Channel and Volume buttons may provide up-down-left-right action.
Posted on May 28, 2009
barbu51
Jacques Marin
  • 566 Answers
SOURCE: change input without remote. can be done on tv?
If you don`t have input selector on the set or in the menu you might be able to get it with the channel buttons, that would be right below channel 2 or above 125
Posted on Oct 31, 2009
Anonymous
  • 5 Answers
SOURCE: lost remote control for an emerson tv. how do you
I just purchased one of these televisions and it didn't come with a remote. However, a Philips Universal Remote (SRU2103/27)
with a code 0520 works fine. I haven't explored all the codes but I can easily change from tv stations to Video 1 and Video 2 merely by pressing the "Input" button on the remote.
Posted on Dec 08, 2009
Hisense TV model #40H5 won't respond to remote or buttons on TV.Ive tried changing Input,channel,adjusting volume & turning TV off.
Check the remote control for its infrared emission. Check it with fresh batteries. Check it by pressing all the keys. You can detect the presence of infra-red emission from the remote control, using a cell-phone camera. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. In some cases, the remote control might need to clean.
http://remotesearch.blogspot.com/
Search the site by type in this key phrase "how to test a remote control "in the "search box at the top right of the display window of the Homepage" to get the related post quickly.
https://youtu.be/wUpnETSm6_k
https://www.youtube.com/watch?v=jsSCNCW3IbQ [open and clean]
https://www.youtube.com/watch?v=Qp-l1uh-5gE [open and clean]
Im trying to set up an RCA antenna on my Hisense TV and can't get the channel scan feature to come up. What do i do?
Are you on a t.v channel or an input? Many t.vs won't access channel scan if you have one of the inputs currently selected. Once on a channel activate the channel search feature
MY HISENSE TV IS NOTT RESPONDING TO THE REMOTE CONTROL COMMANDS ALTHOUGH THE REMOTE IS BLINKING. MY REMOTE SERIES IS EN-31603 (IT CAME WITH THE LCD 32' HISENSE TV)
I have the same problem, NOTHING to do with batteries.BUT if you press the that blinking (red) button and hold it down and THEN press the option you want (channel +/-, volume +/- etc) the controls work. Im looking for an answer aswell to return it to its previous state where I dont have to do that!
I dont have the remote and im trying to put on cable or channel 3 but the settings on the tv wont allow me to do that
go to cable input, go up one channel, if that won't work, scan for channels but make sure your cable box is on
2answers
How do u change av on tv withoute remote
Directly on the TV there should be a button marked AV/Source/Input. That would be the button to press till you reach the desired input.
Thanks
Dustin
Getting a specific channel on the TV without using a remote
Usually if you go into the setup menu, there is an option to allow you to either "scan" for a channel, or "input" a channel. In this case, select "input" and see if the TV will allow you to press the up and down channel buttons and go to a specific channel. If so, when you get to channel 4, press the "add this channel" option (or whatever the menu option says) and you should then be able to go to channel 4 using the buttons on the front without skipping over it.
1helpful
2answers
2answers
Remote problem Hisense
I GOT A NEW HD WIDESCREEM POLAROID. DIRECTTV CONTROL PUTS ON POWER ON TV,CHANGES CHANNELS BUT DOES NOT CONTROL VOLUME NOR CONTROL DVD ANDVCR PLEASE HELP GODWIN
Loss of sound
you can try changing the assigned channel.you should have to put the second T V on a certain channel like channel 72 or 68 or something like that.on the main reveiver you should go into the menu and poke around in the setting until you see a REMOTE ADDRESS option walk through the steps and change the channel that the second TV receives its picture on, you should shoot for channel 62-72.also make sure the hisense is set to a cable input.you can go into the menu on the hisense and go to your settings and change this .it will be on CABLE or ANTENNA.try switching those around.also did you have sound before coming out of the coax output on the hisense? if your not sure then plug a vcr into and make sure the TV is working with different equipment.GOOD LUCK!
Televison & Video Logo
Top Hisense Televison & Video Experts
Jean Sintulaire
Kolbrun...
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
