Https://www.youtube.com/watch?v=-Z1ZAQxPucw
https://www.youtube.com/watch?v=p14EEa4AYGM
SOURCE: oven door locks and un locks code F90
The F90 fault indicates that the maximum time allowed for oven door unlock was exceeded. The control attempted to unlock the door. The door lock motor or mechanism failed to unlock the door within the maximum amount of time it is allowed to be energized by the control board.
It is unlikely that you will be able to reset this fault code. You can try to completely disconnect electrical power and leave it off for 5 minutes. After reconnecting power, the fault code will probably reappear since the control will still detect that the oven door is locked. The only way to clear the fault code is to disassemble the range and repair or reset the oven door lock assembly. You will need a service technician to complete this repair.
SOURCE: Frigidaire washing macine ATF6000ES1 error code E47
Hi I have the same problem, Error Code 47. I went to the support page and only found manuals and the tech data sheet. Which one shows you how to get to the front door lock? Thank you
SOURCE: Getting DL F - door
remove the bottom panel reach up on the right side you will see a small white loop pull this down and your door will open dlf usually refers to you haveing to replace the door lock assembly you can find your part at www.marcone.com under contact us there is a 1800 number and they mail directly to your door anywhere in the world if you have any further questions message me back and please remember to rank how this opinion has helped it helps so that i may be able to help people with similar situations in the future Thanks again Rick
