Have Cuisinart SCO-60 can opener. Motor runs but feed gear does not move. Removed 4 bottom screws. How to remove cover to looks at internal components?
Posted by Brian Smith on
Attique-ur-Rehman
    Top Expert:
  • Office Equip... Master
  • 2,677 Answers
Https://www.google.com/search?source=hp&ei=uvR9XraLNcKOlwSMjZfYCA&q=Have+Cuisinart+SCO-60+can+opener.+Motor+runs+but+feed+gear+does+not+move.+Removed+4+bottom+screws.+How+to+remove+cover+to+looks+at+internal+components%3F&oq=Have+Cuisinart+SCO-60+can+opener.+Motor+runs+but+feed+gear+does+not+move.+Removed+4+bottom+screws.+How+to+remove+cover+to+looks+at+internal+components%3F&gs_l=psy-ab.3..0i362i308i154i357l6.1781.1781..3048...0.0..0.206.206.2-1......1....2j1..gws-wiz.....6.1Ijux5-GPqU&ved=0ahUKEwi20KH81rroAhVCx4UKHYzGBYsQ4dUDCAU&uact=5#kpvalbx=___d9Xv7AJJC5gwe1mpCwCw32
Posted on Mar 27, 2020
5 Related Answers
Anonymous
SOURCE: mp600 pixma printer
I'm not sure if you've already checked this, but this was my issue. I, too, would try to print something and it would make a great deal of clunking noise but would then say that there was no paper and told me to load some. I went to the Canon site and before I actually went through the process of cleaning the print roller, I checked the feed switch button on the display panel. It's right below the ON/OFF button and, what do you know, it was set to feed from a paper cassette instead of the back loading tray. I pushed the button and it's now printing fine. I'm sure we must have accidentally hit the button when we were trying to turn the printer on or off quickly. Hope this does the trick! It's always nice when it's something easily fixed!
Posted on Sep 07, 2008
jyackle5
Jyackle5
  • 8197 Answers
SOURCE: breville juicer mod: JE95XL does
Remove the rubber legs to get to the screws onder them
Posted on Dec 26, 2008
Anonymous
  • 7 Answers
SOURCE: Cuisinart DCC-1200 Coffee on/off switch
To remove the faceplate:
You will need a tiny standardscrewdriver (I used one from an eyeglass repair kit) and a smallishphilips screwdriver. Begin by removing the carafe, the basket (andpermanent filter, if you have one), the water filter, and the inserton the underside of the flip-up lid. With the lid open, you willnotice two round screw covers towards the front of the coffeemaker toeither side of the filter basket. Remove these with the smallstandard screwdriver. This is impossible to do without damaging themsomewhat. Remove the two philips screws underneath .
There are nine clips that need to bereleased to remove the plastic top of your coffee maker. First, pressin on and release the two located on the back just below the lidhinge. With the small standard screwdriver, gently release the sixclips along the top edge of the casing. These are located two inback, near the corners and two along each side. You will have to getup underneath the plastic bezel, be gentle so that you do not bendthe stainless steel housing (if you do, gently bend it back intoplace before you put everything back together). Lay the coffeemakeron its back. The final clip is located in the carafe “nook” tothe back of the drip outlet. The upper plastic portion should nowlift straight up out of the coffeemaker.
With the coffeemaker upright, removethe four philips screws holding the faceplate in place. Remove thefaceplate by pulling it straight out towards you.
Posted on Nov 22, 2009
Anonymous
SOURCE: I am having trouble removing
If you lift your treadmill deck up, you will find 2 screws underneath, on the side, towards the front. remove them and that should do the trick.
Posted on Jan 03, 2011
Anonymous
SOURCE: I have a Lane Dead
Hi Glen, just wondering if you were able to resolve your problem? I have a similar Lane deadlock & am struggling to remove it. If you are still around on this website ... would appreciate any help/pointers!
Cheers,
Uday
Posted on Oct 02, 2011
1helpful
I have a 2008 grizzly 700 and it won't drive (move) in 2wd. I only can drive in 4 wheel drive. Any thoughts on how to diagnose what the problem could be? Please help
This is the electric motor inside your servo that actuates your 4wd/2wd/diff locker. When the servo goes out on these bikes, it's more than likely the small electric motor. Simply pull the servo off the front differential, open it up and you will see the small motor inside. I pulled the complete diff out in the instructions due to having to change a seal but you can do this with it still in the bike.
If you have a skid plate on you will have to remove it to access the bottom bolt on the servo. I also recommend having the bike in 2wd to ease in installing the servo back on the diff.
Remove the 3 bolts that hold the servo on the diff. Gear oil is going to pour out unless you drain it first.
Soory last pic 5
26147106-wuoh52pvdxpwqpeytk4hf153-3-0.jpg Once removed installation is the opposite. Just be sure not to turn anything inside the casing once you open it. The small worm gear on the motor doesn't matter just don't turn anything else.
Install back on the bike fill with gear oil and enjoy your 4wd and the money you saved.
pic 1
pic 2
26147106-wuoh52pvdxpwqpeytk4hf153-3-5.jpg Once the servo is removed from the diff. Remove the six T-25 tamper resistant tq screws that hold the servo together.
Once you get the screws out, carefully pry the servo apart taking extra care not to turn the gears inside.
Once apart it will look like this.
pic 3
26147106-wuoh52pvdxpwqpeytk4hf153-3-9.jpg You can see the two screws that hold the little motor in.
pic 4
Remove those two screws and carefully pry up on the motor and remove it and the small gear attached to the end of it.
Picture of the motor removed.
I need advise how to remove the machines cover and get access to the driving belt. Alternatively please give me the link for a service/repair manual
There are three exposed screws on the bottom of the machine that can be removed with a Phillips screwdriver. You also need to remove two of the four rubber feet with a Phillips screwdriver. The other two rubber feet also need to be removed, but they have some kind of specialty screw that needs a split-head screwdriver. I just removed them by twisting the entire foot with a pair of pliers. Then the panel pops off fairly easily, and there's the belt. As an aside, the drive belt on mine kept coming off, and just putting it back on didn't help because it would just fall off again. It turned out that the whole bottom of the machine was bent, so the motor gear wasn't lining up with the drive gear. Not sure if this is fixable.
1helpful
Take apart cuisinart sco-60
there are screws on the bottum, and snap locks that make it tricky to take apart, you almost have to break it to get it apart.
White quilters star 1780 is running slow, how do I fix it? Have already cleaned feed dog and shuttle, what else can I do?
You can send out to repair to have it lubricated & oiled, or you can do this yourself. Not recommended though if you have pets or kids where you are working on machine. Remove needle, thread, bobbin. There are screws underneath. Don't lose them! One drop good quality oil on moving parts so lay machine back on a towel, remove screws, keep foot pedal up on table so you don't accidentally hot it with your foot. All gears that are not greasy get a very small dollop of lubricant (Singer makes a good one comes in red &white tube). All parts moving get the oe drop oil. Put plate back on, firmly tighten screws. Never lube or oil plastic parts! A drop of oil any metal screw located on top of machine. Lift machine up and if tip can be removed, you can check moving parts needing oil there and replace lid. If front section opens--left of needle bar--open it up and oil moving parts..I usually just apply one drop oil to TOP of needle bar Close lid. Put one drop oil on shuttle hook bottom left. Never oil tension discs. Run machine with scrap of fabric to get her nice and smooth sailing. If motor sounds like it's running heavy after that, take in for service, but unless motor needs replacement, you should see noticeable improvement immediately. Good luck and hope this helps! Jimmy Remove screws on top
When turned on gear 1 mixer lately slipped to gear 2 immediately. I took back cover off and cleaned everything out by lifting the electrical element (?) and after mounting everything back on the mixer does...
You need to adjust the mixer speeds. Obtain a copy of the KSM5 Repair Part List from Kitchenaid.com. Remove the screw holding the End Cover and locate the three screws from the Control Plate. All three (2 top left and right, and 1 bottom) must all be adjusted. 1. Loosen the lock nuts enough & Turn the 2 top screws clockwise until they cannot be turned
anymore. Leave the bottom screw alone for now.
2. Use a dab of white paint or paper whiteout to mark the positions of the Phillips screws.
3. Plug in your mixer and Set the speed selector to "Stir".
4. Turn each top screw One full turn couterclockwise (alternating between Left and Right)
Keep making one full turn at the time (for both left and right) until the motor starts running.
5. Put your hand near the Agitator shaft and allow it to brush your finger slightly. Use your
watch or clock and start counting the number of times the shaft touches your finger in
60 seconds. The correct count should be 60 RPM (Rounds Per Minute). If it is less
or more than 60, give each screw 1/4 turn counterclockwise or clockwise and start counting
again. Now tighten both lock nuts.
6. Set the speed selector to "6" and turn the bottom screw either clockwise or counterclockwise
to achieve a speed of 180 RPM.
For your reference, the planetary RPM's for the 5-qt. tilt-head Artisan Stand Mixer are as follows:
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 2
Hoover empower belt need replace
To gain access to the belt: remove 2 screws at the top rear cover, next remove 2 screws at the bottom front cover. This will allow the cover to be removed. Then remove 3 or 4 screws that hold the roller in place (from the top). you will be able to see the belt and replace it.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Apr 18, 2010 • Vacuums
58helpful
3answers
Broken Cuisinart SCO-60 Deluxe Stainless Steel Can opener
Take a look for replacement parts on amazon.... here Amazon com cuisinart sco 60 deluxe stainless steel. I hope this was helpful. cheers
3helpful
3answers
Chamberlain Power Drive 1/2 HP - motor runs but does not move chain
I have the same problem. I just removed the cover and discovered a nylon gear had been worn out. I found lots of shavings inside the cover. The nylon gear is beneath the exterior chain gear. I am looking for information on how to replace it, if I can find the part. If you decide to look at yours, unplug the power and remove the sheet metal screws securing the bottom portion of the cener cover to the front and back covers. Then just remove the upper screws from the center cover. Good luck.
6helpful
2answers
Cuisinart CBT-500 blender won't work
(0) unplug unit (1) Remove the bottom 4 screws, cover plate and motor shield ( 2) unhook the white motor wire from its binding clip ( 3) locate the plastic sleeve with the fuseable link (4) cut the sleeve and test for continuity between points on either side of link with ohmmeter (5) if no continuity, clip out fuseable link and and solder the white wire back together (6) cover with tape (7) rebind to other wires (8) replace bottom and check. This worked for me.
Tom Chichester
