Question about Generac Electrical Supplies
Generac XG10000E - wont crank. No sound at all. Battery is fine.
Posted by Steven on
Carl Rock
  • Generac Master
  • 3,215 Answers
See following link
https://www.generac.com/service-support/product-support-lookup
Check fuse and connections between start switch, control board, and starter solenoid.
ENGINE CONTROLLER CIRCUIT BOARD
GENERAL:
The engine controller board is responsible for crank-
ing, startup, running and shutdown operations. The
board interconnects with other components of the DC
control system to turn them on and off at the proper
times. It is powered by fused 12 VDC power from the
Posted on Mar 26, 2020
1helpful
2answers
My generac generator wont start,making a clicking noise and battery is fully charged
Have somone hold the start button while you measure the voltage across the battery. If it is less than 11 volts, then the battery is bad.
Over crank
Over crank is just that, cranking and cranking for a timed period without a run signal. Make sure the fuel solenoid is opening and you have the correct gas pressure. Too much pressure can stop it opening. Then check you have a spark at the plugs, this will eliminate ignition, and you can re-focus on the fuel system. You didn't say it was LP or Nat gas
Generac xg10000e won't start
Very annoying is the word. In order for many on todays small engines to pass EPA regulations, the carburetor is set very lean. This makes them very hard to get started and warmed up. Once warm, most will run OK .
Try choking a little 'til it is warmed up and running smoothly. Some have an adjustable main jet that can be opened a little to overcome this problem.
Some are not adjustable and some have a small plastic cap over the adjusting screw. The plastic cap is supposed to be a tamper proof thing.
If you still have trouble take it to the local small engine man. I am sure he has the cure or marbe he can adjust under warranty.
Hope this helps. Robert
Generac NP 50G wont crank
Measure voltage drop across the far ends of the fuse wiring (should measure zero), as one of the wires or it's connection to either end of the fuse may be open. Check the battery negative grounding connection at the frame. If all ok, you may need to find a wiring diagram for the machine. Does this unit have a low-oil-level switch which will kill the engine if set?
Electrical Supplies Logo
Top Generac Electrical Supplies Experts
Sheldon Dedek
Fahr Quad
Dennis Boxerman
Are you a Generac Electrical Supply Expert? Answer questions, earn points and help others
