Question about LG Televison & Video
LG TV Plasma 60PZ550-UA.. no picture, no sound... what causes these problems?
Posted by Cristian Cristianson on
JOhn Papi
I think the internal parts of the stereo and the display are broken i suggest getting a new tv
Posted on Mar 26, 2020
5 Related Answers
Anonymous
  • 15 Answers
SOURCE: 42 inch LG Plasma TV - Lost picture
ysus pcb that supplies voltage to the panel is faulty
Posted on Dec 15, 2007
Anonymous
  • 3 Answers
Our LG 50" plasma tv screen went black after a popping noise but still had sound, after great diliberations decided to take the back off and have a peek!
We unplugged the tv and tested the fuses (there were three we could see) one had blown, the one on the left as you look at the back of the tv it also has one above it. We wrote the code/seriel number down and took the fuse to the electrical wholesalers Maplin and bought a pack of 10 fuses for £1.29 replaced the fuse in the tv and everything now fine!!!!!!
Hope this might be of use to anyone whose lost the picture after a loud popping/snacking noise but still has sound.
Posted on Jan 17, 2008
Anonymous
SOURCE: Sound but no image on my LG Plasma TV
Have sound but no imagen
Posted on Sep 30, 2008
Anonymous
  • 13 Answers
SOURCE: LG Plasma has sound but no picture
Hi James,
This could be one of two problems. I can't narrow it down any further without having the set in front of me.
1. The plasma panel or the componets which supply electricity to the plasma in the panel have packed up.
2. The video processing unit in the set has gone.
As for the cost of repair, if it's the panel, buy a new TV. It'll be cheaper. If it's the component that supplies the electricity to the plasma on the panel or the video processing unit, expect to pay between 300-400 as a conservative estimate for parts. Labour would be another 100-200.
Hope this helps
Posted on Apr 28, 2009
David Low
  • 458 Answers
SOURCE: 42" LG Plasma tv, no picture - black screen, but have sound.
Most a likely a problem with your Y-Sustain board which will then not drive the screen giving a black picture. The fuse on the board may be open circuit & need replaced but most likely you will need to have the sustain board replaced.
Posted on Oct 28, 2009
Are there any universal board in my LG plasma TV .model 60PZ550
No. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
LG TV 60PZ550 black screen no pic or sound green lit flashing it has back lite
LG 60PZ550 Plasma - No Sound, No Picture - Badcaps Forums ...
www.badcaps.net > ... > Troubleshooting TVs and Video Sources
Sep 15, 2013 - 20 posts - ‎4 authors
LG 60PZ550 Plasma - No Sound, No Picture Troubleshooting TVs and Video Sources. ... I see no change in the screen at any point (no glow). With the rear cover ... I've worked with some electronics in the past, but am new to TV's. I'm sure .... Multimeter on DC 1000V, red on (+) marked, black on (-) marked. Lg 3d plasma 60pz550 i've got sound but no picture
Jul 18, 2014
LG 60PZ550 color issue - Badcaps Forums
Jun 9, 2014
Purple/Pink Lines / Postering on plasma LG 60PZ550
May 29, 2014
LG Plasma 60pz550 has strange greenish rainbow ...
Jan 20, 2014
More results from www.badcaps.net
The vol, input and other functions won't work it's not the remote
If you are using a remote other than the LG remote that came with the TV it could be an improper code setting. Most TVs have up to 10 or 15 codes to match the remote to the TV. Some codes will work for some functions, but not all.
What are symptoms of defective z sustain board?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to both LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent.
LG 60PZ550 has discoloration and distortion across screen worse with light colors
A strange fault you denotes here indeed. Haven't came across this type of fault with Plasma TV. I suggest you to contact the authorized service center for LG. Never do anything to it. Gopakumar Gopalan Google
Strange rainbow.reenish type effect
Did you notice any better picture when you play a movie on a DVD player or using a flashdrive on this TV? Is the picture quality better? Or is it the same? Try to check another cable connection or try to play TV channel thru internet. The last option in this case is to show a TV mechanic for he would better understand which part to order.
4helpful
2answers
LG "NO PICTURE" , IF FIX WILL RECUR? ,DID LG FIX DESIGN FLAW 42PC3D
I had same problem - no picture, but sound worked - LG 42PC3d - was two months past warranty, but LG agreed to fix it as a warranty call. Service guy was out within a week to replace the Z SUS(?) board. Works fine now. This must be a typical problem, as LG did fix it, even though the warranty had expired. Good luck.
Televison & Video Logo
Kolbrun...
