Question about LG Televison & Video
Our 60 inch Lg 60pv250-tb fell off a wall mount.
Our 60 inch Lg 60pv250-tb fell off a wall mount. Now it runs for anywhere between half hour to an hr and shuts off. When turned back on it can run for 20mins or 1 min. I was wondering if you think it could be one of my boards. I will buy what I need through you but just to let you know I live in Australia. Any help is greatly appreciated. Even if I need to replace 2 boards. Thanks heaps. Regards Barbra.
Posted by Barbra Woods on
Andrew Taylor
    Top Expert:
  • LG Master
  • 31,451 Answers
That's why wall mounts have security screws to hold the television frame to the wall frame hooks.
Take the back off and see if there are any cooling fans that have been dislodged, or boards that have moved. Anything else, take it to a repairer. Oh yes, and FIXYA dot com does no sales. We only supply information. Do NOT try and fix it yourself, history here shows that never works.
Posted on Mar 25, 2020
5 Related Answers
Anonymous
SOURCE: troubleshooting reddy heater 115,000btu
runs for awhile shuts down with a big puff of smoke comes out poured diesel 911 thought i had water in diesel fuel cans nothing help need solution ASAP
Posted on Jan 18, 2009
Anonymous
SOURCE: mitsubishi WD-62827---PICTURE TURNS GREEN
I had the same problem. I deducted that if my TV worked fine for an hour or so and then the colors became bad (green, people's faces purple...), it must be a overheating problem. Simple logic, right? So, I picked up a few tools and a small vaccum and went to work.
I went first for the main source of heat: The lamp. Just a few screws, and I removed it. The lamp cage has a fine screen to prevent the dust to cover the lamp. Mine was covered with dust! And the fan behind the lamp was also covered with dust! Bingo!!! That's my problem! I cleaned everything and vaccumed all the air vents on the the back of the TV. I put the lamp back and checked that the fan was working. The TV works like new since!
Before you are out of a TV for days and spend an arm and a leg for a "Technician" to fix it (replacing expensive parts that didn't need to be replaced in the first place), try what I described above first. It's very simple and it takes only 15 minutes.
Since my TV is 2 1/2 years old, I purchased a replacement lamp. I know that one of these days it will burn out. I'll be ready and my TV will be working again in 15 minutes!
Since my problem was solved, I didn't go to the next step. There must be one or two other cooling fans inside the TV, but they must be working...
Good luck,
[email protected]
Posted on Jan 25, 2009
Testimonial: "YES IT IS A HEAT ISSUE(IF YOU HAVING GREEN SCREEN ISSUES LEAVE THE BACK COVER OFF AND PUT A SMALL FAN BLOWING IN THE LIGHTBULB AREA.PROBLEM SOLVED"
Anonymous
  • 41 Answers
SOURCE: WESTERN DIGITAL 1 TB HARD DRIVE WON'T MOUNT
1. Assuming you have tried different cables.
2. Assuming that you are trying different ports (different usb) on your computer or even different computers.
This eleminates your computer and isolates your drive. These are know problems with the WD drives. Sometimes you get a bad drive. It happens. WD offers full support for their drives. Esp. new ones.
This website tells you if the noise you hear is normal. Also, most of these drives are under warrenty for at least a year.
ttp://wdc.custhelp.com/cgi-bin/wdc.cfg/php/enduser/std_adp.php?p_faqid=568&p_created=1033495201&p_sid=LaetSItj&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MzUsMzUmcF9wcm9kcz0mcF9jYXRzPSZwX3B2PSZwX2N2PSZwX3BhZ2U9MSZwX3NlYXJjaF90ZXh0PU5vdCBtb3VudGluZw**&p_li=&p_topview=1
Posted on Mar 26, 2009
emissionwiz
Marvin
  • 85223 Answers
SOURCE: car starts run's 3 seconds shuts down
Your car is equipped with a system called PASSKEY standard on all GM cars and light trucks, try the following procedure to reset the system, the battery being dead will trigger the system.
PASSKEY LOCKOUT RESET GM CARS 1999 UP
1) Put the key in the ignition and turn to the "ON" position. Leave it that way for 10 minutes. After 10 minutes turn the key and take it out. Repeat this process (2) more times (3 times, 30 minutes total) This should reset the passlock system to recognize your key.
Posted on Mar 30, 2009
Macmarkus
Mark MacDonald
  • 2605 Answers
SOURCE: My Bosch dishwasher SHU43C02UC/38 runs the quick
The issue with your Bosch dishwasher likely lye`s within`the electronic timer/control, specifically the heater relay solder joint. ( a faulty flow switch, ntc or heater can also cause this, but not very probable ). This is the purpose of the "1" indicated in the display, a heating problem.
I`d first suggest calling in an authorized bosch servicer, however If you feel capable there`s a way to visually inspect the control. It will require you to remove the control from the unit and then remove the control from it`s plastic housing and look for a burnt solder contact on the printed circuit board. This will be one of the pins from the heater relay, hence the unit sit`s at "1" ( because it can`t heat to advance or until canceled ) trying to heat the water.
**Further to this, if you or someone you know is proficient at soldering, a lot of times it can be remedied by simply repairing the solder...although Bosch recommend`s replacing the control and I don`t pretend to speak on there behalf nor do I profess to know better. This is just my experience (it work`s) and my opinion (why buy new if one can repair ?)**
**Please disconnect the power before attempting any service to the dishwasher. If you do not feel comfortable attempting this service, call a local pro, preferably one familiar with Bosch/Thermador/Gaggenau, to service your machine.**
Hope this answer`s your question, let me know if I can assist you further. Thank`s for visiting "fixya" for your repair inquiries. Please take a moment and rate this solution and leave a testimony.
Good luck.
macmarkus :)
Posted on Mar 12, 2010
Testimonial: "Thanks so much for the help - it was right on. "
My TV doesn't have picture its fuzzy in different areas not the whole screen and makes with clicking noise when its turning on.
Invariably the HDMI cable that you are using to connect the signal is bent and pressing hard against the wall. Can you verify with other ports and other sources.
Feb 06, 2016 | LG 60PV250 60 in. Plasma HDTV
How do I wake a sleeping hard-drive on my pc
possible hard drive failure, try shutting machine on and off consecutively 10 times, to get running.
good luck
Jan 17, 2016 | Seagate Barracuda 7200 1.5 TB 7200RPM SATA...
I have a 20lb propane tank fells half full or better grill lights but won't heat up why? Put new tank on works fine.
Gas may have settled. Turn it upside down several times. Usually happens when it gets cold outside.
Oct 12, 2014 | Grilling
Why does my GE Dryer shut off prematurely?
sorry but sounds like u may have a bad motor, going out. does it make u wait about 30-60 minutes before u can turn it back on? then it runs for a short while andf goes out agin?
Aug 15, 2014 | Dryers
When setting the timer (model 12-817) power is activated between the hour choices (2 hr, 4 hr etc) but the power goes off when the dial is turned to the actual hour selection. If left between the hour...
What timer is this?
http://www.electricsupplyonline.com/prod/intermatic-springwound_timers.php
Sounds like a defective timer.
I have three Intermatic spring wound timers that are used every day, and never have that problem.
After all, how does the timer 'know' when it's set on the 'hour' since the dial does not have stop points at specific times?
Add a comment for more free help.
Also take advantage of fixyas phone service.
For a price, fixya expert speaks with you over phone while you work on timer.
Jan 03, 2011 | Intermatic FD60MH Energy Controls -...
Shuts off after about 1 hr and then we have to power off
The TV might be on sleep mode, so it will stay on for an hour, then turn off again. You'll need to turn it off through the menu
Apr 03, 2009 | Hitachi 60SDX88B 60" Rear Projection...
Televison & Video Logo
16 people viewed this question
Ekse
RONALD CARTER JR
