Question about Citrix Computers & Internet
HELLO my problem is when i finished installed citrix 5 this message was shown citrix xenapp could not contact the server. check your network connection please give me a solution
Posted by morad karama on
john h
    Top Expert:
  • Citrix Master
  • 24,045 Answers
Check network if good then notify citrix for assistance
Posted on Mar 27, 2020
5 Related Answers
Anonymous
  • 9 Answers
SOURCE: network printer through thin print in wyse s10 model
not sure look in the manner
Posted on May 20, 2008
Anonymous
  • 5 Answers
SOURCE: Can not connect to internet when WJ enabled (Ultrasurf plugin)
WJ Enabled is UltraSurf.... just don't use UltraSurf for firefox. Go to Tools>>Add-ons>>UltraSurft Firefox Tool and select Disable or Uninstall...
Then use a web-based proxy.
Posted on Apr 28, 2009
Anonymous
  • 61 Answers
SOURCE: hello i have two IR1024i error code #801
Have you entered dns server address and reboot, make sure password is correct
Posted on Oct 21, 2009
Anonymous
SOURCE: Citrix WYSE SXO terminal.
restart client
Posted on Feb 18, 2010
Anonymous
  • 12 Answers
SOURCE: when i install MS windows server 2003 in IBM x3400
Ensure drives are seated correctly and set up the RAID config.
Then on the Blue screen of Windows installation it will say "press f3 for 3rd party drivers", hit F3 (I think its F3), then insert a floppy disk with the drivers for you RAID controller, setup will then say it has found the followign drivers "your device xxx" then it should* pick up the hard drives later on in setup.
:) - RAID controller drivers can be got from the manufacturer websites.... normally.
Posted on Sep 09, 2010
1helpful
Hi, I have two VM citrix servers that i have load balanced using windows NLB. My users are on a different subnet so I have the load balancing configuration set to Multicast mode. (I have a second nic in...
I have not worked with 3Com switches only Cisco, but I thought I would post this as I found it when googling:
multicast routing-enable pim
on the vlan interfaces:
interface Vlan-interfacex
ip address ***.***.***.*** ***.***.***.***
igmp enable
pim dm
Those commands should help you get multicasting to work. notice, Vlan-interfacex means you will have to do it for each Vlan you created. Some switches do not include multicast support in their base models but make you buy additional licenses to enable it. Cisco is like that, not sure about 3Com.
Chris
SAP with Ncomputing, its works?
It should work fine. As long as the SAP client is 'multi-user' aware then you're good to go. One 'acid test' is to see if the SAP client will work on a Terminal Server or a Citrix Presentation server and in this case it does. The NComputing solution, conceptually at the application layer, behaves much like TS or Citrix, thus looking for those solutions is what you'll need to know for NComputing. Here is the website I found about how to setup specific INI files for Citrix to get the SAP client working. My recommendation would be to test as is out of the box with two NComputing seats, simultaneously. If that fails, then try the suggestions on this website: http://community.citrix.com/display/adi/SAP+GUI+7.10+on+Citrix+Presentation+Server.
2answers
Hello... today i install the citrix receiver on my ipad and on my iphone to be connected to my companies network. With both installs i have using issues: iPad: i configured all firmdatas and the...
At my company, I had to get a link from my network admin to install the vpn app and setup the security certificate with code i got through the token app - the code would time out in 30 sec and start new code and timer. Like using the code generator in Facebook for logins. Check with your network admin, mine had an easy instruction to get it setup properly.
5helpful
2answers
How to turn on wifi
Configuring the optional internal wireless print server
If you purchased the optional internal wireless print server after your printer was already set up, follow these steps:
1 Install the internal wireless print server into the printer. For more information, see "Installing an optional internal
wireless print server" in the "Setting up the printer" chapter.
2 Click Start Programs or All Programs Lexmark 3500-4500 Series.
3 Click Wireless Setup.
4 Click Start.
5 Follow the instructions on the computer screen.
6 Click Finish to complete the installation.
Also here is the link to the setup guide and user manual
click here
configuring the wireless is in the setup guide
Citrix Access Essentials problem. Users can log into Web Interface but cannot launch programs. When I try to run the Quick Start the following error message appears: The licensing task counld not be...
Try one of these 2 things
1) Uninstall and reinstall Citrix licensing
2) Verify the path to the licensing server is correct (this is located in the licence console, if i remember correctly, the info is in the left hand pane at the bottom of console)
Windows XP, Vista, & 7, installed citrix client 12.0.3 on each of them. When using direct connect through cable modem, access is allowed and all apps work. When connected to my local router(trendnet...
Because you can connect outside of your trendnet, its definitely the problem. please allow and direct traffic on port 3389 in your trendnet firewall.
CITRIX not working with my cable modem. Connecting via laptop using the modem's wireless connection. i am able to connect to CITRIX just fine from the office, and from other internet connections.
Are you talking about published apps not working? If so, make sure that your cable modem has the following ports open:
TCP 1494 and 2598
These ports are used by the ICA protocol, which is what Citrix Presentation / XenApp Server software uses for running published apps.
We tried a Belkin Flip to bring our two computer screens together but after 5 minutes the mouse froze. We have a Citrix Server (Wyse terminal)and our Switchboard is a Mitel 5550IP consol. No one else...
1. Download and install ALL of the windows updates and service packs
2. Download and install any updated drivers for your Belkin Flip
3. Cool both computers down as much as possible to help prevent thermal overheat and lockup
Certan configurations can cause a lockup such as a Mitel 5550IP terminal and a Citrix Server
The prefured configuration is 2 identical desktop PCs
Mice can pose a problem , you can try moving the mice to a USB port
That may help clear up the situation of lockup.
Selah. :-)
Computers & Internet Logo
Top Citrix Computers & Internet Experts
xxxxxx xxx
ray gallant
Are you a Citrix Computer and Internet Expert? Answer questions, earn points and help others
