Error code 1518 - Computers & Internet
Posted by jackie krabill on
Attique-ur-Rehman
    Top Expert:
  • Computers & ... Master
  • 2,677 Answers
Https://www.youtube.com/watch?v=sS7BF7nyRJc
Posted on Mar 25, 2020
Error code 1518
What make and model?
What is the Username and Password for a Cavalier provded Zhone 1518-A1 Modem Router?
If the Zhone 1518-A1 was provided by Cavalier, then the address is:
192.168.1.1
Default Username: admin
Default Password: [email protected]@l13r (all lowercase)
This information was valid as of 01/17/2013
2answers
Only you know your SSID( username)and Security Key(password). You can RESET the device to default settings by pushing and holding the reset button for 30 seconds or so and release. That will reset to default setting. Then you can reconfigure the SSID and Security Key, You may want to write down the info for future use. This may help: http://www.zhone.com/products/1518-A1/
I need the default username and password for the Zhone 1518-A1 dsl router i cant find it or figure it out please help
192.168.1.1
This information was valiad as of 01/17/2013
Part number for the OPC Drum in a HP toner cartridge CC530A.
That OPC is the same for HP CP1215/1515/1518/2020/1525 CM 1312/2320/1415 cartridges.
No Part number, search OPC HP CP1215/1515/1518/2020/1525 CM 1312/2320/1415.
Mazda MPV 2001, code P1518 , and P1512, what is the problem?
After extensive searching and trial and error I found that the cause for the code 1518 on my mazda mpv was caused by the plastic clip that holds the linkage for the intake manifold runner had broke on the fire wall side and the linkage fell out causing the runner to stay open. It is very difficult to see. It is on the front( drivers side) of the engine below the upper intake manifold. Remove the air cleaner box and use a mirror and you can see it. Only about 6 inches long. Replace both clips while you are in there because it is a bear to get to. Check this first before you go through the other items like the egr. Inexpensive repair and my code 1518 and the one for randon miss fire went away never to return. Lots of power again. Good luck. Jim
3helpful
I have a Ford Windstar van and we had the scope done on it the code came up 1518 I was wondering what that code ment
.1518 / INTAKE RUNNER CONTROLL FAULT Look at the rods where they attach there is a plastic bushing holding the rod fast. These plastic clips tend to break. If it breaks the rod will fall off and create the code you have. If the rods are attached check the lines to the actautors that the rods attach to and make sure there are no breaks in them. If there is a break you can fix it by installing vacuum hose between the broken peices.
1518 code
go to google search and put in code check symptoms with yours alanwrench
1helpful
Need 5 Digit Remote Code for a Panasonic Receiver HE-100
Try 1518 or 1039
/www.comcast.com/remotes/universal.html
Computers & Internet Logo
k24674
