Question about Samsung Computers & Internet
How do i connect my Samsung NP300 laptop to a wi-fi?
Posted by Thokozani kheswa on
  • dtixgs
    dtixgs Mar 25, 2020
    ?Makes $140 to $180 consistently online work and I got $16894 in one month electronic acting from home.I am a step by step understudy and work essentially one to two or three hours in my additional time.Everybody will complete that obligation and monline akes extra cash by simply open this link…….
    OPEN THIS WEB...>>>>> https://bit.ly/3b9Z7Oq
dtixgs
?Makes $140 to $180 consistently online work and I got $16894 in one month electronic acting from home.I am a step by step understudy and work essentially one to two or three hours in my additional time.Everybody will complete that obligation and monline akes extra cash by simply open this link.......
Posted on Mar 25, 2020
5 Related Answers
Anonymous
  • 48 Answers
SOURCE: about wi-fi
Windows XP has a built in wifi configuration tool, previous versions of windows dont have this feature. But if you were to buy a wireless card it comes with software for wireless to work on all versions of windows from 98 - XP most if not all new laptops have wifi built in & that will be able to share your broadband connection through the netgear router. You can configure the laptop & pc to share files & printer between each other, easy way of doing that is by using the wireless network setup wizard which can be found in Start -> All Prograns -> Accessories -> Communications -> Wireless Network Setup Wizard.
Posted on Feb 10, 2008
Anonymous
  • 146 Answers
SOURCE: Wi-Fi Connectivity
login to http://xda-developers.com ;and this will solve the problem of your PDA
All the Best.
Was this solution helpful? Show your Appreciation by rating it:
Posted on Feb 15, 2008
Jess
  • 742 Answers
SOURCE: wi-fi connection problem
There are 2 ways to approach your problem.
  1. Un-protect your wifi connection by removing the password. This is risky since other wifi gadgets can readily connect to your network.
  2. Configure your Samsung phone to connect to your password-protected wifi. Make sure that the wifi protocol of your phone matches that of your wifi router. Example, make sure to set WPA or WPA2 on both device.
Posted on May 08, 2010
Anonymous
SOURCE: LG Renoir wi-fi connection failure
When i try to turn on my wifi my Lg Renoir restarts ! Any suggestions on how to solve this ?
John
Posted on Jul 03, 2010
gaganddun
Gagan Gupta
  • 114 Answers
SOURCE: I had recently purchased Samsung
Dear Meghna you have not mentioned the wifi router make and moel
no problem
for this you have to go to your router web admin to add your device as WPS client this will solve the problem
for that all the models are differently configured so you have to try playing with the settings yourself, if you jumble up the settings of you wifi router there is a reset switch in all the routers that restors your router to factory settings.
if you find my information useful dont forget to vote me with the thumbsup thankyou and take care Gagan Gupta
Posted on Mar 15, 2011
Need a manual for Samsung 4G so I can hott spot my laptop
no you don't need a manual its easy
Go to your normal home screen on the phone . Ie unlock the screen.
At the top of the screen you will see small white symbols .
put finger on them and pull/ drag finger down to see hidden menu
You will now see wi fi , location, sound, screen rotation, bluetooth
put finger on right hand side of these options and drag finger left
the forth option shown should be mobile hot spot
press on mobile hot spot with your finger
Attention
Enabling mobile hotspot will turn off wi fi
Cancel or OK
Click on OK ( you use wi fi to link the mobile data to the laptops , ect)
on your laptop you will see androidap as a wi fi network connect laptop to this !
network key come up
what is the password
go into the phones settings
look for Tethering and Mobile Hot spot
click on this
click on Mobile Hot spot
step 3 in list of instructions that have now come up will be the AndroidAP password you will need on the laptop , ect
Put password listed into laptop wi fi connection password question.
PS put mobile on usb power or usb charger while hotspotting !
tip
How to set up internet on Samsung Jet
Ensure that you have the appropriate network key code needed to enable you to access a secure Wi-Fi network.
If you are connecting to a secure Wi-Fi network with MAC address restrictions, you will require pre-authorisation for the router. You will need to find your Samsung Jet's MAC (Media Access Control) address. This is a 12-character code which may be needed by the network controller to enable the phone to connect. See Getting the Samsung Jet's MAC address below.
You can get to the Wi-Fi application either via the main menu or using a homescreen Wi-Fi Widget.
  1. To get to the Wi-Fi application via the main menu, press the MENU button (either on the home screen or the hexagonal button beneath)
  2. In the main menu, swipe your finger sideways to go through the menu pages until you see the Wi-Fi icon. Press to select.
  3. The Wi-Fi application opens.
  4. Alternatively, to use the Wi-Fi Widget, from standby, press the home screen. The Widget toolbar opens up.
  5. Scroll down to find the Wi-Fi Widget icon. Press the Wi-Fi Widget. The Wi-Fi Widget will pop up on the main screen.
  6. Press the Wi-Fi Widget on the main part of the display to launch the Wi-Fi application. The Wi-Fi application opens.
  7. Once in the Wi-Fi screen, press the large Wi-Fi button in the middle of the screen to turn it on. Wi-Fi is activated and the button turns blue.
  8. Press SEARCH Nearby Wi-Fi access points (APs) will appear as small circles on the display, with their names next to them.
  9. Press the circle representing the Wi-Fi Netowrk you want to connect to. An options panel appears.
  10. You can press CONNECT to connect to the network or press ADD if you want to add it to a list of preferred networks for easy access later.
  11. You are taken into a settings menu for the Wi-Fi access point. If the Wi-Fi access point requires a network key code, scroll down to the Network Key panel. Press to select.
  12. The numberpad appears. Type in the network key code and press DONE. You are returned to the previous settings screen. Press SAVE
  13. A list of connections appears. Press the back arrow button
  14. If you initially pressed CONNECT, the phone will connect to the selected Wi-Fi network and a confirmation message will appear. The display now shows the new connection, illustrated by blue dots linking the circles onscreen (Figure 15).
  15. If you initially pressed ADD, you will be returned to the Wi-Fi screen. Press the circle representing the Wi-Fi network you want to connect to. A pop up panel appears.
  16. Press CONNECT. You will be connected and the connection illustrated onscreen.
Press the back button to return to the home screen.
  1. From the home screen press MENU to enter the main menu (Figure 1).
  2. In the main menu, press INTERNET
  3. Choose which browser option you want (Home, Enter URL, Bookmarks, etc.) (Figure 18) and press to select. If you press Home you will be taken to the pre-loaded home page.
  4. If required, use the numberpad to type in an URL or scroll a list to select bookmarks. When an URL is completed press GO. Alternatively press the bookmark you wish to access. You will taken to the web page requested.
  1. Activate Wi-Fi and press SEARCH, as before.
  2. When the Wi-Fi access point you want to connect to appears on the display (Figure 8), press it to select.
  3. A pop up options panel appears (Figure 9). Press DETAILS
  4. Details of the Wi-Fi access point appear onscreen.
  5. Scroll down by dragging your finger up the screen. Towards the bottom of the settings list, DEVICE MAC appears, with a string of 12 charactesr beneath (Figure 21). Each handset has an individual MAC address, and this panel will display your Samsung Jet's unique Mac address.
Make a note of the MAC address. You will need it if you want to use the Samsung Jet's Wi-Fi to access a secure Wi-Fi network using MAC address restrictions. This can be added into the wireless router settings access list.
Can't seem to connect to wi-fi
Cannot Connect to Wi-Fi - Troubleshooting your ... - Samsung
www.samsung.com > Home > Support > Cell Phones
Samsung ElectronicsFAQ00061225 I cannot connect to Wi-Fi® on my Samsung device. ... On the mobiledevice, attempt to connect to the Wi-Fi network. If you are not able to connect ...
What to Do When Your iPhone Won't Connect to Wi-Fi
Dec 19, 2015 • Cell Phones
Connect to wi-fi?
Are the Drivers up to date?
When i connect my samsung galaxy express to wi-fi my computer's wi-fi stops working
Hello Ricardo.
How are You? I Guess you need to
1- Check your wi-fi router model.
2- Check your wi-fi settings.
also please check how many devices are connected to your wi-fi at same time. because some routers can only support upto 5 device. you can check this in the settings and also routers manual.
Please let me know, once you done with it.
Regards
My samsung star wifi can not connect to my router
1. Tap the "Menu" button from the home screen of your Samsung Star phone.
2. Tap "Wi-Fi" and select the "ON" option.
3. Select the Wi-Fi router you want to connect to from the list available Wi-Fi networks.
4. Enter the case-sensitive password to connect to a secured network. Your phone will only prompt you to enter a password if connecting to a secured network.
5. Wait while your phone automatically connects to the Wi-Fi router.
and enjoy your wi-fi connection.
I can only get a very weak wi-fi connection
What is you internet speed? if the speed is less than 5Mbps change the network speed settings in the wifi router to 100Mbps to 10 Mbps that will solve the issue.
1helpful
2answers
Is the SAMSUNG R530 DVD/RW laptop wifi enabled??
Hello. Yes, it is wi-fi enabled. You can check this user manual for your reference.
2answers
Samsung np-nc10 shows good signal for site wi fi but wont connect
Go here and download the latest Wi Fi card drivers for your samsung, from samsung.
http://www.samsung.com/us/support/detail/supportPrdDetail.do?menu=SP01&prd_ia_cd=&prd_mdl_cd=&prd_mdl_name=NP-NC10
Hope it works
Jim
Computers & Internet Logo
Top Samsung Computers & Internet Experts
Jean Thiebaux
Jax Planet
Jax Planet
aliasger yq
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
