Https://www.youtube.com/watch?v=hYFT24RobCU
https://www.youtube.com/watch?v=1z_SNB95OE8
SOURCE: I am looking for an
Here the service manual.
599735A DD24 DD60 Service
See chapters from page 25 and from page 32.
If this satisfies your query, do not forget to rate the solution.
Regards.
Ginko.
SOURCE: It doesn't spin in cycle. Timer goes slowly and
It seems that the timer is faulty and must be checked on for loss of contact while it is in the spin mode of the cycle. It can be a mechanical failure of the connections or a possible failure of the contacts.
It will be good if you can source one timer unit to be set on for a trial swap so as to confirm before you can invest on one .... being expensive.
SOURCE: Samsung RS2555SL evaporator is icing
Hi If
refrigerator is not cooling properly it can be due to a defrost timer, which is
causing the fridge to go into defrost cycle. Usually it takes 45-60 minutes for
refrigerator to come out of defrost cycle. If the timer
is bad then it will not come out of defrost cycle and
can result in this kind of issues. It can also occur due to defrost thermostat,
it allows current to pass through it at temperatures of 20 to 30 degrees
Fahrenheit and prevents current from passing through it at 40 to 60 degrees.
This is difficult to test, though, because it takes a prolonged, very-cold
temperature to turn it on. The defrost thermostat is
snapped onto the top portion of the evaporator. The thermostat sends
temperature information to the processor. The defrost heater must be replaced
when replacing the thermostat. Hope this helps...please post back for further
assistance. Daniel
1. Remove the lower fan duct work from the evaporator cover.
2. Remove the 1/4-in. evaporator cover screws and remove the evaporator cover.
3. Disconnect the defrost thermostat wiring connector.
4. Remove the defrost thermostat from the evaporator.
SOURCE: can I put and ikea under counter inteergrated
if you have allowed the same size allocations for the locations in the kitchen to the advertised sizing of the appliances then there should be no problem but I know from past experience some ikea things are of different to normal sizes however, i would be very surprised if they have custom made appliance sizes.hope this helps.
