If food in the bottom of the refrigerator is freezing, this could be caused by a refrigerator not having enough food to absorb the cold air. If food in the door is freezing, move the door bins up or down so they are one notch away from freezer vents. The fresh food control should be at the normal setting of 5.
https://products.geappliances.com/appliance/gea-support-search-content?contentId=20492
https://removeandreplace.com/2016/08/03/refrigerator-is-freezing-everything-what-to-check-how-to-fix/
https://www.google.com/search?sxsrf=ALeKk01roiJbhF3b0068kwGhCH7KB2qyWg%3A1585146122570&source=hp&ei=Cml7XsamIIqua5qMkMgG&q=everything+in+my+Daewoo+refridgerator+freezes+even+at+the+lowest+setting&oq=everything+in+my+Daewoo+refridgerator+freezes+even+at+the+lowest+setting&gs_l=psy-ab.3...2414.2414..3313...2.0..0.276.276.2-1......0....2j1..gws-wiz.....10..35i362i39.Hp6uN1HobIk&ved=0ahUKEwjG07O86bXoAhUK1xoKHRoGBGkQ4dUDCAU&uact=5#kpvalbx=_Dml7Xr-iOYi7lwSMx4X4Cg44
SOURCE: Refrigerator freezes everything even on the lowest setting
Is everything really frozen or just the top shelf stuff? You may have a thermistor (temp sensor) problem if the compressor just runs and runs and runs all the time. Take a glass of water and place a thermometer in it for about 3 hours then take a temp. reading. That will let you know what the real temps are. See if you can cause the compressor to kick off and on by changing the temp settings (go to real low for about 5 minutes then back up to high). Let us know what happens.
SOURCE: I have a Dometic RV
thanks for the question sounds like a defective cold control replace it thanks the appliance doc
SOURCE: my refridgerator is freezing my food
are all your lights working ie interior light and warning lights on front, i had the same problem with fozen food and it turned out to b the control board cost me 75 supply and fit
