Question about Frigidaire Refrigerators
FRIGIDAIRE FFHS2622MSQ DISPENSER LOCKS OFF AND ON ON IT'S OWN.
Posted by Robert Wines on
Attique-ur-Rehman
    Top Expert:
  • Frigidaire Master
  • 2,677 Answers
Https://www.youtube.com/watch?v=9k81fgjOk-U
Posted on Mar 25, 2020
Ice dispenser and water dispenser does not stop after use.
Hello Junhee, thank you for your post!
From what you have described your ice and water dispenser on your Frigidaire refrigerator continue to dispense after being used. This could be a possible issue with your dispenser or the switch inside of the dispenser. I would recommend looking over the dispenser to assure there is no visible damage done to your dispenser. You may need to have a technician out to perform a proper diagnosis and repair. This will help you avoid any unnecessary part purchases. I hope this information is helpful. -Matt
Water dispenser on my 3 year old side by side FRIGIDAIRE PROFESSIONAL FPHS2386LFO is not working, It makes ICE but no water I can hear motor when I try to use dispenser
I appreciate your inquiry, bela_desousa!
From the information you have provided the water dispenser on your Frigidaire refrigerator is not dispensing. Have you recently changed your water filter? If you water filter has not been changed and is dirty or clogged it could lead to potential failure of your water dispenser. If the filter has been changed it could be a faulty dispenser. I would suggest consulting with a professional technician for proper diagnosis and repair. Hopefully this is helpful. -Matt
Frigidaire affinity soap dispenser doesnt work
Good Morning Friend, this is Z. I appreciate your post!
I see that you have a Frigidaire washer and that you are having trouble with the soap dispenser. Is the soap dispenser not dispensing bleach or softener? Is there water left in the dispenser? Are you able to open and/or close the dispenser? Also, may I have your model number please? You can normally locate the serial on the upper front, as you open the door. With this information I can better address the issue at hand. Thank you!
1helpful
After the wash is finished in my frigidaire affinity ATF8000FS, I noticed that the fabric softener remained in the dispenser. ????
You will need to open the dispenser and clear the internal channels out.
There is a service manual available that shows you how the internal dispenser works if you should need it.
1helpful
The detergent door won't open while the dishwasher is running through the cycle.. frigidaire GLD2445RFS0
More than likely a faulty dispenser. The wax motor that is used to open the dispenser burns out regularly. Just order a dispenser, remove the 2 phillips screws that hold the front panel on, and you'll see the 6 screws that hold the dispenser in place.
Ice maker arm does not move freely.
there is probably a piece of ice caught under one of the harvest fingers, at this stage of the harvest, the ice arm is engaged and will not move freely until the harvest cycle is complete.
4helpful
Front load washer
HI. your model has a dispenser solenoid for the fabric softener dispenser on this unit. If the solenoids are out or malfunctioning, it will render the dispenser useless. i recommend checking the solenoids on the fabric softener dispenser for continuity. The resistance should be 1100+- 7%. replacing this blown solenoid will fix this issue. Remember. the dispenser valve will not function without a working solenoid.
please rate and god bless.
12helpful
2answers
Frigidaire plhs267za side/side water dispenser leaks while ice maker cycles
You have a bad diode on the water valve connection frigidaire has a kit for this fix..
5303918287, 5304418384 DIODE KIT frigidaire
Frigidaire signaling water dispenser instead of ice maker
Sounds like the water solinoid valves are wired wrong.One activates The water dispenser.The other the ice maker.That, why every so often the water shoots out on the floor.The ice maker is telling the valve to open.
Refrigerators Logo
Top Frigidaire Refrigerators Experts
Dan Webster
Dan Webster
john h
jdthefixer
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
