Question about Jcb Cell Phones
We have JCB excavator engine start but joy stick both left and right not functioning. Someone can help. thank you in advance.
Posted by Algen Falcatan on
Attique-ur-Rehman
    Top Expert:
  • Jcb Master
  • 2,677 Answers
Https://www.youtube.com/watch?v=u_Cz29VTrK0
Posted on Mar 25, 2020
5 Related Answers
Anonymous
  • 14 Answers
SOURCE: Right Joystick. . .
I had this same problem with my 360 controller (after modding it, but the solution should be the same..) If you pull up on any 360 joystick it will stick the same way.
The quickest fix would be to take some sandpaper on the inside of where the joystick touches the controller shell, sand it down just enough so the joystick is moving smoothly.
More professional ways would be to cut the little piece of metal that sticks out and goes into the joystick. Just a very small amount, too much will make it hard to press the right thumbstick button.
You could also try some old fashioned grease, just a little bit on the inside, nothing noticeable from the outside.
Also make sure the controller is put back together right, I've taken apart many 360 controllers and sometimes joysticks stick when there's a wire in the wrong place and the shell won't close all the way. (The rumble motors particularly).
Hope this helped!
Posted on Oct 23, 2007
Anonymous
SOURCE: Y-axis non-fuctioning
check here:
http://www.wingmanteam.com/latest_software/latest_soft_main.htm
grab the Logitech Gaming software 5.02 (I used the 64bit, make sure you grab the correct one!).
Note, I have a logitech MX 518 gaming mouse, and after installing the above, I could no longer use my button assignments in any games. The mouse functioned like an old 2 button mouse. I have a feeling there is some conflict between the mouse software/driver and the logitech software/driver.
Posted on Dec 22, 2008
Anonymous
  • 39 Answers
SOURCE: Xbox 360 Controller Functions (Sticks and Buttons)
That's a manufacturing fault. Take it back to where you bought it or get in touch with Microsoft (who will probably replace it for free)
Contact Microsoft
Posted on May 03, 2009
udesh99
Udesh Ganepola
  • 98 Answers
SOURCE: how to reset the service light on a JCB JS 130 Excavator
Press "SET" & "MODE" Keys Both 20sec. (After Menu Coms)
Select "Service off" By Press Arrow Keys
Then Press "ACK" Select "Service on" Position by pressig Arrow Key & Press "ACK"
Posted on Jun 05, 2009
Anonymous
SOURCE: JCB 801.4 mini digger - no control of digger arm
We have a similar problem on a Mitsubishi MM55SR.
We developed a new control set-up
Posted on Aug 07, 2009
When I back up my max zoom 60 the left wheel tracks much slower than the right wheel. Moving forward they track the same. The left joy stick when pulled all the way back will nut reach the stop nut.
The best solution you'll get from books at www.reliable-store.com
These are books containing info on repair, service, troubleshooting, parts info, assembling dissemble, removal, error/fault codes, wiring diagrams and everything on any vehicles cars, atv, trucks. forklifts, boats, excavators etc
1helpful
2answers
How do I change j c b 215 rubbertire backhoe hyd’s system over to excavator style right now the machine is backhoe style and I want it excavator style what hoses would I have to change it’s a 2003 jcb
the jcb 215 hoe is a 4 wheel tractor frame where as the excavator is a tracked vehicle
the change over would cost more than leasing the track machine
it is considered not a feasible exercise
contact JBC for further advice on the requirement
When I switch on my jcb js 130 excavator the eighteen warning indicator lights are not going off
How to reset the service light on a JCB JS 130 Excavator ...
www.fixya.com/.../t1428872-reset_service_light_jcb_js_130_excavator
Dec 25, 2008 - how to reset the service light on a JCB JS 130 Excavator Hi I have serviced our JCB JS 130 ... my self and I am woundering if there is away of switching off the service warning light ... Helpful 41; Not Helpful; 1 Comment; Flag ... Posted on Feb 18, 2009 ... What kind of brake fluid goes into a jcb 3cx 1985/86?
4answers
Can't swing the backhoe arm left or right with the controls
The travel lock is either in place keeping it from moving in transport or there is something wrong with the hydraulics. Look for a push button release. The other thing is the stabilizers have to be engaged
Scooter will only turn 1 way
Get someone to replace the joy stick. You might be able to get the company to send someone, or a friend might be electrically/mechanically handy. I've found most repairs on my chair can be made by someone competent.
Ps3 joystick
calibrate controller ? check controller settings ?
1helpful
2answers
Ineed a shop manual for jcb Mini Excavator serial no SLP08037E0828473
you can go to this site and download it right away JCB
Feb 14, 2013 • Garden
How to change my security code but i didnt know my old password to chage it
Sony Ericsson Secret Menu:
> * > means press joystick or arrow keys to right
1. push joy stick to RIGHT once
2. press *
3. push joy stick to LEFT twice
4. press *
5. push joy stick to LEFT once
6. press *
The Service Menu will appears containing following information !
1. Service Info
a. Software Version
b. SIMlock
c. Configuration
2. Service Setting
a. Contrast
3. Service Test
a. Display
b. LED/Illumination - *This test is very cool
c. Keyboard
d. Buzzer
e. ********
f. Earphone
g. Microphone
h. Real Time Clock
i. Joystick Counter*
Lockstatus:
Shortcut to last dialed numbers: 0#
Hope this helps.
If you are helped you can rate on the 4 thumbs and leave a short comment,because,
this is the free side and I can get the chance, to help people like you .
Thanks for using fixya .
73helpful
6answers
Dec 25, 2008 • Garden
Fixing 5-way joy stick.
no way only the center button acn assign a function . other 4 keys can be only used while using menu or gaming functions u can change the application selection for center button in seetings> phone
Dec 04, 2007 • Nokia 6620
Cell Phones Logo
Top Jcb Cell Phones Experts
ADMIN Canada
ADMIN Canada
Are you a Jcb Cell Phone Expert? Answer questions, earn points and help others
