What happens when blue and pink make then when these 2 colours are mixed with each other ?
Posted by Bethany Green on
Reggie brown
  • 947 Answers
I think that when pink and blue are mixed with each other they make the colour light purple then.
Posted on Mar 25, 2020
OKOKO FAVOUR
    Problem Solver:
  • 17 Answers
Write your answer... [THE MIXTURE RESULT IN LIGHT PURPLE
Posted on May 07, 2020
Andrea Gutierrez
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
    Problem Solver:
  • 10 Answers
Light purple
V LCD Monitor D19W12 how do I adjust color - it is all PINK?
Make sure that the "data" cable between the computer and the monitor is tightly-connected at both ends.
Try a different "data" cable.
Try connecting the monitor to a different computer (laptop or desktop).
Note that 'WHITE' is generated by mixing all 3 "primary" colours.
If the video-card on your computer is not generating all 3 colours, then 'PINK' could be the result from mixing the remaining 2 "primary" colours.
Aug 18, 2011 | ViewSonic VP211b 21.3" LCD Monitor
Printer is printing with a pink hue
Your printer mixes the 3 colours in the tri-colour ink-cartridge to achieve each colour.
So, printing in 'PINK' suggests that one of the other 2 "primary" colours is OUT-OF-INK.
Replace the ink-cartridge.
Jan 25, 2011 | Canon Office Equipment & Supplies
I have just recently purchased a BMW ci328i and do not yet have the manual. The coolant sign is starting to flash up on dash. What coolant can I use?
There are many different coolants and if you mix 2 different ones together they can react and turn into a gel which don't do the car much good! the best way is look what colour coolant is in the system already and as long as you use the same colour coolant it will be fine, main colour coolants are green,blue pink and orange, green and blue can be mixed together as can orange and pink but Pink cannot be mixed with blue or green, i would guess the coolant in your car will be the pink stuff but please check 1st, hope this has been usefull to you.
Ash
Jan 09, 2011 | 2000 BMW 3 Series
Monitor turned pink
Video-cards generate "primary" colours (red, green, blue), and "mix" those colours to produce millions of "secondary" colours.
First, try replacing the "data' cable between the LCD and the video-card.
Second, if your LCD works correctly when connected to some other desktop or laptop computer, then the video-card in your computer is not working properly -- not sending one of the "primary" colours to the LCD. Replace the video-card.
Jul 17, 2010 | Samsung SyncMaster 931B 19" LCD Monitor
Hp w2007 why does the computer go pink everything that is green is now black
All the colours on the screen are created by "mixing" the 3 "primary" colours (red, blue, green).
Once the production of "green" ceases, anything that should be "100% green" becomes "100% black",
and every colour that indicates some percentage of "green" becomes a mixture of just RED and BLUE, i.e., various shades of PINK.
First, try the monitor on another computer (desktop or laptop). If the problem persists, it's time to replace the monitor. If the problem vanishes, it's the video-card in your computer that is not generating GREEN, or it is the "data" cable between your monitor and your computer that is not transmitting the GREEN request. So, you can try replacing the data-cable, or try replacing the video-card.
Jul 11, 2010 | Computers & Internet
My monitor resolution colour is changed to pink.
Check the data-cable between the computer and the monitor, and try a different cable.
Or, try connecting the monitor to a different computer, to see if the video-card in your computer is not working correctly.
If necessary, replace the video-card.
Colours on your monitor are produced by "mixing" the 3 "primary" colours: red/green/blue in various proportions.
Or, if part of the monitor that produces one of those 3 primary colours has stopped working, then the resulting "mix" will have too much RED/PINK. Fix/replace the monitor.
May 29, 2010 | SAMTRON 55V 15" CRT Monitor
Toshiba Satellite L35 screen color turned to pink.
If you have a LCD-screen, not an old-style CRT-screen, it is the data-cable, and its connections, that are not transmitting one of the 3 "primary" colours, e.g., mix red & blue & green to get white,
but mix only two of those colours, and you could get pink,
because the mixing is an "additive" process.
If you mix NONE of the 3 primary colours, you should get BLACK.
If you see GREEN, you're seeing ONE of the primary colours.
Sep 19, 2009 | Toshiba Satellite L35-S2366 Notebook
When playing my X Box 360 the colours on the screen keep mixing
.this could be caused by an unsupported display setting for your t.v .are you using the right settings. to adjust them go to options in the xbox main meneu and then t.v options and adjust the screen disply. and then try your game. please write back here if this dosent help
May 08, 2009 | Microsoft Xbox 360 Console
Blues are pink?
either ur blue cartridge is empty or maybe the nozzle of ur blue are clogged .normally the dark blue colour is made up by mixing of blue and pink . because ur nozzles of blue are clogged or maybe the blue is empty it prints only in pink when u command for blues.replace the blue if its empty or clean the nozzles if its clogged.
Sep 15, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Printing blue on top of pink
There is a common colour problem with this model printer it is caused by the scanner assembly (there's a fan that blows megenta into the scanner unit).
Solution is to clean the scanner mirrors.
Aug 04, 2008 | HP Color LaserJet 2600n Printer
376 people viewed this question
Ekse
Marvin
Marvin
