What colour does grey and white make when they are mixed with each other ?
Posted by Bethany Green on
Reggie brown
  • Office Equip... Master
  • 640 Answers
Light grey I think then if grey and white and mixed together then.
Posted on Mar 25, 2020
Andrea Gutierrez
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
    Problem Solver:
  • 10 Answers
Light grey
Can I use 2 black cartridges instead of 1x colour And 1x black
no point
the machine is programmed to use each colour as required
putting in black cartridges will still only use the one black cartridge
remember that grey is not less black but black with a colour mix
Aug 26, 2017 | Black Office Equipment & Supplies
What to do if my water is mixing with the oil
What oil is it mixing with. If it is engine oil then have a compression test done to determine head gasket/cracked head. Water ( grey/white colour oil)can also get to the sump from corrosion holes in the timing cover case behind the water pump impellor. If it is oil in the radiator and is pink ,then it will be from a failed oil cooler in the radiator for the transmission allowing transmission oil to get to the coolant.
Jul 01, 2014 | Cars & Trucks
Why cannon ip3000 can't print in only black and white although I choose grey scale priting?
Not sure of the QUESTION..? Do you want to print colour or black and
white..? Anyway,try this, bring up image , at top left click on Fix , at top
right click on Auto Adjust then go down to Adjust Colour click on and
hold Saturation Slider move to left to remove colour ,right to add colour
go to print and it should give you a black / white image. Remember to
return image back to original colour or image will return to file in b/w
hope this works for you..goodluck...T.C.
Mar 31, 2013 | Canon PIXMA iP3000 InkJet Photo Printer
Hi, im searching for the stereo wiring chart for my mitsubishi lancer 2002 GLXI. i have searched for it but the colours are completely different to what i have. For example the colours i have are - Blue/...
This is all I could find. Hope it helps.
WIRE COLOR POLARITY LOCATION
Battery RED/BLACK (+) RADIO HARNESS
Accesory BLUE (+) RADIO HARNESS
Ground BLACK (-) RADIO HARNESS
Illumination GREEN/WHITE (+) RADIO HARNESS
Power Antenna YELLOW (+) RADIO HARNESS
LF Speaker (+) WHITE/BLUE
LF Speaker (-) BLACK/BLUE
RF Speaker (+) WHITE/RED
RF Speaker (-) BLACK/RED
LR Speaker (+) YELLOW/BLUE
LR Speaker (-) GRAY/BLUE
RR Speaker (+) YELLOW/RED
RR Speaker (-) GRAY/RED
Apr 14, 2011 | 2002 Mitsubishi Lancer
Colour codes for 83 corona, wiring stereo the colours are grey/black grey/red Brown Purple/green Grey Blue/yellow blue white/black any help would be great thanks!
Hello! I'm having a hard time reading your colors...So, I'll give you the 1983 Corona wiring...
POWER
Constant +12= Blue/Yellow Switched +12= Gray
Ground= Brown Antenna= Black/Red
Illumination= Green
SPEAKERS
FR+ Light Green
FR- Blue
FL+ Pink
FL- Purple
RR+ Red
RR- White
RL+ Black
RL- Yellow
Guru...........Saailer
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
May 30, 2010 | Pioneer AVH-P5700DVD Car DVD Player
2001 vw golf 1.4 wiring details for towbar plug/socket.(colour coding)?
Left indicator - Yellow to Black/White
Right Indicator - Green to Black/Green
Left Tail - Black to Grey/Black
Right Tail - Brown to Grey/Red
Fog - Blue to Grey/White
Brake - Red to Black/Red
Earth - White to Brown or Body earth above/behind Left hand Light
Oct 02, 2009 | 2001 Volkswagen Golf
02 sensors wiring
The yellow and white wires take any white wire.I dont now why they dont tell you that.And just fit black to black and grey to grey that simple good luck pippall.
Aug 08, 2009 | 1996 Jaguar Xj Series
Replacing Clarion Radio cassette in 200 Impreza
yellow battery
red accessory
black ground
purple right rear + speaker
purple/black right rear -
green left rear +
green/black left rear -
white fr left +
white/black fr left -
grey fr right +
grey/black fr right -
blue auto antenna
blue/white rem amp
brown phone mute
orange/white illumination
pls rate people arnt rating hope this helps
Sep 13, 2008 | Clarion ARX9270
Black colour ?
Thats because it's using the other colours to mix what it thinks to be shades of grey. Due to the black ink being pigment based and the colours inks dye base, when printing onto glossy paper the machine will use the colour dye based inks to make up black.
If you were to print on plain paper, set to greyscale, then the machine will just use the black as the pigment ink sits onto of the plain paper and will not run should the paper get wet.  With glossy paper the ink has to be absorbed into the paper ad the Black pigment ink will not do this so the machine will use the coloured inks.
Sucks but true.
Aug 06, 2008 | Lexmark X3480 All-In-One Printer
60 people viewed this question
Ekse
Marvin
Marvin
