Question about Samsung Televison & Video
My Samsung t.v model un60d6000sfxza when you push the power button just clicks on and off but won't come on what could that be..
Posted by Timothy Stanley on
steve
  • 3,718 Answers
Possibly the switch is faulty, i would think, have to be inspected by qualified engineer, might be more financially better option to get new TV
Posted on Mar 26, 2020
2 Related Answers
Anonymous
  • 10 Answers
SOURCE: I have a Samsung HDTV. when i push the power
this is a capacitor issue , one or more of your capacitors has blown on your power supply.
Posted on Apr 23, 2010
electrotech1
Veril Gillette
  • 1126 Answers
SOURCE: Samsung model HP-T5054 Plasma TV
When you remove the back of the set. You will fined a couple of caps on the power supply board that are bulged and they need to be replaced, or you can buy a new power supply at www.partstore.com. If you want to just purchase the caps, you can get them at www.mcmelectronics.com
Posted on Oct 16, 2010
2answers
I've replaced every board on the samsung plasma and still clicks
What do you mean by clicks? Plasma televisions are hot cathode ray, there is thermal expansion that takes place due to heat.
Why won't it start?
Here are a couple of things you can try:
Turn the lens clockwise then push the power button. As soon as you hear a click when you turn it push the power button and it should power up. Or
1. Push the power button.
2. double-tap the play-button at the bottom and the screen should activate. If so, push the menu-button. Go to settings and choose reset.
mendmy com How can fix my samsung camera help plz Cameras Film Cameras...
You may find this thread interesting, and helpful...
Hi i have a plasma lcd samsung tv model:PS-42C91HDX it has power going into the tv as the blue light under the front panel below the power on button is on when i push the on button nothing happens. no
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent.
Samsung BD-P1400 Blu-Ray player will not play movie on my TV
Is the Blu-ray region (on back of box) same as the players region?
if not it will refuse to play it.
Samsung plasma won't turn on
Here's is what you need to look for when describing a problem for troubleshooting purposes:
0) What model is the TV (you've covered that)
1) Does the TV respond to command to turn on?
(yes - continue; no - 70% bad power, 30% bad main board)
2) Once it responds (clicks), does a front LED or other indication show that it turns on? It's OK if there's no display.
(that can be model specific and is not certain indication for anything until known what is specific for the model)
3) If such an indication comes up does it remain on until you act or does it go off by itself?
(Stays on - power supply likely good; turns off - power supply *may* be good, but not certain)
4) If the power indication stays on by itself can you make it go off by pressing the power button or do you have to disconnect from AC power?
(responds to power off - 90% power supply likely OK and 90% OK main board; does not respond to power off - 90% bad main board)
Here is a link for test/repair of the power supply of your TV, hope it would help:
http://www.coppelltvrepair.com/p/895/samsung-pn58a550s1fxza-power-supply-repair-service-for-dead-or-clicking-on-and-off-problem
I have a 42" Samsung
This clacking and clicking noise could have been coming from a capacitor going bad in the tv. If this is the case where the tv will not turn back on, I would suggest calling samsung to try to get a replacement or get the tv serviced. Trying to replace bad capacitors can be a tedious job and requires knowledge of soldering small components. This may also void your warranty if you still have coverage.
On my SGH-A737 some times my buttons won't work so
pull it apart and clean the contacts with a rubber eraser where the silicon buttons push onto it . if you google this up there will be a link to show you how to pull it apart it is not that hard to do. regards terry PS.it is under samsung and your model number.just type in how do you pull apart samsung etc ther are pictures to guide you through it..
Televison & Video Logo
Demonic-2011
Demonic-2011
 Grubhead
Grubhead
