Question about Brother Office Equipment & Supplies
Steps To Resolve Brother Printer Not Printing Yellow
Posted by elisa martin on
steve
  • 3,718 Answers
Change ink cartridges and test print and clean heads
Posted on Mar 26, 2020
4 Related Answers
Robert Kitaji
  • 1335 Answers
SOURCE: My printer is not printing the colour yellow even though the cartidge is full and new
If you have run the nozzle cleaning utility, and you are not getting any yellow output, the cartridge is most likely defective. This also occurs if you are not using OEM ink cartridges.
Posted on Apr 25, 2009
Anonymous
  • 86 Answers
SOURCE: printer printing in with stripes
You can try to perform a power purge, do it by the following:
  • Enter maintenance mode. Either with starting your machine with Menu button down, or by pressing Menu, 2, 8, 6, 4 quickly. The fax/copy/scan buttons should flash/be lit.
  • Press 7, 6.
  • Press 3, the machine should now say something like "POWER_P" or "P_PURGE"
  • Press Mono/Black start, the machine should now say "cleaning".
  • When it's done, the display should say Maintenance, and you can leave this service mode by typing 9, 9.
You can now try printing a test page again, the result should hopefully be better.
Be noted however, that this purge takes ink from your cartridges, but it's more likely to solve the issue then just trying to do more "regular cleaning".
Posted on Jun 14, 2009
k24674
  • 8092 Answers
SOURCE: Printer Setup & Support Call 1-(805) 225-6690 For help We are 24 Hour Available Call Now For Help
You try to solve that problem by following the instruction the machine gave you. Here is the link to the manual.
http://welcome.solutions.brother.com/bsc/public/us/us/en/doc/manual_index.html?reg=us&c=us&lang=en&prod=mfc210c_all&type2=5&flang=English&dlid=
Hope it helps.
Posted on Aug 30, 2009
Anonymous
  • 129 Answers
SOURCE: My Brother inkjet printer (DCP-585CW)
If the yellow ink is not printing here's what you can do:
Clean the Printhead & Print a test page by doing the ff:
1. Press the Ink Management button press the Up or down arrow key to select Test Print, then select Print Quality press OK and press Black or Color START. Check all the colors including the black & check if there are any missing dots and if there are any colors not printing correctly.
2. Press the Ink Management button on the control panel and select cleaning press ok
3. Press the up or down arrow key to select Color press ok and press Black Start.
*After the cleaning process the printer will ask you if the quality is OK, press up or down to select yes or no, and it will ask you whether black or color is ok, once you have selected you're answer press Black or Color START to print another test page. Compare the 1st and 2nd test page if it's improving, you may need to do this 3-5 times or until you get a better quality
Hope this helps.
Rate if it worked Thanks!
Posted on Apr 03, 2011
How To Resolve Brother Printer Not Printing Yellow
Check the ink level
Start with checking the ink level in your toner. ... Since you have a problem with printing in Yellow color check Yellow or Magenta ink level. If its ink level doesn't appear, it could be an issue with either Yellow or Magenta cartridges. Two fix the issue, you can try to perform Clean Printhead.
https://windowsreport.com/printer-wont-print-yellow/
How Do I Fix Brother Printer Drum Error?
Toll-Free +1-866-231-0111 Brother printer receiving the 'Drum error'? Then, you have to clean the corona wire on the drum unit of your printer immediately to resolve the issue. Brother Printer users often face this common error but before calling the company for an instant tech-support, trying some steps can help to resolve the issue. Have you been facing the issue for quite some time and keep asking yourself How to Fix Brother Printer Drum Error? Then we here have some solutions for you. Follow the given steps and DIY resolving the error and see whether it's gone or not.
Step 1 Fix Brother Printer Error Drum
· Slowly open the lid of the printer and remove the drum unit
· Also, remove the toner cartridge assembly
· Keep a piece of paper on which the parts can be kept to avoid spilling of the toner
Step 2 Brother Printer Error Drum
·If the error Drum still persists, you have to replace the drum assembly.
·Consider resetting the Drum Counter
·Press the 'Menu' option> click on the 'Machine Info'> now click on 'Reset'
·Press Ok
·Now Press 1 to reset the drum unit counter
·Press Stop or Exit when
Brother Printer Customer Care Number +1-866-231-0111
If the mistake occurs, call for instant assistance at the Brother Printer Customer Care Number +1-866-231-0111. We are a 24 * 7 group of well-qualified and experienced engineers. We are willing to help you with your toughest printing mistake. Our techies strive to provide analyzed responses to all inquiries linked to the client
3answers
My Brother printer is offline. How can I fix this?
If you are incapable to print to your installed Brother printer because it is looking as offline, then you can change some of the printer's settings so that you can resume printing documents. Windows gives a built-in feature for toggling between offline mode, which can resolve many of the "Printer Offline" notifications that you are receiving from your Brother printer. But, if this option does not solve your problems, you may need to make some real differences to your printer connection to replace normal printing functionality.
Steps that fix Brother Printer Offline Windows 10:
1. Click the "Start" button at the bottom-left corner of your computer screen, and then click "Devices and Printers."
2. Right-click your Brother printer icon, and then click "See What's Printing."
3. Click "Printer" at the top of the window, and then look for a blue checkmark to the left of "Use Printer Offline."
4. Full Solution of error is here- Brother Printer Offline Windows 10
If Brother Printer Offline Windows 10 is not resolved, this might mean there's waste within the printer's inside. Call the customer services our check this Blog for a full solution.
ONE LAPTOP AND ONE PC. ONE BROTHER ALL-IN-ONE PRINTER. THE LAPTOP PRINTS PERFECTLY CLEAR. THE PC PRINTS IN DOUBLES.
1, After understanding the issue, there are a few steps by which you can resolve this. This issue is known as the Ghost printing, where it will print a single document twice.
2, To resolve this problem I strongly recommend you to use only genuine cartridges from the same company.
3, Each cartridge ensures you to provide good quality and high-resolution prints. Now, check if the printing sheets are compatible with the specification of your printer.
4, Use only unused printing sheets, with correct paper size and good quality. If you are not sure if the printing sheets meet the specifications for the device.
5, If the media is not suitable for the printer, perform a test print of 10 pages on the machine using regular 20 lb or 24 lb media.
6, If the ghosting is still present, continue to the next step. Open the rear cover of the machine.
7, Place the grey pressure release levers in the position. Clean the levers properly and try printing.
8, If you still not able to print then try servicing your printer.
For more printer related queries get in touch with our experts by just giving a call @ 1-866-293-9220.
2answers
Printing blank pages
If your Brother Printer is printing blank pages, then there is a possibility that you haven't installed the cartridges properly. Or, there is a clogged nozzle or print head issue. So, to get over this problem, one needs to clean up the device properly. In fact, you must reinstall the cartridges properly by taking the help of the manual. If you have lost the manual, you can contact the tech expert team of Canon Printer by dialing the Canon Printer customer support phone number. And, they will resolve the issue.
quick tips for cleaning brother printer head-dwucigzetafhok2xinisuklf-1-0.jpg
Brother MFC 420CN is not printing at all. It seems to not be recognizing the printer cartridges. How do I fix?
Here are the simple steps that can help you resolve the issue.
If your saying that the printer doesn't recognize the ink, try to remove and return the Ink cartridges. Then restart the computer. If still the same try to get the exact error messages in the LCD panel of the printer. If still the same try a different ink cartridge. And if the problem persist contact Brother support as it might be a hardware failure.
Hope this will help you resolve your issue.
thank you for choosing fixya
3answers
Brother DCP-110C printer not printing!
Clean the heads....................
found in printing preferences / maintainance
Not printing
Most likely you will need to follow the steps I found at:
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000700/000035/faq000735_000.html?reg=us&c=us&lang=en&prod=mfc420cn_us&Cat=16
This web page details the steps to take to resolve your problem with some colors not printing but others printing.
Norman  J Weimar Jr
Norman J Weimar Jr
Gary
Gary
