How to Troubleshoot Windows Update Error 80072ee2?
Posted by madison smith on
elisa martin
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 8 Answers
Windows Update Error 80072ee2 generally arises when you try to connect to the windows server for the purpose of downloading the latest updates and the system is unable to establish a proper connection. Here are the few Steps to fix this issue.
Steps to Troubleshoot Windows Update Error
80072ee2
Step 1: Check for the Internet connection
Step 2: Check for all accurate proxy and firewall settings
Step 3: Reset the system proxy server settings
Hopefully, you will be able to fix the bug on your own with the help of the above methods. For more information just go through the following blog.
  1. https://www.microsoftwindowssupportnumber.com/blog/how-to-fix-windows-update-error-80072ee2/
Posted on Mar 26, 2020
Attique-ur-Rehman
    Top Expert:
  • Computers & ... Master
  • 2,677 Answers
How to fix error 80072EE2 in Windows Update.
  1. Press Windows. + R keys to open the run command box.
  2. Type regedit and press Enter.
  3. In Windows registry editor locate the following key: ...
  4. Now right click at AU key and select Delete.
  5. Reboot your computer and then check for updates.
https://www.repairwin.com/windows-update-80072ee2-error-solved/
Posted on Mar 24, 2020
1 Related Answer
cafeerocks
Cafee Khan
  • 13 Answers
SOURCE: i want to check my phone updates but it is coming error as 80072ee2 why?
make sure Ur phone is connected to internet via strong connection,WIFI is preferred .
there should be enough space in the phone to install the update.
try restarting the device.
at last try factory resetting device (do take the backup first),then update ,will work for sure.
Posted on Apr 27, 2014
5answers
How do I fix windows error update 8 to 8.1 0x80070003?
copied from windows website.
Windows Update error 0x80070003 Applies to Windows 8.1, Windows RT 8.1 If you receive Windows Update error 0x80070003 or 80070003 when you use Windows Update, try running the Windows Update Troubleshooter.
2answers
Windowsupdate 80072ee2
if u cannot load https pages then try reinstalling ur ethernet driver
if u can load https pages the try using windows update after some time(20-30 min)
2answers
I want to check my phone updates but it is coming error as 80072ee2 why?
2answers
When i used to check updates......... it is coming erroe as 80072ee2
first try to check for updates using mobile network , then update thru wifi . sometimes , wifi shows error when u check for updates. i also experienced this same problem
Code 80072EE2
I found the fix for my system! Apparently, some manufactureers sent out images with a registry entry pointing to a specific Microsoft server to use for automatic updates. I went into the registery and found and deleted this entry:
HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows\WindowsUpdate\AU "UseWUServer"=dword:00000001
I looked at other systems, and they do not have a subkey named "Windows Update" in the "Windows" subkey. To be safe, I just deleted the "AU" subkey data entry which contains the"UseWUServer" keyword. Note: Setting the value to dword:00000000 does not work.
I'm running Windows 7 Home Premium, but this should work for any system with this subkey set and having a probloem with automatic updates
1helpful
2answers
I cannot sign in my messenger.it said that my contact list is not ready.it said i have an error 80072ee2.i cannot fix it.help
have you contacted the messenger web site about this type of error?
if not email them/ if so try reinstalling the program
Joining xbox live
If you were to call Microsoft they would tell you that this error code simply means to clear out the content on your hard drive and delete all the caches and it will work great!
That is true and that is what the error code means.
Now you don't have to wait on hold for that advice.
If you do have any other questions please ask us.
I hope I was able to fixya problem and Happy Gaming.
3answers
Windows update error 80240016
Could you download and run the program Dial-a-fix from http://www.softpedia.com/get/System/System-Miscellaneous/Dial-a-fix.shtml
I have tried this with many computers and it worked all the time.
Computers & Internet Logo
k24674
