SOURCE: roper washing machine roper rax7245kqo
more than likely something is jamming your pump now your coming up on the post with another user as having the same problem but its not the same kind of machine im getting ready to answer the first user who has a front loader and it may pop up to you so disregard that. Reply to this message and ill tell you how to check yours
SOURCE: My Kenmore Washing Machine wont drain or spin. Only a slight hum.
This problem is commonly attributed to a lid switch malfunction. If the model number you have this listed under is correct, the lid switch is mounted under the washer top casing, on the right hand side. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. The humming sound you hear when the lid is closed may just be the timer motor running. If your washer is not configured in this manner, please post back with your COMPLETE model number (located along the tub rim under the lid) so I can confirm how your washer IS configured. I hope this helps you.
If you determine that your lid switch is broken, please let me know and I will provide you with the steps necessary to repair it yourself (simple repair job). I can also give advice on where to purchase a replacement.
NOTE: Placing heavy objects on the washer lid can cause the lid to bow and also affect the way it contacts the lid switch.
SOURCE: washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
SOURCE: washing machine drains, wont spin, making clicking
If your washer won't spin, check these:
It doesn't pump or spin
If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
If
the motor is running, your washer probably has a frozen pump pulley or
a broken pump belt. To check the pulley, remove the pump from the
washer and try to rotate the pulley manually. If it doesn't turn
freely--if it's frozen or stiff--replace it. If the pump belt is broken
or looks quite worn, replace it--but be sure to check the pump pulley
before you change the belt.
If
the motor isn't running, the lid switch may be defective. If so, the
washing machine can't spin and may not function at all. The switch is
inside the washing machine main housing near the door frame. Often you
have to raise or open the top or front of the washing machine to get to
the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin
If your washer pumps out the water but doesn't spin, check these:
The
lid switch may be defective. If it is, the washing machine doesn't
spin. The switch is inside the washing machine main housing near the
door frame. Often you have to raise or open the top or front of the
washing machine to get to the switch. If it's defective, you need to
replace it.
The
motor coupler may be broken. Many Whirlpool®-manufactured washers use a
small, relatively inexpensive motor coupling. It's plastic and rubber
and is mounted to the shaft of the motor on one side, and to the
transmission on the other. Over time, the coupler wears out and fails.
You may need to replace it.
A
belt may be broken. Many washing machines have one or two belts. If a
belt is broken or badly worn, you need to replace it with a genuine
belt from the manufacturer. (Some washing machine belts are designed
with special characteristics not found in automotive belts.)
The
clutch may be worn. If your washer is a GE, it may use a clutch to come
up to the proper spin speed. As the clutch wears out, it may prevent
the unit from spinning well or at all. If the clutch is worn, you need
to replace it. For this job, you probably want to hire a qualified
appliance repair technician.
The
drive motor may be defective. Many washer brands use a reversing motor.
For agitation the motor runs in one direction, for spinning and
draining, the other. It's possible for a motor to burn out in one
direction and continue to operate in the other. If this happens, you
need to replace the entire motor.
The
spin bearing or basket drive may be worn or seized. These components
allow the inner tub to spin freely inside the outer tub. When this is
the problem, you usually hear a loud sound during the spin cycle. Call
a qualified appliance repair technician.
It spins only with the lid closed
For
safety, washing machines are made so that they spin only with the lid
closed. The lid switch prevents the spinning action when the lid is up.
