Question about Refrigerators
Bottom refrigerator crisper drawer PS123SGNA BS
Posted by Ms Whitworth on
Dorcas Melda
    Problem Solver:
  • 5 Answers
When students seek Business Research Writing Services, they are assured of receiving Business Term Paper Writing Services and Business Assignment Writing Services that meets all their writing needs.
Posted on Mar 24, 2020
5 Related Answers
22yooper
James Helmer
  • 828 Answers
SOURCE: Vegetable crisper drawer problem with food freezing
Absolutely lower the setting.
Posted on May 21, 2008
bruce harrod
  • 112 Answers
SOURCE: ice acculation under crisper drawers
No. There is, however, a drain hole in the back center that tends to get plugged. Remove the lower two drawers and see if it is plugged. It drains to a pan under the unitand behind the kickpanel
Posted on Oct 18, 2008
larryyb
Larry Youngblood
  • 291 Answers
SOURCE: Kenmore bottom freezer model freezes veggies in the crisper
i never go by that / just hold my finger over the air port and move it till i feel move air or less to set it the way i need it ,,, less air puts less air into crisper to cut down on freezing
Posted on Nov 26, 2008
SOURCE: the bottom crisper in my refrigerator is freezing everything....w
Look all the way to the rear of the control console in the fresh food compartment. Look up into the opening with a mirror. There should be a styrofoam diffuser (61005543) visible. If this is missing or damaged (many people think it packing material and remove it) it needs to be replaced. It spreads the air out rather than let it go right down the back wall to the crisper area.
One other thing to check is a tiny slot at the right rear of the same control console. a metered flow of air comes out the slot to the barrel shaped cylinder with the cold control capillary wrapped around it. Sometimes the slot gets water in it and freezes over. The unit will run too long and the cold air will settle during the off cycle and freeze items at the bottom. More often than not, when the slot freezes over, other items in the fresh food compartment will freeze......not just the bottom items.
Posted on May 03, 2009
chris weier
  • 82 Answers
SOURCE: Refrigerator has water under the crisper drawers
There is most likely a plugged drain in the freezer section. The easist solution can be to empty the refrigerator and unplug it over night. If this is not possible then the back or bottom should be removed to allow access to the drain and a hair dryer can be used to make defrosting go faster. still takes a while, if there is access in the back of the unit that can be the cause of the plug.
Posted on Jun 19, 2009
Bottom refrigerator crisper drawer slide fell off
draw slide is mounted to the shelf bracket --either order new bracket or remove bracket [look how slide positioned on other side ] and try drilling and putting in small screw and nuts till you can order a replacement bracket
Sep 09, 2016 | Refrigerators
Ge profile arctica model #ps123sgna bs, leaking water from fresh food side?
Plugged or frozen drain pan located under the evaporator (cooling coil), located in the freezer.
Aug 31, 2014 | GE Profile PSW26P Stainless Steel Side by...
Water collecting in bottom of fridge
Good Afternoon Friend,
I understand that you are receiving water at the bottom of your Frigidaire refrigerator, model# FPUI2188LF. What can cause this is either humidity coming from outside your refrigerator or maybe from the crisper drawers. Make sure your crisper drawers are set for a high humidity. Another thing that can cause moisture build-up at the bottom of your appliance is not covering your foods. Make sure that all foods and drinks are covered to cut down on moisture floating around inside your appliance. Hope this is helpful.
-Best Regards-
WP
May 15, 2014 | Frigidaire Fpui2188lf 21 Cf Top Mount...
Frigidare 1812 frig-water under crisper drawers
clogged drain line somewhere in fridge plumbing
Feb 21, 2010 | Refrigerators
I have water under the crisper drawers in my fridge. The water at the bottom on the ?condenser does not seem to be draining what can I do? Thanks Mary
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Clear the bottom of the refrigerator so you can get at the drain. Then get a turkey baster and fill it with hot water. Insert it in the drain in the bottom and squeeze it cleaning the drain. Several applications will solve the problem, and do not forget the freezer side as well.
Good Luck,
Gilshultz
Dec 01, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
Water collects under crisper drawers
Does it have darin at the bottom to drain out the bottom of the frifge into the drip pan? if it does push a wire threw the hole with the unit unplugged.
Aug 28, 2009 | Refrigerators
Refrigerator crisper drawers are freezing veggies
Shut the air flow into the crispers if you can. If not, turn the refrigerator temperature warmer by just a few degrees. The air into the fridge from the freezer is channeled into the crispers.
Jul 01, 2009 | GE PFS22SISSS Stainless Steel French Door...
Nov 26, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Water on the bottom shelf of the Refridgerator
Has the refrigerator got a wet inner back?
Ff this is wet, adjust it until this solid ice 'blobs', bt not encrusted, like in a freezer
The refrigerator may not be cool enough and the natural warm moisture allowed into the cool compartment when the door is open is condensing into fluid before it is cooling sufficiently to suspend the moisture as a vapour. If the cool compartment is cool enough, any warm air admitted ill be chilled before it is allowed to condense, keeping the refridgerator dry.
However, the only drawback is that you will have to monitor it to prevent the build up of excesive ice.
Also, whether the refridgerator is either empty of full willaffe the day to day operation.
Hope this helps.
Oct 20, 2008 | Whirlpool ET1FHTXM Top Freezer...
Kenmore elite fridge crisper drawer freezing stuff
If you have a side by side model you need to look at the refrigerator compartment wall on the left of the bottom drawer and move the slide control to the warmer/fruit/vegitable setting instead of the meat setting.
I hope this helped. Please rate my help or ask for more help please. supertechks
Apr 05, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerators Logo
23 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
