Https://forums.radioreference.com/threads/pro-106-scanner-help-scanner-stuck-on-one-channel.245676/
https://smallbusiness.chron.com/can-scanner-seems-stuck-61253.html
SOURCE: Radio Shack Pro-95 handheld scanner issues
Here is the online programming tutorial:
http://support.radioshack.com/support_tutorials/communications/200-0523/67345.htm
Here is the full manual Should include Quick guide:
http://support.radioshack.com/manuals/ome20-525.pdf
Here is FREE programming software for the PC:
Includes hardware info. You can buy programming cable at Radio Shack to connect to your PC.
http://www.starrsoft.com/freeware/win95/default.asp
SOURCE: stuck on scan mode
Hi, It sounds to me like your keypad is locked. Pg 63 of your manual.
***using the keylock ***
Once you program your scanner, you can protect it from accidental program changes by turning on the key lock feature. When the keypad is locked, the only controls that operate are FUNC, key , SQ, and VOL. You cannot activate the keylock while you are entering a frequency into a channel. To turn on the keylock, press FUNC then key . Key locked appears for about 1 second. Key locked appears when you press any key after locking the keypad.
To turn off the keylock, press FUNC then key . The scanner beeps three times and Key unlocked appears.
The only other choice I see if that does not work would be to initialize it. Pg 84 of your manual. Hope this helps you,, Mechanic
SOURCE: scanner wont scan
provided you turned the squelch know and it didnt help, i would trace back from the squelch control to the first and second transistor you come to and that should be the squelch circuit. if you know how to check them with an ohm meter you can find out which one it is, if not you can just replace them both for under 5 bucks.
SOURCE: I have a radio shack pro 94 scanner that gets
Getting "stuck" indicates that the scanner may need to be reset to restore proper operation. This is a fairly drastic step that will erase ALL information that you've programmed into the scanner, but it's about the only fix. To reset the PRO-94:
- Turn the scanner OFF
- While holding down the 2 and 9 keys, power the scanner ON.
- CLEAR will flash for about 5 seconds as the scanners clears its memory and restores factory settings. Do not turn the scanner OFF or press any keys until the CLEAR message stops flashing.
Need the manual for your scanner? You can download/print it here:
http://support.radioshack.com/support_electronics/doc61/61426.pdf
Bill B
SOURCE: scanner reads memory loss and is stuck on a police
This means that you have lost all of your programs all of your Frequencies are gone.You will to reprogram it.If you leave it unplugged for a long period of time it will do that.
