SOURCE: How to open front panel of washing machine?
ok on the GE spacemaker ,it's in the back.
there are two screws that you should open and then the front just comes off.
i tried the knife option at first and just ended braking the plastic clip.
SOURCE: Kenwood RXD-A53 CD player just rotates and doesn't load a CD
how long have you been using this player? The problem should be from the lens (laser).
The lens is weak and that's why it cannot read/load Cd's.
Get a lens cleaner and use it to clean the lens, but if the lens still does the same thing even after using the lens cleaner, then it means you would have to change the whole lens completely to a brand new one.
By so doing your player would play all Cd's with no problem at all.
Good luck.
Testimonial: "Super quick response, haven't tried the solution but I will, Thanx!"
SOURCE: Thomas Pacconi Model TPC-MSE-800 turntable
Pjam,
Had the same problem & checked around on the net. Several people tried replacing the belt, but it had no effect. Spoke w/ several repair shops around the country and they concur with what I'd read on the net - bad motors. 3 or 4 repair/supply shops told me getting a motor would be impossible. Since I only listen to 33-1/3 LP's, I messed around w/ it a little and found a solution. Take the turntable out of the unit & you will find a small circuit board attached to the bottom. On that board is a small square blue fixture w/ a white circular "dial" in the middle (has grooves to accept a small straight blade or a phillips screw driver). This controls the voltage to the motor, which in turn controls the motor RPM's. If you set the selector switch to 78, you can experiment /w turning that white circular "dial" to slow the motor down. It isn't very hard to get the speed set properly. The down side is that you will only be able to play 33-1/3 LP's, but they are probably the most common anyways. I assume you could do the same to set the speed for a 45, rather than a 33-1/3. Down side is that you will only be able to play 1 size LP on the 78 speed setting, but it's an easy adjustment that can keep an otherwise in-op turntable functioning. Good luck!
SOURCE: We have a Thomas Pacconi record player and the
TBirdMM, thanks for the advice. I was turning that dial this morning tweaking the rpms and it worked! Strangely enough I actually broke the white dial off, but when I spun a 33 on the 78 setting it played right on! Thanks!
Does anyone know why that dial only effects the 78rpm setting, and if there is a dial for the 33 rpm setting?
SOURCE: Acura tl cd player doesn't work, radio and cassette player work
why is the clock on the dash board showing the wrong time for the first 5 min . then it correct its self on my 2008 acura TL type s
