Ron, F60 is a general error code usually related to a failure on the video processing board. You could fix this by just replacing that board. Try to place it in standby mode first by unplugging it, wait a couple of minutes and then plug it back in. When the 000000's starts, hold down the power button for 15-20seconds. The unit should then be in standby mode. From this mode try to start it normally using the power button and see if it cleared the error. You could also try a complete reset by powering the unit off and press and hold the "Stop" and "Channel Up" buttons at the same time for a few seconds while powering the unit up. Hope this helps, good luck.
smallbusiness.chron.com > Finances & Taxes > Other Finances & Taxes
A standby mode problem on your plasma TV can result in the TV being stuck instandby mode, ... You can troubleshoot a standby mode error by performing a power cycle or restoring the TV to its factory settings. ... Turn the television on. ... What Does It Mean When My Rumor Touch Says the Camera Is in Standby Mode?
Description
Standby low temperature error
After reaching expected temperature in low-power mode (level 1) or standby mode, temperature fell and remained below 155°C for 20 seconds.
Causes
• Fusing thermistor defective • PSU defective
Dear
To reset the error, execute the following in service mode:
COPIER>FUNCTION>CLEAR>ERR.Ok
To Enter service mode.
Press the operation panel user mode key(or additional function key), 2 key, 8 key and user mode key in this order.
To exit test mode, press the user mode key (or additional function key),to return to standby mode or make power OFF and ON.
Do not enter other than the above if you are not sure.
i tried looking at the manual. and this is closest thing I could find.
550 9-22 A Standby temperature error 1-Fusing temperature failed to
drop to expected level within a given time (15 seconds, 15 minutes, or
25 minutes, depending on mode) after entering standby or lowpower mode.
try rebuilding the fuser. hope this helps. goodluck
The printer has a working mode and a standby mode. It could be going into the standby mode. Pressing the power button once, or sending it a print job will usually take it out of standby mode.
Most HP All in Ones will give a problem message on the screen. Your printer may have a more involved problem and you should go to the (hp.com) printers support page at HP. When you get the support page for that printer, type the error code in the search box.
If you are plugging it into the RJ45 Network connector (without a network) you may need to use the printer setup settings to tell it what type of connection to use ( USB or Network).
If the printer is connected to your telephone line and you are using a DSL internet connection you need to put a DSL filter on the telephone line going to the printer. The printer may be picking up DSL internet signals. Again the printer setup utility will ask you what type of connection you are using.
Hi, you have fixing trouble, to be specific E002 Insufficient temperature rise of the fixing unit. The non-contact thermistor fails to reach standby temperature (normally 190 deg C) within 180 sec after reaching 180 deg C.
Try to clear the error by entering service mode: press * Press the 2 and 8 keys of the keypad at the same time. press *
navigate trough service mode : COPIER>FUNCTION>CLEAR >ERR
If these doesnt helps, replace entire fixing assy, its most reliable way to get rid of complications.
Open my computer and right click on your local drive click properties click tools click check now remove check from Automatic fix file system errors start same with the more drives
