Question about Fossil Watches
Replace battery in fossil desktop motorcycle clock
Posted by Lisa Janelle on
Attique-ur-Rehman
    Top Expert:
  • Fossil Master
  • 2,677 Answers
Https://www.youtube.com/watch?v=BD3io5t5W_o
Posted on Mar 20, 2020
1helpful
What Battery do I use to replace the old one on a Fossil JR1157 Watch?
The owner's manual should say which battery to use. Otherwise, the only way to find out is to open the watch and see what type the old battery was.
Replace fossil big tic battery
Little battery operates the analog. big battery operates the digital second hand on the fossil big tic.
1helpful
How do I change the battery on fossil motorcycle clock?
You will need a very small (watch or glasses) Philips head screwdriver, and a SR626SW (or know as a 377) watch battery.
Remove screw 1 to remove the motorcycle back cover.
Remove the other 2 screws to take off the clock backing.
Remove the white plastic ring by pulling directly up.
Remove the battery.
Put the new battery in.
Press the white plastic ring back on.
Reassemble the clock backing with the two screws.
Reassemble the back of the motorcycle with screw 1.
May 24, 2012 • Watches
2answers
I have lost the battery for my Fossil Blue BQ 9039 watch. What battery number should I get to replace it?
To find a registered repair person in your area.
GOTO:
http://www.watch-clock-makers.org/
Hope this tip helps.
r/ David
http://antiqueclock.clockstop.com/
5helpful
I am looking for instructions on how to change the battery and how to set the time on a Fossil Limited Edition Airplane desk clock (# 54 on wings). Thanks!
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all Fossil watch manuals. Rate me, plz.
My Fossil watch worked when I took it off, it just needed a new battery. Now, I tried to replace the battery, and it won't work
Check that the battery is in the correct way up.
Try cleaning the battery with surgical spirit.
If these steps fail, take it to a watch shop.
If this also fails, find you nearest Fossil dealer (Fossil/customer care - store locator
2helpful
Broken digital clock
First of all visit the FOSSIL site from my tips and tricks. If you can not find the solution there, check out if you have two batteries in your watch. It is quite common to have two batteries in Fossil watches (same do Timex). If nothing helps, you have to visit your nearest watch repair shop.
I have an Abacus wrist net and the battery is dead. Where do I send it to get the battery replaced?
Most watch shops will replace batteries but you might need a Fossil dealer to replace yours, as it might need a special tool.
Try your local dealer first.
If you do need a Fossil dealer, go to "fossil.com"; at the bottom of the screen is a menu which includes "store locator". This will tell you where your nearest store is.
Watches Logo
Top Fossil Watches Experts
john h
Lisa Christine
Lisa Christine
Morris Lindsey
Are you a Fossil Watch Expert? Answer questions, earn points and help others
