SOURCE: no suction on Roomba 560
Larger debris is usually the responsibility of the brushes. Remove the bin and run the Roomba-- are the brushes actually turning? If not, call customer support for a new cleaning head module. If so, remove the grill from the back of the bin. Make sure that the little fan inside is clean, then reinstall the bin on the Roomba and run it. If that little fan doesn't spin, your Roomba has lost vacuum suction and you need a new bin.
SOURCE: Disassemble electrolux olympia one vacuum.
Before taking the machine apart, always check for clogs in the hose and power nozzle, full bag, and/or plugged hole under the bag. Suction/vacuum loss can also be caused by leaky or cracked hose, including the section in the power nozzle.<br /> The best way to check for clogs is simply drop a large marble in one end and let it roll through. To check for leaks in hose, hook to exhaust port, pour a small amount of liquid dish soap in other end of hose, lift high and turn on vacuum. Bubbles will appear at badly worn spots and cracks in hose.<br /> There is no need to pull out the motor, as their is no filter surrounding it, motor does not need lubrication, and the above check should result in locating the problem.<br /> Repair manuals are only available to Electrolux franchise owners as highly restricted software.
SOURCE: I have a electrolux Pronto 2 in 1 and the suction
There is a filter inside the main filter. Once that filter gets clogged it will loose suction. Pull the filter and clean it, you can wash it by hand. Turn the unit roller side up and check for a small screw cover that you can use a dime to loosen. This cover is used to remove the roller unit. Once out check and clean then check the gear assy. for miss-alignment.
SOURCE: Dirt Devil 086905 has suction
Need to take the head apatr as if you were replacing a belt. Look for the clog... it's there
SOURCE: brush inside main head doesn't spin, and stops
Sorry to hear you're having difficulties with your DC14. If the brushbar won't run when the cleaner is in contact with the carpet, it's probably best if you get in touch with us directly. One of our experts will be happy to run through some troubleshooting over the phone with you, and recommend the best course of action. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Customer Service
