SOURCE: need to remove agitator on
thank you for your prompt responce i did ring a local repair shop who was very helpfull and explained how to remove the agitator and put it back in . again thank you
SOURCE: how to take apart drum assembly on kenmore front load washer
Is this a HE2,5,4 model? Can you give me the model number from inside the door. If it's a front loader. The only way you can get it out is to totally tare it down, cement, springs, shocks, and crack apart the outer tub. Very very labor intense. Usually if the unit is out of warranty, the cost of a tech to do it isn't worth it. What's the issure with it?
SOURCE: Do I have a stainless steel drum in my washing machine?
If the drum is unpainted and a magnet is able to stick to it, the drum is steel. If there it is shiny and uncoated, more than likely it is stainless. Checxk web site documentation
SOURCE: Hoover 500M only washes on one direction
The Brake-arm under the washer needs to be replaced it is a white plastic moulded to steel (U) shaped artical connected to an electrical solonoid with a split pin it is either cracked or the nib is broken off where it locates plastic cog on the main shaft assy.Hope this helps.
SOURCE: (Kenmore Elite Oasis 27087 Stainless Steel Top
No!! Don't get it! We have had the machine for a few years and have had several problems with it. We constantly get error codes when its mid cycle and it won't complete the cycle. I have actually gotten to know my Sears repair man he has come out so many times. Our current problem is that small items of clothing slip through the crack when we are unloading the machine. They are then trapped under the drum and cause problems including major mildew smells and eventually the machine stops working, The repair man comes out and removes the drum, pulls out the mildew sock or whatever and then its ok. Very poor design!
