SOURCE: source picture changing by itself
It's interesting I unplugged everything and it sat for a few days. I plugged everything back in and it works like normal again. It's been fine for about 4 or 5 days now. I will try what you suggested if it messes up again. But just to be clear, did you mean to try to press the buttons on the TV repeatedly? or the remote buttons?
Thanks for the advice
Check if the remote is in TV position, that is, because most of the remote controllers have the feature that you can program them for use with another devices. Make shure that one button that says "TV" in pressed and released once before you try to change any function on the TV.
SOURCE: No TV "Select Source" Menu Option
Had the same problem and found on the back of the tv on the black box that the cable hooks to there is a plug at the top of that box on the left side came loose. If you slide that box to the right you can completely remove it from the tv. Reinstall it and make sure it's plugged in tight your tv setting should come back.
SOURCE: i hit source button-no tv
You will have changed the inout signal on the Tv to either HDMI input or EXT1 , or AVI. You need to keep pressing the source button until you reach TV again, or...press the TV button (depending on what tv you have) :)
SOURCE: My Sony bravia klv-32u300a can
how do i find power supply board for sony klv-32u300a in dubai
