Question about Home
My braun thermometer 6022 just keeps flashing and won't reset. I have new batteries in it too. How do I get it to work properly?
Posted by Mila Hoban-Munden on
Ngoro
    Top Expert:
  • 2,715 Answers
5 Related Answers
Anonymous
  • 8 Answers
SOURCE: I have a Braun Thermoscan
... call Braun ThermoScan customer service at 1-800-327-7226
Posted on Feb 19, 2011
Anonymous
SOURCE: I have a Braun thermoscan type 6022, but code po5
It's not po5, its pos... you're not positioning it properly in the ear canal.
Posted on Feb 21, 2011
jfmagnusson
  • 8 Answers
SOURCE: We have the Braun 6022
If you whish to switch from Celsius to Fahrenheit, proceed as follows:
(1) Make sure the thermometer is turned off.
(2) Press and hold down the Start button (IRT 4020)
or the «I/O» button (IRT 4520). After about
3 seconds the display will show this sequence:
«°F» / «SET» / «°C» / «SET» ...
(3) Release the Start button / «I/O» button when the
desired temperature scale is shown. There will be
a short beep to confirm the new setting, then the
thermometer is turned off automatically.
Posted on Mar 17, 2011
jfmagnusson
  • 8 Answers
SOURCE: I have a braun thermoscan 6022 after it displayed
Ambient temperature is not within the allowed operating range (10 - 40 °C or 50 - 104 °F).
Allow the thermometer to remain for 30 minutes in a room where the temperature is
between 10 and 40 °C or 50 and 104 °F.
Here is a link to the manual if you should need it:
http://braun.kaz.com/files/IRT33020COGB,%20F,%20E,%20P.pdf
raegirl186
Ralyn Hunt
  • 25 Answers
SOURCE: The digital thermometer was flashing
there should be a setting on it that changes the temp from Celsius or "c" to ferinheight and lo means that it currently isn't reading a temperature in the normal range. try running it under hot water and see if it says error or high.
Posted on Jul 15, 2011
Braun thermoscan 6022
It's probable that it needs a new lens filter or the filter needs cleaning. I have no idea how to remove the filter but it probably clips or screws off the bit that goes in the ear.
Quite frankly the device is at best unreliable, it measures infra-red in the ear, great in theory but not very reliable in practice. I would use a different thermometer.
May 15, 2014 | Home
We have the Braun 6022 thermometer. It is reading in C so temps are coming up (ex. 37.1 C) how do we get it back to F
Mar 04, 2011 | Braun Thermoscan Pro 4000 Ear Thermometer
Can you change the temp reading from F to Celcius on a Braun Thermoscan 6014?
Turn off the thermometer
Press and Hold the L/O Button
Continue to hold the start button when the F or C display appears. Watch for these displays to cycle over the display window.
Release the start button when the F display appears on the screen.
5
Listen for a beep and watch for the Braun ThermoScan ear thermometer to shut itself off, indicating that you changed the temperature scale to Fahrenheit successfully.
6
Follow the same procedure but release the start button when C shows on the display to switch from Fahrenheit to Celsius.
Feb 28, 2011 | Braun Health & Beauty
I have a braun thermoscan 6022 after it displayed '"Err'" I replaced the batteries and it wont turn turn on ? I checked the batteries and they are good. Tried holding the on off button for ten...
Feb 22, 2011 | Braun IRT3020 Thermoscan Ear Thermometer
I have a Braun thermoscan type 6022, but code po5 always comes up. What does that mean?
Jan 26, 2011 | Braun Health & Beauty
Home Logo
78 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
