Freezers Logo
Tri-R Mechanical Posted on Mar 16, 2020
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need to know the age of my Traulsen freezer Model G22000 Serial T78014104
Terry
Level 3:
  • Traulsen Master 11,377 Answers
  • Posted on Mar 16, 2020
Terry
Traulsen Master
Level 3:
Answers
11377
Questions
Helped
4619886
Points
152765
The telephone number of the manufacturer is on their web site.
You can call them to request assistance.
https://www.traulsen.com/service/owners-manuals
I am not typing their phone number here because so many fraudulent1 scammers post on FIXYA, so beware.
3 Related Answers
Anonymous
  • Posted on Nov 24, 2008
SOURCE: traulsen ur 48 dt freezer want go below 10 deg
The first place to look is to check the charge. Using guages check the low and high side pressures and their relationship to one another. I'm assuming your unit is a R-404 unit which, if fully charged and the condenser is clean, and the fan is operating, should have about 210 to 250 high side pressure. Other things to check: evaporator coil ice/frost free; defrosting properly to obtain a clean coil; all evaporator fans running. If low side pressure is above 30 PSI you have a weak compressor. Whatever, fix the Traulsen unit, its head and shoulders above anything else on the market today.
Anonymous
  • 3600 Answers
  • Posted on Nov 11, 2009
SOURCE: How to find age of freezer
You can go to this web site and call them or put your model in and it willl give you date of manufacture. It should be on the back of the unit on a plate that is rivitoed on or on the inside of the door pannel. heres the site.
http://www.traulsen.com/products/refrigerators-freezers/
Dennis Boxerman
  • 1306 Answers
  • Posted on Feb 28, 2011
SOURCE: I have a traulsen G22000 freezer Serial #
https://feg.hobartcorp.com/resourcecenter/ProductDocumentation/TR35748%20G-Manual%20(3-09).pdf
Try this site.If you can not access this, let me know and I will try to email to you this manual. It has info on your controller and programming.
Traulsen G sereis 2 door freezer keeps running past set temp of "0" degrees keeps freezing all the way to -35 degrees and I have to shut it off to keep it from running? any advice??
It basically sounds like the temp sensor is not sensing the box temp that the control functions on. Other wise, the control may be stuck. Traulsen seems to have a fairly descent tech support line. Call them for steps on how to read the controller.
Traulsen wiring diagram
for what model? serial number helps too.
Where can i order a door gasket for traulsen g22010
try Rick at "Restaurant Parts and More". They will need model and serial to get what you need. 1-888-814-1110. That is where I get my parts from.
1helpful
Compressor runs but internal fan isn't working, switch appears good what do I need to check regarding the fan?
Check to see if there is correct,complete power to the fan. If not, look for a fan delay that may be attached to the evap. It comes in many configurations. It may have two or three wires going to it. They may be two black wire or 3 wire of different colors. Power goes to the fan thru this device. It may not be working or the evap not getting cold enough to activate it. I will need model and serial to help more.
Let me know what you find.
Model g22012
If its the digital display with I think 2 or 3 buttons, then you cannot re-program the control.
It is factory set and I have never been able to get any clear answers from Traulsen on the steps to re-programming it for a different setting.
Best advice I can give you is to contact Traulsen directly and ask for tech support. Once you get them on the phone, explain that you just purchased this cooler/freezer and you need a control that suites your needs. They should have one that is pre-programmed to your needs.
Nov 11, 2009 • Freezers
2helpful
How can I get the wiring schematic diagram for a two door stand up traulsen freezer model # GLT 2-32 NUT, Thanks Erick.
call traulsen at 1-800-825-8220. Get tech support and give them the model and serial numbers. They will send you a diagram. Nothing on their web site.
Top Traulsen Freezers Experts
deton8 von Splosion
Douglas Makokha
Level 1 Expert
Are you a Traulsen Freezer Expert? Answer questions, earn points and help others
