Question about Ricoh Office Equipment & Supplies
SOURCE: Ricoh copier MP 6000 error code
THIS IS USUALLY FOR THE FUSER SECTION IT MAY BE THAT SOME TONER HAS BUILT UP ON THE THERMISTOR AND IT AINT READUNG THE TEMP PROPERLY AT WARM UP OR ON A RUN IT HAS TO OVERHEAT TO GET RIGHT READING TAKE THE FUSER OUT CHECK THE THERMISTORS.. YOU COULD ALSO GO INTO THE SERVICE MODE VIA CLEAR ALL THEN 107 AND HOLD DOWN THE RED STOP BUTTON TILL THE SCREEN CHANGES IF YOU LOOK FOR COPIER SP IN THE FEED SECTION THE FUSER SETTINGS ARE THERE YOU CAN OPEN FUSING TEMP AND CHECK THE TEMPS AT THE TIME TO SEE IF THEY ARE RIGHT.. IF IT SEEMS RIGHT IT MIGHT HAVE BEEN A READ ERROR AND BY GOING INTO MODE AND LOOKING FOR 5- 810 YOU CAN RESET THE SC TURN OFF AND THEN BACK ON IT SHOULD CLEAR... GOOOD LUCK A
Posted on Jun 26, 2009
SOURCE: I have a Ricoh MP C2500 Copier and I can not
Your touch screen went bad. This is a common problem with many newer Ricoh models. Get in touch with your service technician to get a new screen.
Posted on May 26, 2010
SOURCE: Ricoh MP C2500 Error Code SC 561 what is this?
sc561 on an MP C2500 is a thermopile error. The thermopile may need to be replaced, but first make sure it is connected properly and hasn't been moved or loosened.
You'll need to go into service mode and execute SP 5810 in order to clear the sc561 code.
Posted on Jul 04, 2010
SOURCE: Problem with the Ricoh mp c2800 Ricoh error code
If the model ia a MPC 2800 it a controller board issue maybe the operation panel. -carl
Posted on Nov 15, 2010
SOURCE: My Ricoh Aficio MP C2500
The red streaks are caused by the red drum transferring way more toner than it should. Cleaning it is easy, you can do it no problem at all - all you need is a lint free rug, some pure alcohol and one hour of your time. The access is easy, no tools required and the exact procedure is in the manual.
The drum looks like that
http://www.precisionroller.com/drum-units-for-ricoh-aficio-mpc2500/products.html
The manual, if you no longer have it, can be found here
http://support.ricoh.com/bb_v1oi/html/oi/rc2/model/mpc25/mpc25en.htm
But to be honest i doubt that it will work: the drum picks so much toner because its surface has lost its sensitivity and it can't no longer generate the image correctly when struck by the laser. Most likely you will have to replace it.
Posted on Dec 17, 2010
May 24, 2016 | Ricoh Aficio Mp C2500 Color Laser -...
Feb 05, 2016 | Ricoh Office Equipment & Supplies
Apr 21, 2015 | Ricoh Aficio Mp-1600 Copier
Dec 01, 2014 | Ricoh Mp C2500
Sep 01, 2014 | Ricoh Aficio Mp C2500 Color Laser -...
Jan 15, 2014 | Ricoh Aficio Mp C2500 Copier
Jan 05, 2014 | Ricoh SR 790 - Finisher - 1000 sheets -...
Jul 03, 2012 | Ricoh Aficio Mp C2500 Copier
Jul 02, 2010 | Audio Players & Recorders
63 people viewed this question
