Question about Garden
Hi as any one got a diagram of deck belt assembly for taro wheel horse 212.5 as i need to replace mine and im not sure which way it goes on
Posted by Neville Kelleher on
5 Related Answers
Anonymous
  • 35 Answers
SOURCE: Broken teeth on drive gear wheels Taros paper shredder Taros 31.8
New gears are $88.50 plus freight. You won't find any used gears because these usually break first. I can help.
Posted on Feb 23, 2009
Anonymous
SOURCE: Spring Horse
You can go to the Radio Flyer website and download the assembly instructions.
Posted on Apr 18, 2009
Dwain Pippen
  • 376 Answers
SOURCE: deck belt diagram
Go to ... http://www.partstree.com/parts/ Then click on Cub Cadet, enter the model number on the left that is under the seat and all the different diagrams are there. Click on Mower Deck.
Posted on Jun 29, 2009
Dwain Pippen
  • 376 Answers
SOURCE: diagram of mower deck
Go to... http://www.partstree.com/parts/ Then click on Cub Cadet, enter the model number then all the diagram are there.
Posted on Jul 04, 2009
Anonymous
  • 90 Answers
SOURCE: belt diagram
You can find the diagram here:
http://lawnandgarden.manualsonline.com/ex/thread/view/idThread/340092
Posted on Aug 03, 2009
Belt diagram install
seems like everyone does but no one knows there model number... darn
Aug 25, 2014 | Toro 3 Standard Blades For Wheel Horse 50"...
Need diagramof ground drive belt asembly
I just put a new one on mine. Your owner's manual has a diagram. Should be a diagram on the deck close to right rear wheel.
Aug 06, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Wheel horse
TOMBONES49 is there anyway I can contact you or you contact me regarding a diagram you posted of a 1982 yamaha xt250 carb? I am currently going through one of these bikes and need to fine tune the carb but cannot find any info anywhere. You were the only diagram I found all over the net. My email is MarlinsMcnasty @ yahoo DOT com (figured the site wouldnt let me post it) or maybe reply on here? Im not exactly sure how to use this site but you seem to be the mechanic man!!! THANKS AND GOD BLESS
Apr 28, 2013 | Garden
I need a diagram on replacing a deck belt on my huskee 21 horse power 46inch cut riding lawn mower model # 13AT688H731
Many of these machines have a belt route schematic on the underside of one of the foot rests
Jul 28, 2012 | Garden
My toro 212-5 mower keeps spitting off the deck belt
You may need a new one. If that doesn't work you may have a bent pulley that's cause it to jump off or the barrings in one of your pulleys may be bad which would cause the pulley to wobble therefore throwing the belt off.
Jan 31, 2011 | Toro Wheel Horse Drive Belt For Tiller...
Need a belt routing diagram for wheel horse raider 10 lawn tractor
have a raider 10 in gravenhurst with a deck sticker that shows the belt routing......if you still need the diagram, let me know
Jul 14, 2010 | Garden
Install belt on toro mower model 70041
For removing/replacing the deck belt, the general method is:
  1. turn off engine, remove key and set parking brake
  2. disengage blade by putting blade engage lever into off (disengaged) position
  3. lower the cutting deck to the lowest position (closest to the ground)
  4. relieve the belt tension (depending on the model, use a 3/8 inch ratchet set to tighten in the square hole of the idler bracket)
  5. remove and replace the belt
NOTE: it's not necessary to completely remove the cutting deck.
Useful diagrams for removing the cutting deck, http://216.213.143.2/ProAuthor/ManProc.cfm?ManualID=425&ProcID=14794
For deck belt diagrams, http://216.213.143.2/ProAuthor/ManProc.cfm?ManualID=425&ProcID=14796
If the transmission drive belt needs to be replaced, several components must be removed and special tools (i.e. air/impact wrench) used in order to change the tractor's transmission drive belt. See an Authorized Toro Service Dealer to have your drive belt replaced.
Sep 09, 2009 | Toro Lawn Mower With Toro Power Tools
I have a mtd 13.5 horse 38 inch cut 6 speed its around a 2007 or a 2008 i need to se how all the belts go on the mower deck and drive
Most mower decks have the diagram on them, if not go to MTD.com and put your model number to see the diagram.
May 02, 2009 | Mtd LAWN MOWER PART # 683-04163B FRAME...
Garden Logo
74 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
