Fisher and Paykel Dishwasher Dishdrawer Error Code E5 = The first 3 program indicator lights are flashing. Error Code Cause: Water supply hose is crimped or bent. Drain hose is too low. Water tap not turned on. Not enough water supply pressure.
https://removeandreplace.com/2016/06/07/fisher-and-paykel-dishwasher-dishdrawer-error-codes-and-troubleshooting-how-to-fix/
Posted on Mar 22, 2020
SOURCE: Hi what error F5 means in a white whale dishwasher ?
The F5 code means that the machine is not draining. Either there is something blocking the drain line or the drain pump is defective. I would first check the outlet where the drain line atttaches to. Take the drain ho9se off the syphon gap or trap and see if the water will drain out of the machine into a bucket. If it will you need to clear the trap or syphon gap where it connects to. If it will not there could be something jammed in the drain pump or the drain pump on the machine could be bad. You would have to remove the lower kick panel and access the drain pump where the drain hose connects to get it out and check it for damage or obstructions.
Posted on Nov 02, 2016
SOURCE: What's error code 4 in white whale dish washer?
Dishwasher Error Codes Fault Codes For Dishwasher Repair ..not saying this will help your model but have a look it might help you out.
Posted on Dec 01, 2016
Hi friend, I appreciate your post!
I understand that your Electrolux refrigerator is showing an "E5" error code and not cooling. "E5" typically stands for Showroom mode, you can press and hold the "Up" and "Down" keys simultaneously and that should restart your refrigerator back to normal operation. Could you reply back if that corrected the issue? Thank you. -Matt
