Question about Measuring Tools & Sensors
It says no weather service on my weather station model #c82929
Out door tem does not show when i push on the sensor it says no weather service
Posted by Mavis Gruba on
Andrew Taylor
    Top Expert:
  • 33,348 Answers
Change the batteries on both units. The home station often has a good display, but not enough power to communicate. I buy CR2032 in packs of 10!
Posted on Mar 15, 2020
Manual for Eddie Bauer Radio Controlled weather station 802R25?
Hello, Denise -
I have not found a manual online for the Eddie Bauer Radio Controlled Weather Station 802R25 yet.
Therefore, I suggest you contact the Eddie Bauer company directly and ask about the availability of an owner's manual / instructions for that model of weather station. See the Contact Us information for Eddie Bauer here:
http://www.eddiebauer.com/custserv/customer-service-landing.jsp
The Customer Service contact information will be found in a far right column.
Note: Even if that model is no longer being manufactured, ask if a manual for that model is in the company Archives and ask if a copy can be scanned as a PDF document (Adobe Acrobat Reader software - free) for you. There may be a cost for a manual.
Best wishes.
Jun 17, 2018 | Measuring Tools & Sensors
Batteries for ws 1000 weather station
Search Results
Ambient Weather WS-1000-BATT 3 x AA Rechargeable Batteries for ...
https://www.ambientweather.com/amws1000batt.html Ambient Weather WS-1000-BATT 3 x AA Rechargeable Batteries for WS-1000-WiFi, ... Buy weather stations, wireless weather stations, emergency radios, ...
Ambient Weather WS-1000-WIFI, WS-1001-WIFI, WS-1002-WIFI ...
https://www.ambientweather.com/amwewswestre.html Buy weather stations, wireless weather stations, emergency radios, barometers, ... Ambient Weather WS-1000-BATT 3 x AA Rechargeable Batteries for ...
[PDF]Ambient Weather WS-1001-WiFi OBSERVER Solar Powered Wireless
site.ambientweatherstore.com/Manuals/ws1000wifi.pdf The WS-1000-WiFi weather station consists of a display console (receiver), an all in one sensor ... Locate the battery door on the bottom of the sensor array.
Ws 1000 weather station batteries Google Search
May 26, 2018 | Cars & Trucks
Lidl/Auriol Z31601B-RX weather station
1 Weather station
1 Outdoor sensor
2 Batteries, type LR06, 1.5 V
2 Batteries, type LR03, 1.5 V
1 Set of operating instructions
Note:
First insert the batteries in the outdoor sensor, then the weather
station.
http://www.lidl-service.com/static/58242588/91679_en_da.pdf
Jan 02, 2018 | Televison & Video
I have the Atomic Clock model W86111. I had to change the batteries on the outside device. The clock outside temp just flashes 63.5 all the time. How do I make it sync to the device outside?
Remove all batteries from outdoor sensor and weather station.
Press one of the buttons on the weather station at least 20 times to clear all memory.
Verify that the weather station is blank before proceeding (there may be lines painted on
the screen that will show when power is removed).
Leave both units without power for 15 minutes (very important).
Insert fresh batteries into the clock.
Insert fresh batteries into the outdoor sensor.
Press the TX button on the outdoor sensor to transmit RF signal.
Keep the outdoor sensor 5-10 feet from the forecast station.
When RF connection is established, the temperature will appear on the station. Allow the
outdoor sensor and weather station to sit together for 15 minutes to establish a strong
connection.
Oct 14, 2017 | Home
Changed the batteries in both the transmitter and weather station. It doesn't show temperature on the transmitter or show temperature and humidity on weather station
In some of these weather stations, you have to install the batteries in the transmitter first and then the weather station within a certain time limit. Also, the weather station must be within a specified distance from the transmitter when replacing the batteries.
If you look on the weather station, there should be a make and model number. If you have that, you can visit the website (if there is one) and download an instruction booklet for your model.
Jul 21, 2015 | Measuring Tools & Sensors
Outdoor temperature on indoor station showing - -.
Check the battery in the outdoor unit, resync them per the instructions, if that does not work check for interference.
Jun 23, 2015 | Equity Time USA 31215 Wireless Outdoor...
What does HH.H stand for on my Flink weatherstation KW-9007W Sensor stand for ? and how do I cure it?
According to the manufacturer, that error code is "The main unit has lost the signal to that particular sensor and the whole unit needs to be reset and the memory needs to be cleared. Please follow the user guide to clear the memory and refer to question 24 for instructions entitled "how to re-calibrate my weather station with my sensors".
Apr 28, 2014 | c22m125 cyk f/link am cat 125 amp
Cannot get the weather station model ws-916ou-it to show outside temperature
I have three of these WS-916OU-IT units. After a few years, the outside sensor just fails. You will get dashes and a "TR" low battery signal, even if the batteries are good
just buy another whole weather station (short money) and set both the old and new weather station unit to receive from the single new outdoor sensor.
To do this - just follow the procedure for a single sensor - that is - put the batteries in the new sensor - then within 30 seconds - put the batteries in all the weather stations - they will all pick up the same outdoor sensor.
I now have three units running off of one outdoor sensor.
Seems a bit silly, but it works.
Feb 27, 2012 | Measuring Tools & Sensors
The weather Forecast Icons don't change on my honeywell weather station model # TE852W
This problem could arise due to various reasons
1)Replace the batteries in remote sensors
When the batteries are properly installed, the remote weather sensor will resume sending signals to the main unit.To enforce an immediate remote signals search, press and hold
DOWN on the main unit.
2)Remote thermo-hygrometer sensor could be weak in sending the signal about weather Forecast.Test it properly.
3)Reset the unit and check
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Sep 11, 2010 | Honeywell TE852W Weather Forecaster With...
Measuring Tools & Sensors Logo
85 people viewed this question
Top Measuring Tools & Sensors Experts
Marvin
Marvin
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
