Canon VIXIA HG20 DVD Blu-ray Camcorder Logo
Posted on Sep 19, 2009
Same problem I hooked up my canon hg vixia hg20 after installing all drivers from the disks, and the computer still did not recognize the camera. I then searched on the web under 'canon vixia hg20 driver' and sure enough, there are driver updates. download those and see what happens.
Anonymous
Level 1:
  • Contributor 34 Answers
  • Posted on Sep 19, 2009
Anonymous
Contributor
Level 1:
Answers
34
Questions
0
Helped
13941
Points
94
You are restarting your computer after install right.
You should be installing the software with out the camera connected9or the usb cable) shutting computer down/ connecting the camera and cable , and then restarting the system.
If you are doing it any other way the computer will not recognize the camera......you are confusing the system
Camera broke, beyond repair, will not power on (by battery or AC adapter) is there any way to retrieve the videos on the INTERNAL memory (NOT SD)?
Can I recover deleted videos from Canon Vixia? '
www.device-recovery.com/recover-deleted-videos-from-canon-vixia.html
May 14, 2012 - Canon Vixia video recovery, how to recover deleted HD videos, photos from all ... Still panic and wonder if there is any way to recover those deleted, formatted and lost files? ... Scan lost files on Canon camcorder/memory stick.
Recover Lost Videos from Canon Camcorder on Mac OS X ...
www.easeus.com > Mac Data Recovery > Card Recovery
Any one knows how to recover lost videos from Canon Camcorder on Mac OS X? ...Many users like to save the recordings of Canon Vixia HG20 on the internal ... a powerful Memory Card Recovery Software is your best choice when you lost
tip
Flawlessly solve questions-Canon HG20 MTS to iMovie 9 with retain best quality
Flawlessly 1080/60i MOV for iMovie-Converting Canon HG20 MTS files to AIC MOV for iMovie
I have a Canon HG 20 with an internal 60GB hard drive. I am using the Mac OS X 10.6 Snow Leopard and iMovie 09. The apple website says that this camera is compatible with iMovie and even sells it on it's website. When I open iMovie and import the .mts files to iMovie, it prompt an error. After google search, found if I want to edit Canon HG20 1080/60i .mts video with high quality for iMovie 9 on Mac, must to convert Canon HG20 1080/60i .mts files to MOV for iMovie 9 before editing.
And as we konw, Apple Intermediate codec is one of the apple built-in codecs, while others could be Apple DV/DVCPRO - NTSC, DVCPRO50 - NTSC.So convert hg20 mts to aic mov is the best choose. Therefore i need mts to aic converter. Aunsoft Final Mate for Mac is the recommended camcorder software to convert AVCHD to apple compatible formats.
Here is the step-by-step guide to quickly convert Canon HG20 MTS to Apple Intermediate Codec 1080/60i (*.mov) with highest quality for editing in iMovie 9 on Mac.
Step 1. Directly download 24Mbps .mts files from Canon VIXIA HG20 to Aunsoft Final Mate for Mac.
Turn on Canon HG20 camcorder and connect it to computer via USB cable, then launch Aunsoft Final Mate for Mac from Application folder. With built-in wizard, you can easily to capture Full HD .mts files from Canon HG20 camcorder to the program. Select "Import" instead of Backup to quickly capture videos from camcorder. You can find imported videos under "Camcorder Tab" in the main interface of Final Mate for Mac.
Step 2. Create a Movie for Converting Canon VIXIA HG20 MTS files to AIC MOV.
Just select one or multiple video files you would like to convert and then drag and drop them to Movie tab. In this way, a Movie for conversion will be created.
Step 3. Export AIC MOV video file.
Click the Export button and choose iMovie and Final Cut Express > Apple Intermediate Codec (AIC) (*.mov) to choose export format for further editing in iMovie. In this way, all video clips will be merged as one single movie for convert to iMovie.
Tips: You are free to set/adjust output MOV files parameters (Bit rate - high quailty, Frame rate - 60, Resolution/Size - 1920 x 1080, channel - 5.1 channel) to make a good output quality. With this set you can get a Flawlessly 1080/60i MOV for iMovie.
Step 4. Click OK to start converting.
Click "OK" to start converting Canon HG20 MTS files to AIC MOV for iMovie .When the conversion is finished, you can import converted mov to iMovie without rendering and edit high quality videos from Canon Vixia HG20 24Mbps mts on iMovie Mac.
Tips: The Canon VIXIA HG20 boasts 1920 x 1080 Full HD, and has a CODEC capable of recording 24Mbps -- the highest AVCHD bitrate --through Canon's own Full HD CMOS Image Sensor and advanced DIGIC DV II image processor. Final Mate for Mac also can lossless split/cut and join/merge Canon HG20 Full HD MTS on Mac with no compression.
Canon Vixia HG20 broken cable to view screen
Had the same problem with my HG20. Couldn't find a way to remove the housing and Canon won't tell you how to do it. I sent it in to Canon and it cost me $250 to fix it. You already have the cable so it might knock off a couple bucks. It's crazy what you have to pay for a camera to be repaired that's no longer under warranty. But you gotta do what you gotta do sometimes. The service is great though. I sent mine in and they paid the shipping to and from their office. I got it back within a week of sending it in.
My computer do not recognize my canon vixia hf20 double click on my computer icon : computer do not recognize the camcorder canon vixia hf20
Be sure that you have installed he driver correctly ..and the cable is well plugged...,another thing to check is the camera's display and see if it asks for a connection confirmation in the moment you plug it in ...if it does..choose PC connect ..and after that will work ..
also check into the device manager and see if the camera is present there ..even if it appears in yellow with an ask sign on it ...this meaning that the driver is not installed or damaged or not the proper one..
http://software.canon-europe.com/products/0010719.asp
select the operation system ..download ..reinstall and go for it ...but first check what I suggested..
1helpful
2answers
Capture video from Canon Vixia stopped working with iMovie
Video files come from Canon Vixia hg20 are in AVCHD format and this is a format which is difficult to be imported and edited by FCP and iMovie. So you have to convert AVCHD files to other easily edited video format, like FCP and iMovie preferred MOV format.
As for AVCHD Converter, have a try Aunsoft MTS Converter for Mac which is is a powerful video converter, player, editor for Mac and Windows. It can play many various movie files; it can encode movies to many formats, including iPod; it can cut, trim and join movies.
You can use this program to open and play most movie formats transport streams; edit them with crop and Trim;export them to QuickTime, AVI, DV and MPEG-4 files with more than professional quality, so you can easily import them in a DVD authoring tool, and use them with many other applications or devices.
http://www.aunsoft.com/mts-converter-mac/
Workaround needed to import video from Canon HG20 into Studio 12
With advanced HD (High-Definition) video conversion technology, HD Video Converter can easily convert among HD video formats, convert video to HD, convert HD videos to SD (Standard-Definition) videos. The HD video converter supports most of HD video formats such as AVCHD (mts, m2ts), H.264/AVC, MKV, MPEG-2 (ts), DivX, HD WMV, MPEG-4 and Quick Time.
4helpful
3answers
Imagemixer3 install won't take serial number when installing for Canon VIXIA HF100
Had the same problem with my HG20. My serial number had 12 numbers and two letters, and I had to omit the letters. Just enter the numbers. Hope this helps.
Top Canon Video Cameras Experts
NOEL
NOEL
john h
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
