Question about Power Computers & Internet
Disconnected it from sever
Posted on Mar 15, 2020
Did you disconnect the actual it andpower at the source, and wait. Then reconnect the power, this should reset it, and let you start out new.
Posted on Mar 14, 2020
SOURCE: Pioneer GMH100 Amplifier
If you don't need the OEM plug, you can use the type of connector used to connect to the terminals of a speaker. You will have to tighten the terminal slightly but one terminal will span the remote and acc pins and will allow you to use the amp. You don't need to apply power to the 'ill' pin of the plug. Be careful with the pins for the plug. The amps are known to having weak connections that break easily if excessive pressure is applied to the pins.
Posted on Jan 08, 2008
SOURCE: asus MB av7333 x
Hi fgs2, the manual will walk you through setting up the board including the CPU, memory, connecting case leds. (Everything).
Download your Asus A7V333-X manual from Asus web site by clicking on the the link below. (You might want to save the link).
http://support.asus.com/download/download.aspx?modelname=A7V333-X&SLanguage=en-us
Good Luck! Take your time.
Have more questions, feel free to ask.
Mike
Posted on Apr 04, 2008
SOURCE: pioneer cdx-p24s wiring
**** - have you had an answer yet?
I've got one of those too - let me know if you still need the info.
Grtz,
Rick
Posted on May 09, 2008
SOURCE: Will not power-up after a shut down unless the CMOS is cleared.
try swapping the Ram Chips "Memory" try running it with less memory or if you have multi chips take a few out and run it
Good luck
Please rate US! thanks
I’m happy to help further over the phone at https://www.6ya.com/expert/david_92c86cbc79e9b552
Posted on Jul 14, 2008
SOURCE: Need replacement external power supply for DISH TV LCD-40-500
Dish no longer supports these monitors but you can contact Prima World Wide (PWW) between the hours of 9:00 am and 9:00 pm EST at their toll free number 1-888-267-5004 for warranty or out of warranty service and they may be able to assist you in acquiring the external power supply needed.I wish I could be of more help but want to thank you for using Fix Ya.If I can assist you in anyway please let me know.
Posted on Oct 08, 2008
Oct 04, 2017 | Cars & Trucks
Aug 05, 2016 | Building Materials
Nov 27, 2013 | Televison & Video
Oct 23, 2013 | Home Fencing
Jan 13, 2011 | Televison & Video
Jan 01, 2011 | Nintendo Wii Console
Jul 19, 2019 | Power Computers & Internet
75 people viewed this question
