Question about Samsung Televison & Video
8 series model un55ks8000fxza LED TV. Why are there vertical lines from left to right?
I think i had a power surge in my building, and now the screen has vertical lines from left to right.
Posted by Bernard Park on
5 Related Answers
ken black
  • 179 Answers
SOURCE: 50inch Samsung DLP with black vertical line on right of screen
the light tunnel has come unglued..samsung has had a problem with this in the last few years...to be absolutely certain of which part i would need the complete model number and the version number which is on a small sticker on the right side when facing the front of the set..i am fairley sure the part number is BP96-01961A. this is not the easiest job to do and you might want to contact a technician who has done one before...what city do you live in?
Posted on Nov 29, 2007
jerryg50
Jerry Greenberg
  • 1691 Answers
SOURCE: Black Line on Samsung TV Model # HPR-4252
This is a screen address failure from part of the matrix addressing. This can be caused by fair number of types of faults to cause a missing part of the addressing. You will not be able to fix this yourself.
Find out who the authorised local Samsung service is for your area. They will be able to give you an estimate.
Jerry G.
Posted on Jun 03, 2008
Anonymous
SOURCE: Vertical line on LCD TV Panel
Had this same issue on right side of 52" about 1 inch from side but had 3 vertical lines that disappeared after 40 minutes. Have Samsung LNT5265FX/XXA and about 16 months old. LCD Panel itself had to be replaced to fix it, fortunately had extended service plan
Posted on Apr 03, 2009
roety
Eric Rotmil
  • 587 Answers
SOURCE: 42 inch samsung plasma tv black vertical lines
Hi, Depeending on the thickness of the lines matters. If the lines are Black and about 1-2 inches thick it may be a bad bottom buffer board or a bad panel (screen).
If the lines are thin 1/16 to 1/8 inch it is most likely a bad panel.
You can open up the set and depending on the model, see the thin board/boards running across the bottom with ribbon cables going to the panel. You may be able to attempt reseating the ribbon cables, but be careful as some retainer plugs break very easy.
If the lines are thick black and the reseating doesn't correct it you may be able to buy the coresponding buffer. Unfortunately some bottom buffers are actually part of the panel. If you are not comfortable taking it apart then call a professional but be aware labor charges start around $200 not counting parts, panels start at $600 up to over $1000
hope this helps
Thanks
Eric
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Posted on Aug 19, 2009
Anonymous
  • 72 Answers
SOURCE: Colored "snow" vertical line an inch thick on Samsung plasma
That is the sustain and buffer boards. Try to find a repair shop to repair on the component/board level because the cost of new boards out weighs the replacement cost.
Best Regards,
Beach TV Repair
Posted on Jul 04, 2010
I have a 55" UHDHDR Samsung TV model UN55KS8000FXZA with vertical lines how do I fix it.
Check the TV signal input line to see if there is any problem, if there is no problem, call Samsung customer service hotline
Abctay.com Wholesale tv parts,include TV power supply board, logic board, TV LED screen,
Aug 14, 2018 | Samsung Televison & Video
RCA LED LCD TV Vertical Line Problem
Sounds like your display driver board is broken. Try claiming warranty.
Jul 02, 2016 | RCA LED55C55R120Q 55" LED TV 1920x1080,...
My samsung tv has thin vertical lines of all colours on left and right of screen
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Jun 11, 2016 | Samsung Electronics UN55EH6000 - 55in...
My LCD TV has a vertical line on the right side of the screen. What causes that?
Search Results
    how to fix horizontal or vertical lines on lcd tv - YouTube
    ? 4:52
    https://www.youtube.com/watch?v=k2QpYJp6MU8
    Apr 12, 2014 - Uploaded by cr4zyw3ld3r
    how to fix horizontal or vertical lines on lcd tv ... Bad T-Con/Mainboard(causes vertical/horizontal lines or half of thescreen is black)
    How to fix / repair vertical lines on half of LCD tv screen ...
    ? 5:23
    https://www.youtube.com/watch?v=8P_i-JIsrYA
    Jan 27, 2012 - Uploaded by chipotletv
    It shows how I fixed the vertical lines on the right half of a Samsung LCD screen tv. Music on video "Crazy ...
    how to fix led tv vertical lines on screen 55 ... - YouTube
    ? 9:47
    https://www.youtube.com/watch?v=zE0eqB4Ppjw
    Nov 11, 2012 - Uploaded by LUFERQUINT
    HOW TO FIX LED TV VERTICAL LINES ON SCREEN 55" MODEL LG ... YOU MAY HAVE, GIVE IT A TRY BUT DO IT ON YOUR OWN RISK!
Jan 26, 2016 | Televison & Video
How do I fix my Samsung LN52A580 TV as the right half of the screen is totally black (even thought I get sound and picture on the left hand of the screen)?
Samsung HL-R6178W DLP TV half of screen goes black [Solved] - HDTV ...
www.tomsguide.com/forum/54431-4-samsung-r6178w-half-screen-black
Aug 28, 2013 - 36 posts - ‎24 authors
Samsung HL-R6178W DLP HDTV I just bought this tv used as is. Every once in a while, the right side of the screen goes black on all inputs. I have read ... As for the 1000 dollar price tag, that's totally bonkers. I found a web site ...Missing: ln52a580
HLR6768W - Right half of screen goes black - Forums - CNET
www.cnet.com > Forums > Samsung
CNETI have a 4 year old 67" Samsung DLP which has worked pretty well other than having... Over the past 6 months it's developed a new behavior where the right half of the screen goes completely black and stays that way until I power cycle the tv.Missing: ln52a580
Samsung LN52A580 Vertical Line Problems - YouTube
? 0:32
https://www.youtube.com/watch?v=eejE6O340EY
Aug 22, 2011 - Uploaded by Jonathan Polis
Samsung LN52A580 Vertical Line Problems ... This feature is not available right now. ... LED LCD TV FIX, How To For Samsung Double Image, Black Vertical Lines, ... Sanyo LCD with DistortedHalf Picture Lines Waves Distortion Distorted ... Samsung DLP Green screen / lines Repair HLR XX67 Series ...
lcd/led tv one side dark video screen display problem fix ...
? 2:28
https://www.youtube.com/watch?v=dYHPKxijz1A
Jan 21, 2016 | Samsung LN52A580 52 in. HD-Ready LCD TV
Panasonic TC-P50VT20 blank screen with vertical lines
If you wish to get some details; visit the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Apr 05, 2017 | Panasonic Televison & Video
There was a power surge ,a black and then a blue line came on the screen,tv went off. when switch on a blue line appears, thanx
I assume by a blue line you are seeing a seeing a single line left to right across the screen. If this is the case it is a failure in the vertical deflection circuitry. There is no simple repair as a part or parts have failed. In the event of a "power surge" there could be a number of components affected. The unit would really need to be diagnosed by a competent technician. I have worked on many of this model and they are certainly repairable, but probably need two people to move it as they are very heavy as you know. I would get an estimate on the repair and make a decision based on that.
Nov 16, 2009 | Samsung TXR3079 TV
One green vertical line in HDTV Vizio 42
Try changing the H/V position in the TV Set Up menu. You can adjust the horizontal and vertical position of the screen and move it enough that the green line disappears from the screen.
May 18, 2008 | Televison & Video
Televison & Video Logo
52 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Demonic-2011
Demonic-2011
